Advice on a fixed dashcam?
Londoner2015
PostPosted: 10:22 - 09 Nov 2015    Post subject: Advice on a fixed dashcam? Reply with quote
HI all,
I'd like to install a fixed dashcam on a 2013 BMW F800R. By fixed I mean something installed on the bike, ideally that I don't have to remove every time, powered by the bike's battery, and that starts recording as soon as I turn on the engine. Something I can forget about.
The only such dashcam I know of is the Innov C3: https://www.innovv.com/#!the-c3/c18kr
This guy installed it on a F800GS: https://advrider.com/index.php?threads/innovv-c3-motorcycle-dashcam-installation-on-an-f800gs.1056599/
Have you sued it? Do you know of any alternatives? Thanks
WimbleHJR
PostPosted: 12:31 - 09 Nov 2015    Post subject: Reply with quote
Hi,
I have a Roadhawk Ride which is wired into battery via the horn. It's a fit and forget job as it records on a loop and starts when power goes to it and turns off when you stop the bike.
I have mine fitted under the front of the fairing of my Fazer which means it's out of the way of any scrotes and captures everything in front of me. I didn't want the hassle of a helmet cam, though I have used it there occasionally. Footage is good enough during the day, night isn't brilliant but would be good enough for most situations.
They have a roadhawk ride + out now which is apparently quite a bit better - think someone on here has one so hopefully they'll be able to tell you more.
HJR
YBR125, FZS600, FZ6 S2 F800ST
Londoner2015
PostPosted: 12:41 - 09 Nov 2015    Post subject: Reply with quote
WimbleHJR wrote:
Hi,
I have mine fitted under the front of the fairing of my Fazer which means it's out of the way of any scrotes and captures everything in front of me. [...]
HJR
Thanks! I didn;t know about this brand. Did you install it yourself?
Did you use one of the mounts that came with it? Did you glue it to the bike? How easy is is to remove?
If you want to download videos to your PC, do you just remove the sd card?
weasley
PostPosted: 14:19 - 09 Nov 2015    Post subject: Reply with quote
I like the look of the Innovv K1 - it's not cheap but it is an apparently well thought-out system with all the features you'd want from an incident camera. It may require some ingenuity to locate the cameras and recording unit discreetly and securely but once fitted it would seem to be fit and forget.
waffles
PostPosted: 16:56 - 09 Nov 2015    Post subject: Reply with quote
I have the Roadhawk car version fitted in my car and have nothing but good things to say so far. The only slight annoyance is it beeps when it thinks you have had an accident. But it is fit and forget, to view the footage you just take out the SD card and shove it in your computer. Mine has GPS so it also gives me my location, speed and some other data should it be needed for insurance purposes. Every so often I need to clear out the "accident" video off it (potholes etc) as it stores that but loops over the rest.
WimbleHJR
PostPosted: 17:00 - 09 Nov 2015    Post subject: Reply with quote
Londoner2015 wrote:
WimbleHJR wrote:
Hi,
HJR
Hi,
Yeah, installed it myself after a garage I used to use messed it up. It's not that hard to do, I'm a mechanical and electrical noob.
Yeah, just used one of the pads and then put a zip tie through as well just in case. Easy to remove, just unscrew it and leave the cables in place. SD card comes out or the power lead has a USB end so you can plug it into the laptop directly.
noobRider
PostPosted: 19:18 - 09 Nov 2015    Post subject: Reply with quote
I have the Innovv C3. Installed the lens under my right mirror with the recorder under the seat. It's pretty good but not fantastic after dark. Some bike vids with it are here: https://www.youtube.com/user/pbmuk/videos. The red splodge in one corner is the fairing.
Edit: If you buy it get the option with a capacitor instead of a battery as that's better when you're powering it continuously.
Licence: Nov 2012, Bikes: Suzuki GN125, Moto Guzzi Strada 750, Triumph Sprint ST 955i x 2
AnPhonEh: I need plans, I need contingency plans also, I need back up contingency plans
Val
PostPosted: 20:00 - 15 Nov 2015    Post subject: Reply with quote
You are asking for this:
https://www.4kam.com/bike_camera_motorcycle_cam_packages.htm
I am pretty sure you can assemble such system much cheaper.
CCD cameras cost about tenner nowadays £10. You just need to get suitable 2ch two channel dvr recorder.
