Iphone 5 battery life
.Bishbash.
PostPosted: 11:17 - 18 Nov 2015    Post subject: Iphone 5 battery life Reply with quote
So, got myself an iPhone 5 the other month, had an iPhone 4 before and the battery was pretty good on that. This 5 however is so weird and need to know if it's normal, or is it my battery is fooked?
Battery goes down pretty quickly, if I watch videos, the life will last about 20/30 mins, sat nav about 30 mins. On 3 occasions, the battery has jumped from 30-40% to dead in 2-3 seconds.
Thoughts?
Current bike - GSX-R1000 k8
dydey90
PostPosted: 11:27 - 18 Nov 2015    Post subject: Reply with quote
I used to have one and the battery would generally last all day if I wasn't constantly using it. Games, videos and sat nav will drain battery faster but not THAT fast. Have a look at getting a new battery. If you're not confident installing it yourself, there are loads of independent Apple repair shops around that charge a fraction of the price. There's a good one in Leeds called iPatch for example.
supZ
PostPosted: 11:49 - 18 Nov 2015    Post subject: Reply with quote
batteries knackered. is it a new one?
my 5 started dying after 20mins or so, basically had to keep it on charge all the time or it would die when i wanted it.
bought one of those cheapo replacement kits off ebay, swapped the battery and now i can go 2/3 days between charges using it pretty frequently. ipod during the day, some browsing when on the throne, kodi remote in the evening..
CBR954RR - Daily toy
CBR600RR - Trackbike
.Bishbash.
PostPosted: 12:06 - 18 Nov 2015    Post subject: Reply with quote
2/3 days.... Shocked Shocked Shocked I'd say the battery is the original comparing to this.
Perfect, thanks chaps, had a feeling the battery was kaput. To eBay I go Thumbs Up Wink
Rogue_Shadow
PostPosted: 14:43 - 18 Nov 2015    Post subject: Reply with quote
2/3 days Shocked
I charge my 5S pretty much every night, by which point it will be around the 30-40% mark & I don't use it a lot throughout the day.
I Miss my iPhone 4, if I didn't start having signal issues I'd swap back in a heartbeat Crying or Very sad
CaNsA
PostPosted: 15:44 - 18 Nov 2015    Post subject: Reply with quote
Rogue_Shadow wrote:
2/3 days Shocked
On my S5 there is an option to turn off specified apps after 10mins, I cant remember where though :/
But if you find it and add stuff like facebook, news apps etc etc your battery will last much longer.
I get 2 or 3 days out of mine from a full charge.
Quote Me Happy
PostPosted: 16:02 - 18 Nov 2015    Post subject: Reply with quote
https://www.apple.com/uk/support/iphone5-battery/
dydey90
PostPosted: 00:08 - 19 Nov 2015    Post subject: Reply with quote
Since posting this morning, I foolishly used my phone as a torch in the garage. The garage has a hard, concrete floor.
Im off to iPatch for a new screen tomorrow.
.Bishbash.
PostPosted: 10:57 - 19 Nov 2015    Post subject: Reply with quote
Ouch, bad luck dude, May I suggest a rubber case too? These rubber cases saved my iphone 4 on many occasion.
The serial number you entered is not eligible under this program because either:
- It's not one of the serial numbers in the affected range
- Our records show that your battery has already been replaced. If you paid for a battery replacement service,
check with Apple to see if you are eligible for a refund.
Worth a try I guess. Crying or Very sad
supZ
PostPosted: 11:30 - 19 Nov 2015    Post subject: Reply with quote
don't leave your phone on charge over night if you can help it.
in other words.. don't leave it charging when it doesn't need to.
now I've swapped batteries I'm a bit more careful and only charge it during the day at work just to top it off and unplug it once it's 100% again.
leaving your phone charger plugged in when it doesn't need to be is the primary cause of 'battery knackerism'
.Bishbash.
PostPosted: 12:35 - 19 Nov 2015    Post subject: Reply with quote
/\ Yup, this, same goes for laptops too, well, most things with batteries I guess.
bladerunner
PostPosted: 10:32 - 20 Nov 2015    Post subject: Reply with quote
Sounds like the battery needs calibrating as I've seen this happen a few times with both apple and android phones. The fact its dropping by 30% is typical. Run your phone flat till it turns off then charge totally before turning the phone back on. You might have to do it a couple of times but it'll reset your battery indicator to show correctly. It fixed issues with an iPhone 5 that was thought to be shot back to normal. Lipo battery usage indicators need it doing periodicly if its a phone or any other equipment as it'll take into account the battery condition over time. Failing that look at apps that cause drain and finally new battery time but the fact it drops in a big step hints at the first step being needed.
Serendipity
PostPosted: 13:35 - 22 Nov 2015    Post subject: Reply with quote
My 5 battery was dying a similar death, although maybe not as severe. Running down fast when used and jumping from 39% to 8% in an instant.
I tried all the usual suggestions for resetting counters etc and got a few more months out of it, but eventually gave in a bought a new battery.
I picked one up from these guys: https://www.appleipodparts.com/ simply based on the fact that I liked their YouTube vids of self-repairs. Also picked up a couple of the tools from their site too.
Since then I’ve also replaced the home button on by wife’s 4 and the power button and battery on my son’s 3GS.
My tips are use a decent desk lamp and try to keep track of all the tiny screws with a marked tray of some kind. Also if you need to heat parts to release glue pads I found that reusable chemical hand warmers work well. You know, the ones with the little clicker disk in them. Set a couple off, stick the parts in between them, wrap in a cloth and leave for 20 mins for the heat to soak right through. Makes releasing screens and batteries much easier.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
.Bishbash.
PostPosted: 11:07 - 23 Nov 2015    Post subject: Reply with quote
Cheers dude, new battery is already on order and looking forward to using these XL hands I inherited to try picking up those screws you speak of.
The last post was made 10 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 82.82 Kb
