Cheeky Chaly Rebuild
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5  Next
binge
Emo Kiddy
PostPosted: 22:27 - 04 Nov 2015    Post subject: Reply with quote
Good guesswork. Cool
PostPosted: 16:25 - 05 Nov 2015    Post subject: Reply with quote
Front brake cable for a Jawa 350 terminates in an M6 threaded rod.
binge
Emo Kiddy
PostPosted: 20:29 - 05 Nov 2015    Post subject: Reply with quote
I've got an idea in mind, which I think should work.
My cable clamp is arriving tomorrow. It's a Gokart brake cable joining union.
Two grub screws, kinda like a heavy duty version of an electrical lego block.
I'm hoping it's around 4/5mm dia inside, so I can tap it to M6, and screw a length of threaded bar in one side, lock it off with that grub screw.
Then I can insert brake cable in other side, and clamp it up.
Tomorrow will tell.
Tonight, I have fabbed up some headlamp bowl brackets because I think proper ones are disgustingly expensive for what they are. And they're all far too big for Chaly.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xaf1/v/t1.0-9/12219414_172588286425538_8881607804858146816_n.jpg?oh=51cd963e8730255d5d740d9b7ba2d8bf&oe=56B31F62
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xap1/v/t1.0-9/12195776_172588306425536_4470706880756186028_n.jpg?oh=4266c71b342468b9bcc98b51a6179190&oe=56BBA396
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/12219589_172588349758865_1160025753982297285_n.jpg?oh=120a71fc49d411106b0d1629c75e0a59&oe=56B50142
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/12189542_172588369758863_8161629945337261421_n.jpg?oh=162bb814aefd072be59c0761b874bd03&oe=56B3B443
binge
Emo Kiddy
PostPosted: 23:40 - 05 Nov 2015    Post subject: Reply with quote
I have a question regarding electrics on this bike. I might stick a thread in the workshop if I don't much in the way of answers here. (Not many people wanna follow the build of a pink moped Laughing )
Ignition wiring:
Depending on how well my LED lights handle it, I am planning on running a battery-less system. So the stator will be wired into the Reg/Rec, and then directly to the loom and electrics. Killing the engine, will of course, instantly kill the electrics.
This works well with the key and barrel I have got. I managed to keep one off an old CBR125 I was breaking for parts. It's a lovely OEM Honda ignition barrel with a Honda engraved key (Hence the reason I'd like to use it).
The barrel though, only has 2 wires coming out of it.
I am used to the simple 4-wire barrels which come on pit bikes. 2 wires which connect with ign on, and the other two disconnect.
With ignition off, they simply reverse.
The connecting wires to link up the electrics to the battery.
And then the disconnecting wires, to allow the coil to power the spark plug, rather than earthing it to the frame.
With a 2 wire stator (I need to check the function of the two wires yet, whether they connect or disconnect with keys on), how would one go about wiring up a loom with a battery (should I need to use one)?
Cheers,
Ben
Iain.
PostPosted: 01:07 - 06 Nov 2015    Post subject: Reply with quote
Dropped you a wiring diagram. Thumbs Up
binge
Emo Kiddy
PostPosted: 22:53 - 09 Nov 2015    Post subject: Reply with quote
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xaf1/v/t1.0-9/12122898_174637456220621_5155481344736187672_n.jpg?oh=d2ffa6a872d1998ca6668f9e8ee87131&oe=56BD235E
My idea worked perfectly. Cool
binge
Emo Kiddy
PostPosted: 16:10 - 11 Nov 2015    Post subject: Reply with quote
Gotta chuckle.
I was routing through a friends facebook photos the other day as I have deleted my old facebook and have no photo archives any more.
I stumbled across this photo which I sent to my pal the day after I bought the Chaly.
I've had it roughly 4 years now, and the Ex was not best pleased when I arrived home from work one evening and said 'we're off to collect a motorbike'.
