| Hahadumball |
 Hahadumball World Chat Champion
 Posted: 08:30 - 07 Nov 2015 Post subject: xj 900, can you blank off the collector box on 1 side? |
Right hand exhaust snapped off at the end, welding is possible but weight reduction with a new exhaust would be a better idea...
rather than trying to get 2 matched as it has 4-2 collector box... is it possible to blank off the left side on the collector box and then just change the right exhaust?
From the image it looks like the collector box links all 4 then the gas decides where it goes.
https://www.motorcycleproducts.co.uk/images/558921.jpg
https://i.imgur.com/PIAoRdS.jpg ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| Pete. |
 Pete. Super Spammer
 Posted: 08:32 - 07 Nov 2015 Post subject: |
Pulse reflection would be horrible. Would you buy an exhaust off the shelf that looked like that? No, you would scoff at it and say it doesn't work. ____________________ a.k.a 'Geri'
| Copycat73 |
 Copycat73 World Chat Champion
 Posted: 08:44 - 07 Nov 2015 Post subject: |
weld up the old exhaust as it was designed & constructed
otherwise your gonna get problems ...
.. and look for a second hand item.
been my experience once you start weldin exhausts you never stop... ____________________ Whatever I post I have no citation and no intention of providing one..
caveat emptor |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 12:51 - 07 Nov 2015 Post subject: |
That's not really a collector 'box' as you would have with a 4 into 1 system, as a a pair of 2 into 1 Y-Pieces, with a balence - pipe between them....
In a 4 into 1 or 4 into 1 into 2 system, a collector box (or on cars a 'mid box') is a chamber that sort of pretends to be 'free-space' for the 'tuned' bit of the exhaust, the headers, to dump into, and let the pulses 'settle' and the pressure average out a bit, before flowing out through the 'silencer' (s)
A 'Balance Pipe', is just that, a pipe that can relieve pressure between chambers; used commonly on 2 into 2 exhausts on twins, where each pot effectively has its own exhaust, the balance pipe doesn't 'flow' exhaust gasses between the two exhausts, it just makes the space n one exhaust when its NOT flowing 'available' to the other as a resonance chamber, taking some of the 'pressure' n the pipe.
Snowie's Guzzi, has twin exhausts with balance pipe; and the balance pipe is actually a separate tube.. exhaust can be fitted up without it, and the bike fired up.. and you can look at the gap, where chunk of exhaust is missing, and there's actually bugger all smoke coming out of the header tube diameter holes where the balence pipe ought to be!.. quite fascinating actually... at low revs could actually sort of see a wisp of smoke come out and then get sucked back in!
To-Wit.. the answer is 'No'.
As its not a 4 into 1 or even 4 into 1 into 2 system, and that isn't a collector box, blanking off one side, would be more like sticking a bludy great cork up one silencer, and expecting the smoke from that side to flow through the balance pipe, like sticking a road-block on one side of the motorway and hoping all the south-bound traffic will do a U-turn round a junction roundabout and join the north-bound traffic without causing a tail-back! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| c_dug |
 c_dug Super Spammer
| Hahadumball |
| Hahadumball |
 Posted: 13:35 - 07 Nov 2015 Post subject: |
| c_dug |
 c_dug Super Spammer
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful? |
