Handy tip if you're stuck...
PostPosted: 17:17 - 21 Nov 2015    Post subject: Handy tip if you're stuck... Reply with quote
...without a big enough spanner.
https://www.facebook.com/3dfirstaid/videos/1171130429564063/
WD Forte
PostPosted: 17:32 - 21 Nov 2015    Post subject: Reply with quote
Ingenious for sure but I doubt it would work that well on a tight nut and bolt or one that had restricted access.
Handy for bolts self tapped into chipboard though
lots of them on my old bike Laughing
bikers smell of wee
MCN
PostPosted: 23:39 - 21 Nov 2015    Post subject: Reply with quote
Really useful Ghetto Tool for when bolts are finger tight. Thumbs Up
Very Happy
And Servico Manuel made a video of it. ROgarageFL. Smile
Taught2BCauti...
PostPosted: 10:40 - 22 Nov 2015    Post subject: Reply with quote
When I need to undo a bolt, I simply get the correct tool Laughing
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
monkeybiker
PostPosted: 11:37 - 22 Nov 2015    Post subject: Reply with quote
Are spanners that hard to find?
MCN
PostPosted: 15:46 - 22 Nov 2015    Post subject: Reply with quote
Yeah but that's not adventurous enough.
One must be a bit Bear Grylls these days to get that full-on 'satisfaction quotient'.
Very Happy
monkeybiker
PostPosted: 16:31 - 23 Nov 2015    Post subject: Reply with quote
When would you be in a situation when you wouldn't have a spanner but you would have a threaded bar?
Top tip? More like top bullshit Middle Finger
Suntan Sid
PostPosted: 19:23 - 23 Nov 2015    Post subject: Reply with quote
Because I've got time on my hands, I thought I'd actually try this, before pronouncing on it!
I tightened an 8mm bolt into a blind hole, on an old engine casing, using a ratchet wrench, I tigtened it as much as I could without bursting a blood vessel, so reasonably tight!
I put the 2 nuts onto a 150mm long, 8mm bolt, without the use of a spanner, and it worked, no problem at all with no skinned knuckles! I didn't use the spanner for extra leverage, as per the video!
I then tried to undo the fork pinch bolts on one of my bikes, they're done up to 23NM, it didn't work. However, I would say a lot of the problem here was not being able to excert any downward presssure to stop the the makeshift spanner slipping off the nut!
I also think the reason it worked in my first test was the bolt I used was new, so all the edges were sharp, unlike the old pinch bolts!
It is not difficult to get the 2 nuts to clamp on the bolt, without using a spanner!
It's just a trick really, if you were stuck in the middle of nowhere with a snapped spanner, the chances are you woudln't have 2 spare nuts and a bolt anyway!
The last post was made 10 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 61.28 Kb
