Chain Tension and Brake questions.
Gazz
PostPosted: 17:41 - 03 Nov 2015    Post subject: Chain Tension and Brake questions. Reply with quote
Two quick questions for you.
Was out this afternoon cleaning and lubing the chain and noticed that the small plate on the left side of the swingarm was moving about a bit.
How could this have occurred ?
Also noticed that the chain seems a bit loose. I cannot seem to get the tension correct (or what I deem to be correct). This is first dirtbike that I have owned and I have posted a couple of times regarding the tension of the chain. The manufacturer states that it should be 5-6cm of play measured from the bottom. Other people say that 3 fingers between the top of the swingarm and the chain are correct.
The last time I tightened the chain I took the tension to 5cm but I feel that you can pull the chain away from the sprocket far too easily and I worry that it is going to come off.
The chain seems to have slacked off slightly to around 6cm now which is making my worries slightly worse, especially with the moving plate.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xft1/v/t1.0-9/12187748_10153662009982768_4508619753713919280_n.jpg?oh=84dab07c0deffdb628cf4dde02a79ccd&oe=56B5576D
And my next question is:
I found this marking on the brake drum and I was wondering what it means exactly. Obviously it is to show how worn the shoes are on the inside, but I cannot work out when this point is reached.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xat1/v/t1.0-9/12189147_10153662009367768_7869066540588912203_n.jpg?oh=042fed202f9b40d326a192b2fc837c62&oe=56B788F6
MCN
PostPosted: 18:24 - 03 Nov 2015    Post subject: Reply with quote
The plate is only there to allow the chain to be adjusted to the setting (as per OEM). Once the correct slack/tension is set the axle/pivot bolt nut is tightened to the OEM torque. If everything is clean and no shit trapped between mating surfaces then the bolt/nut torque holds the pivot in position until next adjustment/wheel removal etc.
Pull it apart.
Clean all the pivot parts washers, spacers in parrafin/brake cleaner/Jizer/Petrol woteva and re-assemble.
Put a smear of anti-seize on the mating parts and torque it to the correct torque. I haven't torqued a pivot bolt in donkeys and not had any come slack. But I have enough experience of what is tight and what isn't. Cool
As for the brake adjustment, as you move the wheel position the brake rod length changes. Adjust the chain. and then adjust the brake.
It helps to have a lock nut on those adjuster nuts too. (And a bit of anti-seize Razz ) They may be self-locking nuts but the nut locking device and threads can wear out over the years or if made of pasta and can slacken off for no reason. For those sort of areas belt and braces is the norm.
Karma for the excepshonal photos too.
someotherguy
PostPosted: 18:26 - 03 Nov 2015    Post subject: Re: Chain Tension and Brake questions. Reply with quote
5-6cm = 3 fingers, no? Seems about the same to me.
If it says 5-6cm, make it 5-6cm.
How is that plate moving? Maybe try some new adjuster nuts, or get some locking nuts on there.
MCN
PostPosted: 18:27 - 03 Nov 2015    Post subject: Re: Chain Tension and Brake questions. Reply with quote
How is that plate moving? New bolts needed maybe?
Why is that plate moving? Razz
Raffles
PostPosted: 12:28 - 04 Nov 2015    Post subject: Reply with quote
Trunnions!
MCN
PostPosted: 12:45 - 04 Nov 2015    Post subject: Reply with quote
Raffles wrote:
Trunnions!
Trunnions.
That those round things that one chops up/slices and adds them to mince, salads, sauces and cetera?
Raffles
PostPosted: 12:49 - 04 Nov 2015    Post subject: Reply with quote
MCN wrote:
Trunnions.
They're the ones. You should try some.
talkToTheHat
PostPosted: 23:56 - 05 Nov 2015    Post subject: Reply with quote
Try pulling the chain away from the back of the rear sprocket. If you can see daylight between chain and soproclet the chain is worn out. Try also measuring the distance between links if the wear limit for this is known.
When you adjust the chain, jam the shaft of a screwdriver between chain and sprocket so the wheel is pulled hard against the adjusters before you tighten the spindle.
Bandit. does. everything.
The last post was made 10 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 65.3 Kb
