Samsung S5 misbehaving
bikertomm
PostPosted: 21:21 - 10 Nov 2015    Post subject: Samsung S5 misbehaving Reply with quote
Hi lads, got an S5 had it for about a year and a bit now.
Over the last day I keep getting this error message:
https://i1145.photobucket.com/albums/o520/bikerrtomm/Screenshot_2015-11-10-20-14-54_zpswwi87r5z.png
Happens when I go to use anything really, app store, snapchat etc. I press ok it goes away and comes back again for a bit then stops for a bit.
Today when I got to work my battery was on 41% when it usually would be on 90%, the phone is also getting hot
So something is clearly hammering it's CPU or RAM or whatever, haven't ever messed with the phone its standard 16gb with a 60gb memory card in (half full up)
And it keeps badgering me to update which I've been putting off now for forever.
I will get round to it.. maybe it will solve all my problems? Very Happy
Anyone got any ideas?
Cheers. Thumbs Up
Boris the spider
PostPosted: 21:28 - 10 Nov 2015    Post subject: Reply with quote
Update it.
The apps etc you have might need the update to operate.
I always make sure background stuff on mines are closed, Same with data roaming. If i aint using it. Switch it off.
Updated mines just the other day.
Runs great
Yes I'm a pig....And yes... The working public do pay my wages. Tho I contribute to your benefits you lazy c##t. You do not pay my wages. So go fcuk yourself.
bikertomm
PostPosted: 21:33 - 10 Nov 2015    Post subject: Reply with quote
I really need too.. I have next to no memory either which isn't helping - don't have enough for the update which is why I keep not getting round to it!
Also very little of my photo's are backed up because my laptop can't handle it.. and I'm getting a new one very soon so keep putting it off before I can get backed up! Laughing
CaNsA
PostPosted: 21:57 - 10 Nov 2015    Post subject: Reply with quote
Check out My Phone Explorer
https://www.fjsoft.at/en/
and
https://play.google.com/store/apps/details?id=com.fjsoft.myphoneexplorer.client
Needs alot less grunt than the over bloated Samsung Kies.
Accuhaler
PostPosted: 22:24 - 10 Nov 2015    Post subject: Re: Samsung S5 misbehaving Reply with quote
This happens to me too, removing the battery for 20 seconds and restarting my device allows the screen to become the highest battery drain again.
Also for future reference if you ever get the camera failed when trying to use the camera, removing the battery also fixes this.....
I don't know how, or why but it does!
PostPosted: 23:05 - 10 Nov 2015    Post subject: Reply with quote
Mine has that issue too. Just got the update which has stopped most. Destiny app however has become spastic. PM me your snapchat for late night dick pics. Thumbs Up
bladerunner
PostPosted: 02:02 - 11 Nov 2015    Post subject: Reply with quote
Check the battery hasn't started to get puffy ie on its last legs and likely to catch fire soon!!! It would cause heat build up and lower power to the phone so apps which need a bit extra may push it over the limit and cause issues. Failing that give it a factory reset once you've backed everything up properly. If your phone is detecting excessive heat build up it will throttle back your Cpu to prevent more heat being generated and possibly give you a laggy experience.
bikertomm
PostPosted: 16:17 - 12 Nov 2015    Post subject: Reply with quote
Thanks for suggestions lads.
Trying to copy 5000 pictures off fucks my laptop to no end, work computer can't handle it, can only upload 250 at a time to dropbox.. lesson learnt to keep on top of it.
I've definately found the culprit though by looking in battery settings
https://i1145.photobucket.com/albums/o520/bikerrtomm/Screenshot_2015-11-12-15-09-23_zpsd0tvdvuk.png
https://i1145.photobucket.com/albums/o520/bikerrtomm/Screenshot_2015-11-12-15-09-27_zpst2tbj0sl.png
If I delete google play store, how do I get it back again when thats what I use to download apps? Laughing
Will try backing up 1 last time then update it to jizz pop lollipop tonight.
Cheers Thumbs Up
CaNsA
PostPosted: 16:50 - 12 Nov 2015    Post subject: Reply with quote
If you have a 64gb memory card.... move all the photos and videos to it.
Use the Dick Usage app to find out what crap you have on your phone memory and remove anything you havent used for atleast a month.
https://play.google.com/store/apps/details?id=com.google.android.diskusage
PostPosted: 17:33 - 12 Nov 2015    Post subject: Reply with quote
I've only just got my first android phone, (OnePlus 2) on it if I click the battery it shows me what has drained the battery. I had a similar issue and GMail was the culprit. Does the S5 not have the battery info? Can you DL an app for it?
bikertomm
PostPosted: 17:44 - 12 Nov 2015    Post subject: Reply with quote
Yeah I do cansa, I've got everything I possibly can on the SD card, I have no idea what's taking up the 16GB! Deleted alot too. Now have 600MB free ffs!
Thanks will check out that dick usage thing!
@ Chris-red, check my last post! Razz It's inbuilt, I forgot to check it at first. Thumbs Up
Im-a-Ridah
PostPosted: 15:10 - 13 Nov 2015    Post subject: Reply with quote
In addition to the battery removal technique, also check that the GPS is on power saving. If it switches over to high accuracy and you use an app which accesses the GPS, it can drain the battery at a shocking rate.
S5, S4, and S3 all have it IIRC.
Laughing Thumbs Up
PostPosted: 15:15 - 13 Nov 2015    Post subject: Reply with quote
Sorry must not have read that properly! (pics are blocked at work)
CaNsA
PostPosted: 16:07 - 13 Nov 2015    Post subject: Reply with quote
Laughing Thumbs Up
3 fucking times i re-typed it....
ffs
Very Happy
The last post was made 10 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 87.56 Kb