5 hours later when we arrived in Plymouth, and the chap handed me this frame, and a pile of rusty parts, all I heard from the passenger seat of my old Clio was 'you've dragged me all this way to buy that?....'. Laughing
The most important bit really was the frame and V5, the rest was all junk.
But I gave the pricely sum of £80 for it.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xtf1/v/t1.0-9/12227049_174855046198862_5564732482066305078_n.jpg?oh=21c6b0956f400f2aabafc36f47af045f&oe=56F36EF8
This afternoon, I decided to get the chain fitted up. I had to revert back to my smaller rear (Talon) sprocket, because unbeknown to me, my other rear sprocket was actually 420 pitch. I have no idea how it had been running all that time, as the chain and front sprocket were both 428. I can only assume the old chain was worn enough to fit into both sprocket sizes.
I also got the leg shield bolted up. I need to get it in for plastic welding really.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/12239470_175348376149529_987070962267594545_n.jpg?oh=73a3eff0252ecaf117c66305cb9383ce&oe=56BC435D
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/12239539_175348392816194_2283102217076395229_n.jpg?oh=97fee4877ae2fc851c20d10380dd861e&oe=56F74E05
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-9/12219630_175348422816191_5583424286134967379_n.jpg?oh=40707c1dca5084cca90ee35fbe897113&oe=56B69082
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xtp1/v/t1.0-9/11215856_175348459482854_2173988795166918394_n.jpg?oh=72696b52dc14fdf7f7cdaa75f4a2a581&oe=56F31ED5
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/12191637_175348472816186_1639970883324249333_n.jpg?oh=6e5011f4329aa0b46013fc6104c0c3d0&oe=56ACB1D3
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xat1/v/t1.0-9/12243253_175348502816183_3083208426728322877_n.jpg?oh=50971474319865ce6eb723ad5f5cc3fb&oe=56BB6DF0
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xaf1/v/t1.0-9/p720x720/12241481_175354296148937_6303218436982414796_n.jpg?oh=c3a126314627cef24cbfbedfb35fa78f&oe=56B4FB0C&__gda__=1459156971_75f8ae426ee09cf51b93c5dd8762e943
Doovy
PostPosted: 16:23 - 11 Nov 2015    Post subject: Reply with quote
That does look pretty sweet Cool
Just wish it was a different colour if I'm honest Laughing
Great work though Thumbs Up
binge
Emo Kiddy
PostPosted: 20:24 - 11 Nov 2015    Post subject: Reply with quote
Shot down to the garage and got some petrol.
Filled her up, made up a basic ignition loom (Still need to do one for the lights etc).
Pretty chuffed how easily it started with the cheapy carb on it. Little bit of fettling to be done with the air screw, but that's about all it'll need. I'm pretty confident it's jetted just right.
https://www.facebook.com/Binge.Jammin1987/videos/175471056137261/?l=9031272628567001759
https://www.facebook.com/Binge.Jammin1987/videos/175467616137605/?l=2121635525819067400
PostPosted: 14:02 - 12 Nov 2015    Post subject: Reply with quote
Now all you need are some white, rhinestone-studded leathers to ride it in.
stevo as b4
PostPosted: 14:29 - 12 Nov 2015    Post subject: Reply with quote
Still very cool, and very pink but I just hope the target audience looks more impressed with it than your dog does! Laughing
Polski
PostPosted: 20:55 - 15 Nov 2015    Post subject: Reply with quote
That it totally finished?
Colour scheme is wild but In a weird way I actually quite like it haha
binge
Emo Kiddy
PostPosted: 01:48 - 16 Nov 2015    Post subject: Reply with quote
Wiring loom to be done, and a few stickers for the leg shield and she's about done.
I do need to make up a bump/lock stop for the bars as they are DAX yokes on Chaly frame. The stops don't line up.
Little project lined up for this though. I'm looking at adapting the 120cc Thumpstar engine to Semi Auto (Apparently it can be done), and then putting it into the Chaly.
