| Gazz |
 Gazz World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 18:24 - 03 Nov 2015 Post subject: |
The plate is only there to allow the chain to be adjusted to the setting (as per OEM). Once the correct slack/tension is set the axle/pivot bolt nut is tightened to the OEM torque. If everything is clean and no shit trapped between mating surfaces then the bolt/nut torque holds the pivot in position until next adjustment/wheel removal etc.
Pull it apart.
Clean all the pivot parts washers, spacers in parrafin/brake cleaner/Jizer/Petrol woteva and re-assemble.
Put a smear of anti-seize on the mating parts and torque it to the correct torque. I haven't torqued a pivot bolt in donkeys and not had any come slack. But I have enough experience of what is tight and what isn't.
As for the brake adjustment, as you move the wheel position the brake rod length changes. Adjust the chain. and then adjust the brake.
It helps to have a lock nut on those adjuster nuts too. (And a bit of anti-seize ) They may be self-locking nuts but the nut locking device and threads can wear out over the years or if made of pasta and can slacken off for no reason. For those sort of areas belt and braces is the norm.
for the excepshonal photos too. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| someotherguy |
 someotherguy Crazy Courier
| MCN |
 MCN Super Spammer
| Vincent |
 Vincent Banned
| Raffles |
 Raffles World Chat Champion
| MCN |
 MCN Super Spammer
| Raffles |
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 10 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
