HDMI and USB switch help
DrSnoosnoo
PostPosted: 12:41 - 18 Nov 2015    Post subject: HDMI and USB switch help Reply with quote
Hello mighty Geeks of BCF. I'm due to put my TV onto a wall mount and I've had a thought that it'd be much better to have little hubs for the hdmi and usb devices so only two cables go up to the tv. This way it'd look much neater I think and make the ports easier to access.
Thus, I searched a bit on Google and found that a powered hdmi hub is the best option and I found a cheapy on eBay here I need/want it to allow full HD pass through and for 3D signals to go through from my 3D blurays through the PlayStation. Would this be up to the task?
Similarly, with regard to a USB hub, I found this which is a powered unit again and claims to support USB 3.0.
Any hints, tips and recommendations would be welcome.
Jayy
Mr. Ponzi
PostPosted: 13:10 - 18 Nov 2015    Post subject: Reply with quote
Ok... you will need a high speed HDMI cable so that you can transmit up to 4k resolution and 120hz for 3D (60hz per eye).
https://www.amazon.co.uk/AmazonBasics-High-Speed-Supports-Ethernet-Return-Black/dp/B00NH12LCY
Something like that as there are all different models of HDMI cable, you want 1.4 spec.
Equally, you'd need to make sure the box/switch does the same job which from reading it:-
Support 1080p Full HD 3D and 12-bit deep colour , retaining the crispy clear images.
High performance up to 2.5Gbps.
2.5gb/s = 250mb/s
Most blurays have a VBR (variable bitrate) of anywhere from 15 to 40 mb/s so it will be able to handle all that.
DrSnoosnoo
PostPosted: 13:26 - 18 Nov 2015    Post subject: Reply with quote
Very helpful Jayy thanks. I've just used HDMIs from the pounds hop and the like and they've always seemed OK to my non professional eyes but I'll take your advice on board and upgrade my cabling too.
Any opinion on the usb hub or should that simply work?
Cheers Karma
Jayy
Mr. Ponzi
PostPosted: 13:35 - 18 Nov 2015    Post subject: Reply with quote
Is your TV 4K?
The new HDMI 2.0 specification supports all kinds of new resolutions...
https://www.hdmi.org/manufacturer/hdmi_2_0/
https://www.hdmi.org/manufacturer/hdmi_1_4/
DrSnoosnoo
PostPosted: 13:51 - 18 Nov 2015    Post subject: Reply with quote
No my TV is a 3D 1080p one. None of that 4k madness for me yet. Give me a few years ha
t121anf
PostPosted: 14:09 - 18 Nov 2015    Post subject: Reply with quote
Not the cheapest and plenty of clones about but this has worked flawlessly for me.
https://www.amazon.co.uk/gp/product/B001DAVA64?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
Didn't like a particular cable but that was it.
DrSnoosnoo
PostPosted: 14:41 - 18 Nov 2015    Post subject: Reply with quote
I've pressed fire on each of those hubs so I'll make sure to post and let you know how they work. Pretty much, if it can play 3D through the hdmi one from the PlayStation and a 3D movie off a hard drive through the usb hub, I'll be happy
Jayy
Mr. Ponzi
PostPosted: 14:43 - 18 Nov 2015    Post subject: Reply with quote
Good page here on understanding HDMI specs
https://www.audioholics.com/hdtv-formats/understanding-difference-hdmi-versions
panrider_uk
PostPosted: 16:26 - 18 Nov 2015    Post subject: Reply with quote
Jayy wrote:
2.5gb/s = 250mb/s
I think you're mixing bits and bytes there.
0.25gb/s = 250mb/s
Jayy
Mr. Ponzi
PostPosted: 20:52 - 18 Nov 2015    Post subject: Reply with quote
Maths isn't my strong point but I always took it as...
100 mbit / s = 10mbyte / s
Like my 24mbit/s ADSL downloads at a 2.4mb/s rate
So 2.5gbit/s would equal = 250mbyte / s
That was my logic, unless my logic is flawed, which it usually is.
Jayy
Mr. Ponzi
PostPosted: 20:53 - 18 Nov 2015    Post subject: Reply with quote
panrider_uk wrote:
Jayy wrote:
2.5gb/s = 250mb/s
0.25gb/s = 250mb/s
It doesn't say 0.25gb/s it says 2.5gp/s
panrider_uk
PostPosted: 22:12 - 18 Nov 2015    Post subject: Reply with quote
It does but 250mb = 0.25gb, not 2.5gb
Jayy
Mr. Ponzi
PostPosted: 00:37 - 19 Nov 2015    Post subject: Reply with quote
I are a dunce at maths Very Happy
panrider_uk
PostPosted: 00:54 - 19 Nov 2015    Post subject: Reply with quote
Very Happy
DrSnoosnoo
PostPosted: 10:08 - 19 Nov 2015    Post subject: Reply with quote
But the little box should still be alright though?? Ooohh if I've wasted a fiver because of a man on the Internet giving me advice I'll... continue living normally.
Jayy
Mr. Ponzi
PostPosted: 13:08 - 19 Nov 2015    Post subject: Reply with quote
The box is fine mate, I was actually correct just the logic in which I worked it out was wrong. Thumbs Up Thumbs Up Thumbs Up
VBR on Blurays is anything from 10 - 40mb/s - That box is fine (250mb/s), if you got the right HDMI cable then all is good.
DrSnoosnoo
PostPosted: 23:30 - 20 Nov 2015    Post subject: Reply with quote
Update for anyone interested.
Items work well. Auto switching of the hdmi works and the usb hub works and allows me to see both my external hard drive and my drift camera through the same port.
Thanks for the advice Jayy
Jayy
Mr. Ponzi
PostPosted: 02:13 - 21 Nov 2015    Post subject: Reply with quote
Sweet Thumbs Up
The last post was made 10 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 94.46 Kb