120cc Thump engines are super punchy for their size. And also electric start, so nice and posh too! Laughing
binge
Emo Kiddy
PostPosted: 18:49 - 18 Nov 2015    Post subject: Reply with quote
So today, I pulled Chaly out of the garage:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xlf1/v/t1.0-9/11988437_178681545816212_6065329868588465137_n.jpg?oh=ef915fb90ae29e29dbea63537467e686&oe=56E42645
And introduced the new power-house:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xaf1/v/t1.0-9/12241207_178681579149542_4399748733254628103_n.jpg?oh=293694ed5cec55fe7430d619a6e7a1c4&oe=56B8BA32
Comparison of the two engines. Although the Thumpstar is a 120cc engine, it doesn't fall under the same category as the cheapy Lifan 120's etc. It's based on the bigger 125cc engines (YX125, Jialing etc), so it's quite a lump. Bigger ports, Mikuni VM22 carb, and a higher lift cam.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xat1/v/t1.0-9/12243245_178762692474764_6673802868694680395_n.jpg?oh=3353d6c9e491909da7c8ea18ba2e55f2&oe=56EB633D
Clutch covers and clutches removed as I wan't to convert the Thumpstar from manual, to semi Automatic.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/12243406_178762725808094_4826116325770067050_n.jpg?oh=a69c868f6fefd0b11720d7cdd50987db&oe=56EA228A
Centrifugal clutch, and clutch selector arm removed from the 70cc, and fitted into the Thump 120 engine:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpa1/v/t1.0-9/11223749_178762779141422_7722764002480764817_n.jpg?oh=a7e3f66a82e502331e6e3c3e74c2f4ec&oe=56EF4657
And fitted up into the bike:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xaf1/v/t1.0-9/12249898_178762805808086_8416049001497629079_n.jpg?oh=29b98501ab316dd4d0951fe65d2925b6&oe=56F176FF
Careful trimming with the hole saw to make room for the bigger carb:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xfa1/v/t1.0-9/11223749_178762892474744_9076742335956323718_n.jpg?oh=9b23dbbfbc7644cff50e7d48489d4c68&oe=56ED6D45
Next job is to wire the thing up, including the electric start Cool
Can't wait to hoon it. Think the Thumpstar 120 lump pushes out about 10bhp.
Just hope the centrifugal clutch can hold down that extra power.
stevo as b4
PostPosted: 20:04 - 18 Nov 2015    Post subject: Reply with quote
I think apart from the anodised blue cover on the head it looks brilliant in the Chaly. Thumbs Up 10bhp should be enough to make the bike really fun to ride and make the mahoosive front brake worth having too.
The 4speed box should be worth having too, and turn it into a damn good cruiser too!
Will you have to change the final drive gearing to suit the big motor too?
binge
Emo Kiddy
PostPosted: 23:45 - 18 Nov 2015    Post subject: Reply with quote
I think when I come to get the engines covers polished I will chuck all the blue bits in for polishing up too.
Final drive, I've put the smaller rear sprocket on anyway, so it should be about right.
Top speed with that small sprocket on used to be nearly 45mph with the 70 engine fitted. So if it does that with the 120 in, I will be happy.
Should be a bit more thumpy now too, with the 70, the exhaust note wasn't very deep, because the stroke was so short on the engine.
Doovy
PostPosted: 10:45 - 19 Nov 2015    Post subject: Reply with quote
Ben, your mechanical knowledge is inferior only to your trolling of the pit bike group Facebook page Laughing
Kris
PostPosted: 11:22 - 19 Nov 2015    Post subject: Reply with quote
What an epic little bike.
I love the speed of your projects Ben! Thumbs Up
www.prisonplanet.com
binge
Emo Kiddy
PostPosted: 14:51 - 19 Nov 2015    Post subject: Reply with quote
That pit bike group really is a mess! Total waste of space cvnts. Haha!
