| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
 Posted: 10:55 - 17 Nov 2015 Post subject: Little bleeder. |
Do they work as described? Only cost £4.99 at the moment and come with hose which I need anyway.
Also I have never bled a bike with two calipers up front is it any different than just a single? |
| c_dug |
 c_dug Super Spammer
| monkeybiker |
 monkeybiker World Chat Champion
| SQL |
 SQL World Chat Champion
| Beehive Bedlam |
| Raffles |
 Raffles World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
| Beehive Bedlam |
| Fizzer Thou |
 Posted: 14:47 - 17 Nov 2015 Post subject: |
I bought the right size clear plastic hose from B&Q.It comes off a big reel so it straightens easily.
The best way to connect to the bleed nipple is to use some rubber hose,about 2" long,that is a good fit over the plastic hose and on the bleed nipple.Then,when you undo the bleeder,the rubber hose distorts slightly but will not come off,unlike if you have the plastic hose directly onto the bleeder  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| evilzed |
 evilzed Scooby Slapper
| MCN |
 MCN Super Spammer
 Posted: 23:18 - 17 Nov 2015 Post subject: |
They will work as long as you can get enough fluid to move from the master to the caliper.
I have always found the most common issue with motorcycle brake bleeding is that the master cylinder puts out a tiny amount of fluid and take for ever to bleed because of this.
Most success I have had is using a pressure bleeding system. It is the most positive way to ensure you get fluid moving with minimal phaph. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| kramdra |
 kramdra World Chat Champion
 Posted: 23:52 - 17 Nov 2015 Post subject: |
Reverse bleeding with a syringe is quicker and much easier.
Good cheap hose can be purchased from halfords, 2.4meters for a couple quid. Its also very good as air hose. The thicker stuff is good enough as fuel hose on a carb bike  |
| MCN |
 MCN Super Spammer
| Skudd |
 Skudd Super Spammer
| MCN |
 MCN Super Spammer
 Posted: 13:30 - 18 Nov 2015 Post subject: |
| c_dug |
 c_dug Super Spammer
| Rogerborg |
 Rogerborg nimbA
| Fizzer Thou |
 Posted: 14:43 - 18 Nov 2015 Post subject: |
I helped a friend earlier this year to replace old brake lines with some nice new braided hose lines,so the brake system was completely dry.Within ten minutes we were able to bleed the system and get satisfactory pressure,without the need for syringes or anything else apart from an old pickle jar to take the overspill.I have a Mityvac pump that I have used in the past on car hydraulic clutch systems,but I have never felt the need to use this device on motorbike brake systems.
What I would say is that many home mechanics have their own way of doing things and if that works for you then there is no need to change  ____________________ Just talk bikes.What else is there?
| MCN |
 MCN Super Spammer
| dydey90 |
 dydey90 World Chat Champion
| kramdra |
 Posted: 01:19 - 19 Nov 2015 Post subject: |
Filling and bleeding brakes should be done in a specific order or it will be a lot of effort. Does not matter which way you do it, air will want to collect at the master cylinder banjo, this is where most bleeding should be done, with calliper nipples just to check. I can do any dual calliper system in about 2 minutes filled and bled perfectly first time. Do in order:
Filling:
1) Remove bleed nipples and apply fresh PTFE tape. Refit. Master cylinder banjo should be clean, undo, fit fresh washers if needed. Do not fully tighten.
2) Suck any fluid from res and discard. Make sure res is clean. I use an old syringe for this. The one I use for filling is always stored in a sealed bag.
3) fill a clean syringe with 50ml fluid, use it to fill one calliper. Any time a nipple is open, you must apply presure and have fluid moving.
4) close nipple, pause and suck excess out res as it gets full and repeat until clean fluid and no bubbles. Use all of the 50ml fluid.
5) repeat other side using 50ml fluid.
Res should now be full, with clean new fluid and no dirt in the lines and very little air in the system mostly around MC banjo.
Bleeding:
1) With syringe on the same calliper and a good amount of fluid, apply syringe pressure, open calliper nipple, crack open the master cylinder banjo for couple seconds, close both before syringe empty and always with pressure. Have kitchen tissue around banjo to catch any fluid.
2) Without syringe, use master cylinder to bleed at the master cylinder banjo again, then repeat calliper bleed nipples. One squeeze of lever should be enough.
3) Tighten mc banjo to 30-34nm. Top up res.
If you use up more than 150ml fluid, your doing it wrong. If it takes over 5 mins, your doing it wrong.
60ml syringe is the correct size. 100ml holds too much and is hard to push with one hand, and cost a lot more. |
| Beehive Bedlam |
 Posted: 17:11 - 20 Nov 2015 Post subject: |
It has arrived. The tube isn't coiled like some arm chair expert critiques waffled about.
https://i.imgur.com/DFFAuNv.jpg |
| Ste |
 Ste Not Work Safe
 Posted: 17:20 - 20 Nov 2015 Post subject: |
Reverse bleeding is the way to go.
You can get plastic syringes from eBay and you can try asking in a local pharmacy on the off chance they'll sell you one.
However they will almost certainly refuse to sell you a syringe and instead they'll offer you some leaflets for a needle exchange.  |
| MCN |
 MCN Super Spammer
| MCN |
 MCN Super Spammer
 Posted: 18:23 - 20 Nov 2015 Post subject: |
IFTFY.
If you ask for help on a public forum expect the best with the worst. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 10 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
