YBR125. Engine runs in neutral but cuts out with any gas.
JackDanger
PostPosted: 02:47 - 22 Nov 2015    Post subject: YBR125. Engine runs in neutral but cuts out with any gas. Reply with quote
Pretty much the title. I was on my way back from the shops and I had strapped my shopping to my fuel tank and I think i snagged something with my mesh bungee holder thing. Long story short the bike jsut starts stuttering a few minutes out and then the engine dies. It seems like it will run but when I give it any throttle for more than a few seconds the engine just stutters and dies. I've read up and I think its got to be either my air intake (is that a thing???) or my fuel line. Is there anything I could have snagged with my bungees around the side of the tank? Need my bike to commute so I'm going to get the old tool box out tomorrow and try to fix it. Any ideas/suggestions would be great.
Thanks in advance BCF.
hmmmnz
PostPosted: 09:42 - 22 Nov 2015    Post subject: Reply with quote
edit: i didnt correctly read the post before replying.
the humans are dead
I kick arse for the lord
Evil Hans
PostPosted: 10:06 - 22 Nov 2015    Post subject: Reply with quote
Fuel line crushed or kinked, or fuel tap turned nearly but not quite off?
Air leak? Check the big rubber hose between the airbox and the carb.
Ht lead loose or damaged?
Filler vent blocked? Try running with the fuel cap off.
Robby
Dirty Old Man
PostPosted: 12:23 - 22 Nov 2015    Post subject: Reply with quote
If you strapped your shopping over the fuel tank vent hole then it could cause a problem. It needs to be able to suck in air.
Try it again without any thing covering the fuel filler.
GaryJM
PostPosted: 12:44 - 22 Nov 2015    Post subject: Reply with quote
If it has a fuel tap check that it is in the right position.
Again as others have said check you are blocking the fuel vent or catching the fuel line.
To prevent this in the future look at a tank bag or top box.
Even a cargo net on the rear seat would be better than bungeeing onto the fuel tank.
Top boxes come in a variety of sizes and should be easy to fix on the back of the bike as IIRC the YBR all read has a rear carrying frame.
So long and Thanks for all the fish !
Triumph Sprint GT SE.
JackDanger
PostPosted: 13:11 - 22 Nov 2015    Post subject: Reply with quote
Thanks for the replies guys. I'll get back to you with how I get on. Looks cold as bawls outside, not excited to do this today! =(
JackDanger
PostPosted: 13:50 - 22 Nov 2015    Post subject: Reply with quote
Vincent wrote:
If it's a vacuum tap, check you havn't pulled off the vacuum pipe that goes from the tap to the carb.
It's actually fuel injected not carbed. Anything specific I should be looking for?
JackDanger
PostPosted: 16:27 - 22 Nov 2015    Post subject: Reply with quote
Right I've cleaned out the air filter and that's definitely not the problem. The fuel line from the tank doesn't appear to be snagged or anything, i checked the fuel going into the FI and its got fuel in it. However when I checked the tank even though it says I have like a 1/4 tank of fuel it feels pretty empty. Going to try getting some fuel in it and see if its just the fuel gage that's not showing the right level.
JackDanger
PostPosted: 16:32 - 22 Nov 2015    Post subject: Reply with quote
Not sure if this will help but the fuel injector light is flicking when its trying to turn over and the fuel pump is definitely running because you can hear it pumping.
https://www.youtube.com/watch?v=KkNGbIr4VfQ&feature=youtu.be
hmmmnz
PostPosted: 21:13 - 22 Nov 2015    Post subject: Reply with quote
are you in neutral?? the lights not coming on.
has the bike always turned over so slow? it seems like the battery is pretty flat
the humans are dead
temeluchus
PostPosted: 21:16 - 22 Nov 2015    Post subject: Reply with quote
yup battery seems pretty tired.
JackDanger
PostPosted: 21:20 - 22 Nov 2015    Post subject: Reply with quote
Yeah to be fair the battery is now sat on charge in my kitchen but the problem was happening way before I drained the battery trying to get it to turn over. My neutral light is a bit temperamental. Perhaps the video wasn't particularly helpful. My bad. It doesn't normally turn over first time.
zark
PostPosted: 21:28 - 22 Nov 2015    Post subject: Reply with quote
Does the yellow light flash an error code after attempting to start it? (Long and short flashes)
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
JackDanger
PostPosted: 21:43 - 22 Nov 2015    Post subject: Reply with quote
Nah the yellow light is the fuel injection primer. I appreciate that it looks like it's flashing but its because I'm mashing the starter.
zark
PostPosted: 23:12 - 22 Nov 2015    Post subject: Reply with quote
If it helps... From here
Fault codes are stored on the ECU , these will be shown via the engine fault light on the dash board
as a series of flashes of the light .
The engine management light will come on for 3 secs every time you start the bike , if the light does not come on replace the bulb at rear of clocks .
Codes are all 2 digit numbers , the first number will be read by long flashes of the light , the second
number of the code with be in short flashes of the light .
Fault code 12 - Crankshaft position sensor
Fault code 13 - Intake air pressure sensor
Fault code 14 - Intake air pressure sensor
Fault code 15 - Throttle position sensor
Fault code 16 - TPS
Fault code 19 - No signal from ignition to ecu
Fault code 22 - Intake air temp sensor
Fault code 28 - Engine temp sensor
Fault code 30 - Tip over sensor
Fault code 33 - Igniton coil
Fault code 39 - Fuel injector
Fault code 41 - Tip over sensor
Fault code 44 - Read write error ECU
Fault code 46 - Power supply error to FI system
Fault code 50 - Ecu malfunction
JackDanger
PostPosted: 17:27 - 23 Nov 2015    Post subject: Reply with quote
Right I've charged the battery all night and tried it again this morning. It is firing and turning over but its still spluttering a bit. Really have to give it a lot of gas to turn over. Went out for a ride though and it was OK so I dunno, maybe a bit of gunk in the bottom of my tank. Next thing I want to do is change my fuel filter. Anyway I can get to work again so thanks for the suggestions! =)
DrSnoosnoo
PostPosted: 17:36 - 23 Nov 2015    Post subject: Reply with quote
Perhaps it was sputtering due to a slightly blocked injector? If the tank was almost empty, that's where all the crap ends up so could have been sucked in. This may not be beneficial but maybe think of putting an inline filter between tank and fuel pump to prevent that particular issue re/occurring.
JackDanger
PostPosted: 17:41 - 23 Nov 2015    Post subject: Reply with quote
Meh I might. I'm hoping to get my tests done soon (passed my theory last week but I'm fucking moving house this week - grr) so I'll probs end up selling the bike soon enough anyway.
DrSnoosnoo
PostPosted: 10:32 - 24 Nov 2015    Post subject: Reply with quote
...but I'm fucking moving house this week - grr
I've just moved last week so I'm living in a jungle of boxes and bags I dem feels bro Thumbs Up
The last post was made 10 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 4.92 - MySQL Queries: 13 - Page Size: 113.26 Kb