And I don't like to hang around with my bikes because I'm excited about getting out and riding them! Smile
Should have the Chaly wired up over the next few evenings.
PostPosted: 17:36 - 19 Nov 2015    Post subject: Reply with quote
Chuck the blue andosed bits in a weak caustic solution and swill it about a little. Usual precautions about handling caustic apply.
https://i48.photobucket.com/albums/f216/stinkwheel/inbred/1CIMG1433_zpsf63b6fae.jpg
Plus
https://i48.photobucket.com/albums/f216/stinkwheel/inbred/1CIMG1432_zpsd4862a13.jpg
Equalls
https://i48.photobucket.com/albums/f216/stinkwheel/inbred/1CIMG1435_zpsfd71e609.jpg
In about 3 minutes.
binge
Emo Kiddy
PostPosted: 16:59 - 21 Nov 2015    Post subject: Reply with quote
Will have to pick some up next time I'm out and about.
Got the Chaly running today on the new engine.
It's, erm... Fast. So much torque compared to the 50/70cc lump, and it just picks up speed in all 4 gears, effortlessly.
Could probably go bigger on the front sprocket. Currently running the smallest available. I think it's a 12 or 13t.
Might up it to a 16 or 17, and see how it behaves.
It's a bit noisy from the crank cases. I'm wondering whether the centrifugal clutch doesn't sit as far onto the crank as the standard one. It whines like an over-tightened cam-belt does on a car. I'm almost certain that noise was not there before when the engine was in the Thumpstar.
It idles like a dog. I think it needs running up to OORacing once it's all done, for a dyno and tune up.
Fucking excited about getting it MOT'd on Wednesday. I've a feeling it's going to be a bit of a ped-boi muncher.
https://www.facebook.com/Binge.Jammin1987/videos/180159212335112/?l=8329896831950327039
stevo as b4
PostPosted: 20:13 - 21 Nov 2015    Post subject: Reply with quote
Excellent news!Smile
I hope the auto clutch will cope ok with the power of the motor and you can find out why it's whining a touch, hopefully it's nothing serious though!
Your making me want to pull my KMX125 apart to fit the new tuned 200cc top end, that I told myself I wouldn't fit until id tried out the 125 once set up with all the best bolt on parts I can throw at it. Laughing
It does sound nice with a bit of a bark now! Thumbs Up
binge
Emo Kiddy
PostPosted: 19:44 - 22 Nov 2015    Post subject: Reply with quote
I sat and built a wiring loom for it today.
Nice and simple loom. No battery on it at the moment. When I come to wire up the electric start, I think for simplicity, I'm just going to have it on a separate harness, and charge the battery via an optimate, unless there is a fancy way of wiring it all in, as it currently doesn't have an ignition, simply a kill switch.
If I was to introduce a battery, I'm not sure how I would isolate it from the electrics when I turn the engine off. Laughing
Either way, it's done, and ready for an MOT on Wednesday.
Don't half motor along nicely with the 120.
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xap1/v/t1.0-9/12274225_180640822286951_1877990862536627865_n.jpg?oh=58034873ddaa54062057e6b2737cbdc1&oe=56EEB932
mrbox
Wonderwall
PostPosted: 20:20 - 22 Nov 2015    Post subject: Reply with quote
^^looks awesome!
Current bikes: RE Himalayan, Bandit 12, MZ250ES
mysterious_rider
PostPosted: 20:30 - 22 Nov 2015    Post subject: Reply with quote
Its quite smart that.
Does the generator not supply enough juice then? Or have you just hooked it straight to lights? Just keep it kick start if thats the case.
I bought a midi moto chopper thing a few weeks ago. Sadly the forks etc are shite and impossible to get parts for. Id like to do similar and get it road regd for the girlfriend.
Keep up the good work.
KAWASAKIIIII
The last post was made 10 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 140.58 Kb
