| MC900 |
 MC900 Nitrous Nuisance
 Posted: 08:04 - 09 Nov 2015 Post subject: YBR125 problem |
On my way to work today and half way there my bike started juddering (like it does when its low on petrol). Little bit further through my journey and the bike cut out so i rolled to a stop. Started the bike again and continued but the problems still existed and my bike stopped again. The bike does not start every time and sometimes wont tick over.
It just judders and cuts out, also when it cuts out it sometimes sounds like the bike is in too high of a gear (its not) and is labouring. Does anyone have any idea what the problem could be?
I had a similar problem a while back where it would judder and struggle to start/tick over. I took it to the garage and they cleaned the fuel injection and it was fine until now. Maybe its the same problem, or something else?
Its got a full tank of petrol, new spark plug, new oil.
Cheers for any help  ____________________ Current Ride: Fazer 600 (02) & YBR125 (07) |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:19 - 09 Nov 2015 Post subject: |
How's your battery? Given the wiring a good wiggle and a dose of WD-40? ____________________ Biking is 1/20th as dangerous as horse riding.
| MC900 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:35 - 09 Nov 2015 Post subject: |
| MC900 wrote: | My battery is a new one |
Usual question: why did you change it, did you diagnose the cause, did you charge it fully, is it charging up, and is it holding charge? ____________________ Biking is 1/20th as dangerous as horse riding.
| zark |
 zark Trackday Trickster
 Posted: 17:16 - 09 Nov 2015 Post subject: |
07 YBR, so the fuel injected one? Does the yellow engine light blink when it stalls? Does it re-start on the button or do you have to kick it?
I've said it before - but 99% of the running problems on my YBR were solved by sorting out the charging system. I could just about get away with charging the battery every couple of nights - but the only proper fix was to replace the stator (that had melted on the inside, so impossible to see without removing it). Ran as good as new after that... When it was struggling for electricity - the indicators and headlamp wouldn't work, and pressing the brake or horn made the rev counter drop to zero.
A multimeter and a healthcheck of your charging system will save you headaches and replacing random components. (I've got a reg/rec for sale due to doing exactly that ) ____________________ CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou... |
| Rogerborg |
 Rogerborg nimbA
| MC900 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:21 - 10 Nov 2015 Post subject: |
Could be. They've seen the bike, we haven't.
To get that diagnosis, they should have:
1) Done a compression test and seen a low reading.
2) Squirted oil into the cylinder and repeated the test.
That's about 5 minutes on a YBR. ____________________ Biking is 1/20th as dangerous as horse riding.
| evilzed |
 evilzed Scooby Slapper
| MC900 |
| MC900 |
 Posted: 01:37 - 11 Nov 2015 Post subject: |
Just looked at your thread. My airbox did have water in it and it looked similar to the picture in your thread. The mechanic cleaned the airbox, what else can I do and what could it mean? ____________________ Current Ride: Fazer 600 (02) & YBR125 (07) |
The last post was made 10 years, 341 days ago. Instead of replying here, would creating a new thread be more useful? |
