| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 17:17 - 21 Nov 2015 Post subject: Handy tip if you're stuck... |
...without a big enough spanner.
https://www.facebook.com/3dfirstaid/videos/1171130429564063/ ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| WD Forte |
 WD Forte World Chat Champion
 Posted: 17:32 - 21 Nov 2015 Post subject: |
Ingenious for sure but I doubt it would work that well on a tight nut and bolt or one that had restricted access.
Handy for bolts self tapped into chipboard though
lots of them on my old bike  ____________________ bikers smell of wee |
| MCN |
 MCN Super Spammer
 Posted: 23:39 - 21 Nov 2015 Post subject: |
Really useful Ghetto Tool for when bolts are finger tight.
And Servico Manuel made a video of it. ROgarageFL.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Taught2BCauti... |
 Taught2BCauti... World Chat Champion
 Posted: 10:40 - 22 Nov 2015 Post subject: |
When I need to undo a bolt, I simply get the correct tool  ____________________ Honda Varadero XL125(V8)
www.TheFutureIsHere.eu |
| monkeybiker |
 monkeybiker World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 12:09 - 22 Nov 2015 Post subject: |
It's a neat little idea....but I bet you he used a spanner, or two, to tighten up the top nut & bolt  ____________________ Space Is Deep |
| MCN |
 MCN Super Spammer
| monkeybiker |
 Posted: 16:31 - 23 Nov 2015 Post subject: |
When would you be in a situation when you wouldn't have a spanner but you would have a threaded bar?
Top tip? More like top bullshit  |
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 19:23 - 23 Nov 2015 Post subject: |
Because I've got time on my hands, I thought I'd actually try this, before pronouncing on it!
I tightened an 8mm bolt into a blind hole, on an old engine casing, using a ratchet wrench, I tigtened it as much as I could without bursting a blood vessel, so reasonably tight!
I put the 2 nuts onto a 150mm long, 8mm bolt, without the use of a spanner, and it worked, no problem at all with no skinned knuckles! I didn't use the spanner for extra leverage, as per the video!
I then tried to undo the fork pinch bolts on one of my bikes, they're done up to 23NM, it didn't work. However, I would say a lot of the problem here was not being able to excert any downward presssure to stop the the makeshift spanner slipping off the nut!
I also think the reason it worked in my first test was the bolt I used was new, so all the edges were sharp, unlike the old pinch bolts!
It is not difficult to get the 2 nuts to clamp on the bolt, without using a spanner!
It's just a trick really, if you were stuck in the middle of nowhere with a snapped spanner, the chances are you woudln't have 2 spare nuts and a bolt anyway! ____________________ "Everybody needs money, that's why they call it money!"  |
The last post was made 10 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
