| ItsTommmm |
 ItsTommmm Derestricted Danger
| Minty |
 Minty World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 20:26 - 11 Nov 2015 Post subject: |
What he said.
Try tapping the float bowl a bit with the handle of a screwdriver, it's never worked for me, but it seems to be the go-to advice for a stuck float jet  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| kramdra |
 kramdra World Chat Champion
 Posted: 20:28 - 11 Nov 2015 Post subject: |
Float needle valves or leaking floats are likely.
Take needles out, inspect the rubber tip, clean them up, clean up the seats. Rub aluminium foil on the metal shaft of the needle, (avoiding the rubber tip) - this works extremely well. If the tip is damaged, order new ones.
Put floats in water. Do they float, or bubble if you submerge them?
Refit and check the heights are set correctly.
Its a new-used carb, I assume you did not inspect it before fitting?  |
 ..... Quote Me Happy
| ItsTommmm |
| dubloman |
 dubloman Derestricted Danger
| ItsTommmm |
| dubloman |
| Burnzy1989 |
 Burnzy1989 Nitrous Nuisance
| WD Forte |
 WD Forte World Chat Champion
| ItsTommmm |
 Posted: 23:07 - 11 Nov 2015 Post subject: |
think its sorted now thanks guys  |
| Raffles |
 Raffles World Chat Champion
| Rogerborg |
 Rogerborg nimbA
The last post was made 10 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