Edit: can't find cheap 2ch dvrs. The cheapest one is £64:
https://www.ebay.co.uk/itm/2Ch-MPEG4-Compression-Realtime-SD-Card-Mobile-DVR-Car-Security-DVR-IR-Remote-/321723785446?hash=item4ae83b60e6:g:KioAAOSwBLlVK1Pr
this one £145
https://www.flyonthewall.uk.com/cctv-cameras-and-systems/in-car-security/anti-vandal-car-dvrs/hd-mobile-car-dvr-with-motion-detection-2-channel-12v-vga.html
Found complete system for £174:
https://www.ebay.co.uk/itm/Ambarella-A7LA70-K1S-Mini-2CH-Dual-Car-Camera-Dash-Cam-DVR-GPS-HD-1080p-Lesns-/252119877324?hash=item3ab38406cc:g:m-QAAOSwLVZV5p2X
If you want good low light CCD cameras with Sony CCD sensor you need to pay some money:
https://www.flyonthewall.uk.com/2-channel-hd-car-dvr-with-low-light-ccd-cameras-motion-sens-32gb.html
Val
PostPosted: 01:09 - 16 Nov 2015    Post subject: Reply with quote
MrGs1 wrote:
Val wrote:
I don't know what I am talking about.
Cheapo camera £10
Recorder £64.
Power leads. £??
SD card. £??
Mount(s). £??
Plus postage and the ballache of setting it all up.
Alternatively one can get all of that with the innovv c3 for £84.86.
Except Innovv is with 1 camera the set up I am talking about above is for 2 chanel dvr with 2 cameras - one front and one rear. The OP is talking about black box accident recording device not for some hipster youtube see my video helmet cam.
Innov has 90 degrees viewing angle only and god knows how good is at low light. My educated guess is it is very bad in the night.
The "cheapo" CCD cameras I mean are with Sony low light CCD sensor which is in times better in the night. Minimum illumination: 0.01 Lux.
https://www.ebay.co.uk/itm/131553829793?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
noobRider
PostPosted: 03:35 - 16 Nov 2015    Post subject: Reply with quote
Innov C3 is full 1080p recording. It's very good in daylight, not so good in the dark, but not awful. 120 degrees viewing angle option. I think it's pretty good for £100. I'm happy with mine.
They also do the K1 for a two camera set up that looks really good for £170.
I didn't want to spend a fortune and build my own.
.. This post is not being displayed because the poster is banned. Unhide this post / all posts.
Val
PostPosted: 11:02 - 16 Nov 2015    Post subject: Reply with quote
Do not get me wrong Innov is a good ready made set up. I feel you can do better with your own custom set up. At the end of the day Innov are buying cheap Chinese components and resseling them as theirs.
And the 2 camera K1 set up is not theirs. This is Chinese KOONLUNG Dual Car Dash Camera + GPS Logger | Front and Rear 1080p Remote Lens Cameras | 140 Degree lenses | 64GB microSD capacity | Ambarella A7LA70
Which has been sold by many different names and cost about £150:
https://www.amazon.co.uk/dp/B00TM59NCK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2FMU73Y2PUG2U&coliid=IBO9T1KFBVFMN
The cameras in K1 set up are much more inferior quality and night light sensitivity then this one which has Sony sensor and costs mere £9:
and the Chinese vendor makes that clear in his posting:
https://www.ebay.co.uk/itm/131623614063?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
While video quality will satisfy many people, the night quality is a bit worse than the dual cameras which are using the Sony Exmor CMOS sensors
Innov does not give you ANY technical specifications about the sensor on their product.
noobRider
PostPosted: 11:36 - 16 Nov 2015    Post subject: Reply with quote
FOV: 120°
C3-Lens: 6G glass,F/ON=1.8,f=2.8mm,diagonal 127°/ horizontal 90° / vertical angle 91°
Image Sensor: Aptiona AR0330 1/3-Inch CMOS Digital Image Sensor
https://www.minidvcameras.co.uk/viewitem.php?productid=125
This is where I got mine
Val
PostPosted: 13:06 - 16 Nov 2015    Post subject: Reply with quote
MrGs1 wrote:
Show me a DIY set up for less monies than the K1 and I will buy it.
I cannot. The 2 channel DVRs are very expensive. Means K1 for £150 from some Chinese vendor is the best value for money currently.
