Today I did have an adventure
dydey90
PostPosted: 17:52 - 13 Nov 2015    Post subject: Today I did have an adventure Reply with quote
So today was my final mod 2.
Woke up around 6am, room spinning and feeling nauseous. Not good.
Didn't have to be there until 12, so I found time to man up and worked out the room only spins when I tilt my head.
Went to the training school and hopped on their Gladius, headed out to the test centre. BUT THEN, went to park up and the front brake went slack. Pumped it quickly and got it to stop. Turns out one of the brake pads had let go and was hanging out of the calliper. Could not reinsert due to some dick pumping the brake.
Anyway, bike recovered, luckily they'd taken two of us so I got to go on the other bike. Still a Gladius, but with different bars on. Examiner nearly called it off due to wind and rain but we got out in the end.
Passed, great success!
Had to go back as a pillion on the instructors bike, which was a new experience for me. Did not like, but he was gentle with me.
tl;dr
Shouldn't have operated machinery today
Killed a bike
Passed test
Rode pillion
Kitten casualties: 0
PostPosted: 17:54 - 13 Nov 2015    Post subject: Reply with quote
Dude. Clapping Cool
Nexus Icon
PostPosted: 18:04 - 13 Nov 2015    Post subject: Reply with quote
Well done Thumbs Up
Did you find the anxiety of everything else going wrong meant you were just relieved to be able to take your test rather than nervous about it?
I certainly was when I got a puncture on the way to the test centre and had to run back home, get the car, drive to a training school near the test centre, borrow a bike (free - thanks Lightning Oxford) and race to the test centre just in time to take my test on a bike I'd never even sat on before. I was so relieved to get there that I wasn't nervous at all.
Greetings from Shitsville!
.Bishbash.
PostPosted: 18:05 - 13 Nov 2015    Post subject: Reply with quote
Bravo chap....You manned up and now you have the best thing a man can have, a full bike license!
Current bike - GSX-R1000 k8
monkeybiker
PostPosted: 18:58 - 13 Nov 2015    Post subject: Reply with quote
Sounds like a shit training school, could have killed someone. Never in my life have I ever had a brake fail. How worn were the pads?
Anyhoo well done on passing Thumbs Up
dydey90
PostPosted: 19:17 - 13 Nov 2015    Post subject: Reply with quote
The pads didn't seem worn, instructor said the only time he's seen it happen was on his old ZX550 when one side of the calliper seized so it only wore down one side, but this one didn't seem bad.
Don't seem to have much luck with brakes, can't get the ones on my ZZR to stop bloody leaking either!
Brendan110_0
PostPosted: 19:22 - 13 Nov 2015    Post subject: Reply with quote
Reminds me of mine, pulled up at the test center at end of test, puts side stand down and it fell off completely. There's me sat on the bike the assessor asking why the hell I'm still sat there and not inside as asked, leaned it against the wall like a BMX ha ha.
sreeB fo gniK
monkeybiker
PostPosted: 19:35 - 13 Nov 2015    Post subject: Reply with quote
Where is it leaking? Your not riding it like that are you?
dydey90
PostPosted: 20:32 - 13 Nov 2015    Post subject: Reply with quote
Hell no I can't take it out with no brakes. I've completely stripped and rebuilt the calipers, I've probably not cleaned out the seal recesses well enough.
pepperami
PostPosted: 20:53 - 13 Nov 2015    Post subject: Re: Today I did have an adventure Reply with quote
Top hole Thumbs Up Thumbs Up
wr6133
PostPosted: 21:29 - 13 Nov 2015    Post subject: Reply with quote
The tokico callipers are total dogshite. Swap them out for Nissins, if you trawl eBay you can probably do it for similar cost to rebuilding the shite ones.
I persevered with my tok's for ages, rebuilding, swapping between my 3 sets, bleeding, various pads. Even freshly built and bled they are spongey crap. I threw a set of nissins from an old blade on about a month ago and now want to scourge myself with a cat-o-nine tails for not doing it sooner.
ScaredyCat
Examiners Vs Weather ...
Rolling Eyes
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
dydey90
PostPosted: 21:31 - 13 Nov 2015    Post subject: Reply with quote
Any idea what to look for? I have no idea what will fit and what won't!
wr6133
PostPosted: 21:38 - 13 Nov 2015    Post subject: Reply with quote
Here is what I used and how I did mine. I had to hack at my mudguard, a lot of other Nissins that can be used don't require that (but often cost a lot more).
https://www.zzr-international.co.uk/viewtopic.php?f=16&t=16315
or if you prefer YouTube format https://youtu.be/wyUfbhTYce4
Here is a complete list of what fits (though spacers and/or shouldered bolts are usually needed)
https://www.zzr-international.co.uk/viewtopic.php?f=13&t=14658
It's worth joining zzr international. It's a bit slow as a forum but very useful as a knowledge base.
dydey90
PostPosted: 21:42 - 13 Nov 2015    Post subject: Reply with quote
These look about right then? For £50 it would save me a lot of hassle and finally give me some use out of the bloody thing!
wr6133
PostPosted: 21:49 - 13 Nov 2015    Post subject: Reply with quote
Same as I used.
To mount them you can...
1 - 10mm-8mm shouldered bolt and use washers between calliper and leg as spacers
2 - Get/DIY tap the nissins to 10mm, use original bolts and washers to space
3 - Splash out on these and use some 8mm bolts. https://www.ebay.co.uk/itm/ZZR1100-ZZR600-CALIPER-SPACERS-TO-RUN-GSXR1000-CALIPERS-/231728856372?hash=item35f41dbd34:g:XWMAAOSwpDdU465T
I used option 3 because.... lazy, no farting about trying to get the spacing right.
dydey90
PostPosted: 21:55 - 13 Nov 2015    Post subject: Reply with quote
£20 for a bit of chuffing plastic?!
Shoulder bolts it is!
I'll get a pair ordered, thanks!
wr6133
PostPosted: 22:04 - 13 Nov 2015    Post subject: Reply with quote
Ali, but yeah price is a bit bonkers, I got lucky at auction and paid £13 for the callipers though so decided to splash out.
Using shouldered bolts you'll want a handful of washers too, you'll need to space out between calliper and leg by around 2mm (with the top hat spacer the rim bit does that).
PostPosted: 22:12 - 13 Nov 2015    Post subject: Re: Today I did have an adventure Reply with quote
dydey90 wrote:
Could not reinsert due to some dick pumping which was a new experience for me. Did not like, but he was gentle with me.
Shocked
dydey90
PostPosted: 22:17 - 13 Nov 2015    Post subject: Reply with quote
STEVEN NO
PostPosted: 00:28 - 14 Nov 2015    Post subject: Reply with quote
Another entry in the "bike shat itself, passed test on a surge of rageadrenaline" column. Well played, sir. Thumbs Up
Stalk
PostPosted: 09:09 - 14 Nov 2015    Post subject: Reply with quote
Had leaky calipers on step stalks zxr, it was badly made bleed nipples that came with the seal kit. It was only a slight leak so it was difficult to see as the fluid was running down the middle of the caliper.
Just a thought, might be worth a look?
dydey90
PostPosted: 15:12 - 14 Nov 2015    Post subject: Reply with quote
I threw away the old bleed nipples, I'll have a look and see if there's anything coming through the middle. Thread should be fine, I used PTFE tape.
The last post was made 10 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 119.2 Kb
