Brake piston kit?
FlubbaBubba
PostPosted: 15:22 - 11 Nov 2015    Post subject: Brake piston kit? Reply with quote
Need a 35mm OD by 32mm long brake piston kit, the only ones i can find are the boot kind, the one on the bike is grimeca
calliper with the two seals and no boot.
So does anybody know where i can get one or an alternative.
I cant find any for the bike and the dealers want me to buy the whole calliper for £180 even though i just need the piston and seals
Its for a 2005 aprilia mx 125, any help would be much appreciated, thanks.
PostPosted: 15:28 - 11 Nov 2015    Post subject: Reply with quote
Wouldn't be the hardest thing in the world to make up on a lathe.
Know any machinists?
FlubbaBubba
PostPosted: 15:35 - 11 Nov 2015    Post subject: Reply with quote
I should be able to find one that can make it but what about the seals as the ones on the bike just piss fluid everywhere when i try to bleed it.
bladeblaster
PostPosted: 16:05 - 11 Nov 2015    Post subject: Reply with quote
They should sell you the seals separately, but Aprilia only sell the pistons as an assembly with the calliper, thats why they are quoting you for a new calliper. If you ask for just the seals it shouldn't be an issue.
How bad are the pistons you have, would they clean up?
FlubbaBubba
PostPosted: 17:08 - 11 Nov 2015    Post subject: Reply with quote
The piston isn't that bad its just a bit worn out an i don't want to buy new seals and fit them to a worn out piston to find out they start leaking.
Robby
Dirty Old Man
PostPosted: 18:11 - 11 Nov 2015    Post subject: Reply with quote
Is this what you're looking for:
https://www.motorcycleproducts.co.uk/brake-caliper-piston-seal-kit-2250mm-35mm-p-7471.html
[edit] or this:
https://www.patternbikeparts.com/productinfo.asp?ProductID=120010
Fizzer Thou
PostPosted: 18:49 - 11 Nov 2015    Post subject: Reply with quote
Robby wrote:
Those are both useful sites Smile Thumbs Up
Always have a 'Plan B'
FlubbaBubba
PostPosted: 20:17 - 11 Nov 2015    Post subject: Reply with quote
Robby wrote:
Yeah thats it but i cant seem to find the right size piston it needs to be 35mm OD and 32mm long but no were sells them, i found some but it has a boot and mine takes two seals.
iooi
PostPosted: 22:52 - 11 Nov 2015    Post subject: Reply with quote
Try this lot
The last post was made 10 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 62.81 Kb