I do have just bought yesterday 1 channel DVR for £18:
https://www.ebay.co.uk/itm/261710246845?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and a low light Sony sensor camera for £8:
Which will make the 1 camera set up cost me £26.
If I do not find soon cheap 2ch DVR I may just buy second DVR with a camera for another £26. Still will be 3 times cheaper then K1 Laughing
Will post some videos next week Very Happy
weasley
PostPosted: 14:25 - 16 Nov 2015    Post subject: Reply with quote
But none of that is 1080p HD - VGA resolution maximum.
eBay DVR ad wrote:
Specifications:
1. Color: Blue
2. Video System: PAL/NTSC
3. Recording Mode: Continuous / Motion Detected / Mixing
4. Video Input / Output: 1 Channel Input and 1 Channel Output
5. Audio Input / Output: 1 Channel Input and 1 Channel Output
6. Video Encoding: AVI
7. Browse Software: Support Windows Media Player
8. Recording Function: Local Storage / Loop Video Recording
9. Recording Frame Rate: Real Time 1~30fps Adjustable
10. Record Resolution: VGA (640 x 480), QVGA (320 x 240)
eBay camera ad wrote:
Specifications:
Adopt color 1/3" Sony Super HAD II CCD + Effio-e DSP
Max horizontal resolution reach 700TV Lines
2.1mm Lens
Viewing Angle: 140 degree
Val
PostPosted: 13:16 - 28 Nov 2015    Post subject: Reply with quote
MrGs1 wrote:
Any update yet Val? Wink
I bought the camera on 16th it was ment to arrive on 18th according to the seller. However it appears it will come from China god knows when Rolling Eyes
It is coming. Having said that we know the resolution will not be too great, so I am looking at 4k cameras too now Very Happy can't find any cheap though...found Firefly 6S, here are Firefly 6s vs GoPro 4 Black:
https://www.youtube.com/watch?v=unwTlqN-_Uc
Good news is Firefly is cheap £64 for 4k video is not bad:
https://www.gearbest.com/action-cameras/pp_239152.html?currency=GBP&gclid=Cj0KEQiAvuWyBRDO_Yzhpv_4nvEBEiQANBdXMssHsjMtT1cf0f3YvldbwG9SXIt1UGcX_J4_soY_un4aArhg8P8HAQ
The resolution looks better then Gopro not sure is that too good to be true?
https://farm1.staticflickr.com/680/23369291475_64c2aa5152_o.jpg
Not good for permanent set up though...
Looking at Foxeer Legend 1 too.
2015-11-28 04:40
UNITED KINGDOM, ITEM SENT TO COURIER
2015-11-27 20:03
UNITED KINGDOM, ITEM PREPARED FOR DELIVERY
2015-11-27 02:13
2015-11-27 02:13
2015-11-27 02:09
UNITED KINGDOM, RECEIVED AT HERMES DEPOT
2015-11-27 02:09
2015-11-26 17:32
UNITED KINGDOM, ITEM SCANNED BY HERMES
2015-11-25 21:26
UNITED KINGDOM, Shipped from HUB OXF
2015-11-25 21:26
2015-11-25 20:57
UNITED KINGDOM, Received at HUB OXF
2015-11-24 15:31
AMSTERDAM - NETHERLANDS, Custom clearance completed
2015-11-24 15:31
2015-11-24 12:19
AMSTERDAM - NETHERLANDS, Custom clearance processing
2015-11-24 12:19
2015-11-23 05:50
AMSTERDAM - NETHERLANDS, Arrived at LONDON airport
2015-11-21 06:41
HONGKONG - HONGKONG, Departed Facility in HONG KONG
2015-11-21 06:41
2015-11-21 00:38
HONGKONG - HONGKONG, Arrived at Sort Facility HONG KONG
2015-11-21 00:38
2015-11-18 03:28
SHENZHEN - CHINA, Departed Facility in SHENZHEN
2015-11-18 03:27
SHENZHEN - CHINA, Arrived at Sort Facility in SHENZHEN
Val
PostPosted: 14:14 - 28 Nov 2015    Post subject: Reply with quote
MrGs1 wrote:
So exactly how much have you spent on this DIY dash cam?
Nothing the picture above is screenshot from some guy dashcam comparision of high 4k resolution cameras: Firefly 6S vs GoPro 4 Black.
The one I bought is £8 and is not so high resolution and is still in transit not have it yet Very Happy
The last post was made 10 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 139.37 Kb
