New front sprocket every 10K?
Ariel Badger
PostPosted: 01:16 - 05 Nov 2015    Post subject: Reply with quote
WTF do you expect from HD? Bunch of shysters.
davebike
PostPosted: 09:05 - 05 Nov 2015    Post subject: Reply with quote
I have on my own bike swapped out the front sprocket at about half life as it starts to wear it SLIGHTLY extends chain life but I not sure it worth the effort
It makes a lot of vibration for 500 to 1k miles after the change which is why I don't think I bother again
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 09:13 - 05 Nov 2015    Post subject: Reply with quote
<armchair experts>But you should always replace chain and sprockets as as a set or they ASSPLODE! Shocked </armchair experts>
Love the Teflonian bollocks about the chain lengthening because the outer faces of the rollers are wearing thinner. Because of course fractions of a millimetre of wear at the 4 points where they intersect with the leading/trailing teeth on the sprockets adds all that slack in the middle. Rolling Eyes
He does however make an interesting point that a worn sprocket is likely to wear a chain by tugging on it (and wearing the pins and bushings). Given the relatively low cost of the front sprocket it might actually be worth replacing it as soon as it starts to hook. Thinking
<gets out of armchair and goes to garage>
PostPosted: 09:59 - 05 Nov 2015    Post subject: Reply with quote
'Not sure if troll', considering the OP.
Stopped video at "it's not hard, is it?" - often front sprockets are made from a tougher material (steel vs a lighter alloy), meaning that it can be the rear sprocket wearing out first.
monkeybiker
PostPosted: 10:25 - 05 Nov 2015    Post subject: Reply with quote
What's your theory then?
Edit..............
Actually I just re-read what you posted. It's not just the 4 points the sprocket touches the chain. It's all along the chain. It's the holes that contain the pins that wear out and you have movement of the pins all along the chain.
https://www.kronowit.com/bicycling/chainstretch.html
wr6133
PostPosted: 10:42 - 05 Nov 2015    Post subject: Reply with quote
Isn't this the same youtube guy that did a video where he said his wife has massive chicken strips because her bike can never lean that far due to exhaust in the way and then proceeded to scotchbrite them off saying it wasn't to be a fake poser but for safety in case she ever needed to lean that far? (despite already stating her exhaust meant she could never lean that far).
If so I'd take his advice with pinch of salt.
PostPosted: 11:32 - 05 Nov 2015    Post subject: Reply with quote
Yes, that was my point.
Whatever the exact wear mechanism (I'll look at my stretched tractor chain when I get out of the armchair) we're agreeing that it must be wear at the pins/holes that causes stretch along the length of the chain, not what DelBoy said, reduced diameter on the 4 rollers in contact with the last sprocket teeth.
MCN
PostPosted: 23:16 - 05 Nov 2015    Post subject: Reply with quote
The worn sprocket will wear the chain because the wear in the sprocket effectively changes the pitch. The pitch being the distance between the pin of one link assembly and the pin/s of the adjacent links.
The damage will not be 'impact' as any chain slack will be 'taken up' on acceleration (and deceleration).
Any 'additional wear will be from the extra load on the pins and bushes due to the extended pitch 'stretching' the pitch of the chain.
The wearing three times as fast may be correct but again it it possible the front and rear sprocket materials hardness will differ to compensate if 'matched'.
Paint diagram req. Embarassed
MCN
PostPosted: 23:29 - 05 Nov 2015    Post subject: Reply with quote
This is what can happen when a chain snaps.
Delboy said to not even google it.
Well fuck him I did. Razz
https://www.youtube.com/watch?v=rEaj4Lc3Ro0
kerr
PostPosted: 16:06 - 06 Nov 2015    Post subject: Reply with quote
I do like delboy's videos but he does contradict himself a hell of a lot.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
gbrand42
PostPosted: 22:42 - 06 Nov 2015    Post subject: Re: New front sprocket every 10K? Reply with quote
MrGs1 wrote:
Dellboy suggests to replace the front sprocket every 10K as it apparently wears three times faster than the rear.
The first five minutes makes a lot of sense but when he pulls the old sprocket off and compares it with the new there doesn't appear to be a great deal of wear so I am not convinced this is anything more than OCD.
Link.
Yeah what a muppet he is, he even bolted the new sprocket on instead of welding it properly
Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European
PostPosted: 23:05 - 06 Nov 2015    Post subject: Reply with quote
Reducing diameter of the rollers doesn't affect the pitch, which is the distance the pin centres are apart. If the distance the pins are apart doesn't change then the chain is not able to be any longer in length because adding up all those pitches is what gives you your overall length.
PostPosted: 23:50 - 06 Nov 2015    Post subject: Reply with quote
Oh really? How many subscribers do you have?
</internet logic>
PostPosted: 13:32 - 07 Nov 2015    Post subject: Reply with quote
Hardness of the sprockets will make a big difference. Some last no time at all (some are alloy so wouldn't expect them to), but front ones are normally far harder.
But on some older bikes the sprockets lasted far longer than chains.
Katy
Snod Blatter
PostPosted: 13:49 - 07 Nov 2015    Post subject: Reply with quote
I replace the front sprocket once it becomes noisy, and they seem to become noisy because they "pick" at the chain as it tries to leave the teeth on the underside. The result so far has been negligible chain wear in 28K miles on the CB250. For posterity I have also been keeping a record of how each brand of sprocket lasted, complete with awful pictures (thanks Nokia and your EDoF cameras!). The 530 JT on the front of the TRX is starting to hook too at only 8K, so every 10K could be on the money..
Just my experiences Pass the popcorn
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
PostPosted: 14:59 - 07 Nov 2015    Post subject: Reply with quote
Katy
And some are too hard Very Happy
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 99.93 Kb
