| JackDanger |
 JackDanger Two Stroke Sniffer
| hmmmnz |
 hmmmnz Super Spammer
| Evil Hans |
 Evil Hans World Chat Champion
| Robby |
 Robby Dirty Old Man
| GaryJM |
 GaryJM Borekit Bruiser
| JackDanger |
| Vincent |
 Vincent Banned
| JackDanger |
| Vincent |
 Vincent Banned
| JackDanger |
| JackDanger |
| hmmmnz |
| temeluchus |
| JackDanger |
| zark |
 zark Trackday Trickster
| JackDanger |
| zark |
 Posted: 23:12 - 22 Nov 2015 Post subject: |
If it helps... From here
Fault codes are stored on the ECU , these will be shown via the engine fault light on the dash board
as a series of flashes of the light .
The engine management light will come on for 3 secs every time you start the bike , if the light does not come on replace the bulb at rear of clocks .
Codes are all 2 digit numbers , the first number will be read by long flashes of the light , the second
number of the code with be in short flashes of the light .
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction ____________________ CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou... |
| JackDanger |
| DrSnoosnoo |
 DrSnoosnoo World Chat Champion
| JackDanger |
| DrSnoosnoo |
The last post was made 10 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
