xj 900, can you blank off the collector box on 1 side?
Hahadumball
PostPosted: 08:30 - 07 Nov 2015    Post subject: xj 900, can you blank off the collector box on 1 side? Reply with quote
Right hand exhaust snapped off at the end, welding is possible but weight reduction with a new exhaust would be a better idea...
rather than trying to get 2 matched as it has 4-2 collector box... is it possible to blank off the left side on the collector box and then just change the right exhaust?
From the image it looks like the collector box links all 4 then the gas decides where it goes.
https://www.motorcycleproducts.co.uk/images/558921.jpg
https://i.imgur.com/PIAoRdS.jpg
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
PostPosted: 08:32 - 07 Nov 2015    Post subject: Reply with quote
Pulse reflection would be horrible. Would you buy an exhaust off the shelf that looked like that? No, you would scoff at it and say it doesn't work.
Copycat73
PostPosted: 08:44 - 07 Nov 2015    Post subject: Reply with quote
weld up the old exhaust as it was designed & constructed
otherwise your gonna get problems ... Thumbs Up
.. and look for a second hand item.
been my experience once you start weldin exhausts you never stop...
caveat emptor
Teflon-Mike
tl;dr
PostPosted: 12:51 - 07 Nov 2015    Post subject: Reply with quote
That's not really a collector 'box' as you would have with a 4 into 1 system, as a a pair of 2 into 1 Y-Pieces, with a balence - pipe between them....
In a 4 into 1 or 4 into 1 into 2 system, a collector box (or on cars a 'mid box') is a chamber that sort of pretends to be 'free-space' for the 'tuned' bit of the exhaust, the headers, to dump into, and let the pulses 'settle' and the pressure average out a bit, before flowing out through the 'silencer' (s)
A 'Balance Pipe', is just that, a pipe that can relieve pressure between chambers; used commonly on 2 into 2 exhausts on twins, where each pot effectively has its own exhaust, the balance pipe doesn't 'flow' exhaust gasses between the two exhausts, it just makes the space n one exhaust when its NOT flowing 'available' to the other as a resonance chamber, taking some of the 'pressure' n the pipe.
Snowie's Guzzi, has twin exhausts with balance pipe; and the balance pipe is actually a separate tube.. exhaust can be fitted up without it, and the bike fired up.. and you can look at the gap, where chunk of exhaust is missing, and there's actually bugger all smoke coming out of the header tube diameter holes where the balence pipe ought to be!.. quite fascinating actually... at low revs could actually sort of see a wisp of smoke come out and then get sucked back in!
To-Wit.. the answer is 'No'.
As its not a 4 into 1 or even 4 into 1 into 2 system, and that isn't a collector box, blanking off one side, would be more like sticking a bludy great cork up one silencer, and expecting the smoke from that side to flow through the balance pipe, like sticking a road-block on one side of the motorway and hoping all the south-bound traffic will do a U-turn round a junction roundabout and join the north-bound traffic without causing a tail-back!
c_dug
PostPosted: 13:22 - 07 Nov 2015    Post subject: Reply with quote
Is this for a Diversion? or pre divvy?
I think I might still have some exhaust pieces for a 900 Diversion around the place that I'd get rid of on the cheap if you're interested?
Can't remember if I have the collector box or not still (I definitely have the downpipes and motad silencers).
Hahadumball
PostPosted: 13:34 - 07 Nov 2015    Post subject: Reply with quote
xj 900s diversion.
dont need collector box just right hand exhaust, it snapped at the end of the exhaust.
as pictured
https://i.imgur.com/bOWTUKc.png
Hahadumball
PostPosted: 13:35 - 07 Nov 2015    Post subject: Reply with quote
Teflon-Mike wrote:
No
c_dug
PostPosted: 14:25 - 07 Nov 2015    Post subject: Reply with quote
I have a pair of used motads in reasonable condition, I can dig them out tomorrow and take a picture or two, if you're interested drop me a PM.
The last post was made 10 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 13 - Page Size: 61.26 Kb
