front sprocket security pin?? removal help please!!
vladthetodge
PostPosted: 16:04 - 22 Nov 2015    Post subject: front sprocket security pin?? removal help please!! Reply with quote
HI all.
So, went to remove front sprocket on my daelim vjf125. the fixing plate, instead of having two bolts, has one bolt, and some sort of security tab. It seems to have no way of removing without drillling out, as i asumme its threaded in the same way as the other bolt is.
Anyone p[lease shed some light on how to get the bugger out??
i know that the chain has tight spots btw, and its filthy!!! im waiting to get the sprocket off to replace both sprockets and chain together.
heres a link to a pic too, as i suck at attaching photos lol!!
Thanks all, in advance.
https://s1123.photobucket.com/user/vladthetodge/media/Mobile%20Uploads/DSC_0239.jpg.html?o=0
PostPosted: 16:07 - 22 Nov 2015    Post subject: Reply with quote
Doesn't seem useful, or even likely. How would they fit the pin then install the retainer? Try removing the one bolt and see if the retainer will turn to align the splines.
vladthetodge
PostPosted: 18:21 - 22 Nov 2015    Post subject: Reply with quote
Tried that. It won't budge. The security bolt goes through the retainer. Was actually thinking of using a bolt remover bit on a drill and trying to get it out that way after a little heat application.
PostPosted: 10:07 - 23 Nov 2015    Post subject: Reply with quote
I've seen "anti-tamper" bollocks on a Hyosung, but that takes the biscuit. Whyyyyy? You so cray-cray, Korea. Rolling Eyes
I'd assume that's a shear-bolt. You might have luck getting an Irwin bolt grip to bite on it.
Failing that, weld a nut on it?
A local garage would likely have it off in seconds.
PostPosted: 10:47 - 23 Nov 2015    Post subject: Reply with quote
I'm trying to imagine how they would fit it. Pics needed.
PostPosted: 11:09 - 23 Nov 2015    Post subject: Reply with quote
Just a shear bolt, innit?
https://www.insight-security.com/images/products/sf%20sbbh825.jpg
PostPosted: 11:14 - 23 Nov 2015    Post subject: Re: front sprocket security pin?? removal help please!! Reply with quote
I can't work out what that is suppose to do Neutral
PostPosted: 12:42 - 23 Nov 2015    Post subject: Reply with quote
Shear...
Tighten it up, the hex head snaps off leaving a rounded dome. It's likely just a regular bolt rather than a pin under the remaining head though; if you can get a grip on it it should rotate out.
Looks like the idea is simply to stop Joe Owner from changing the sprocket. I believe that Korea has or had some legislation about not tampering with the power train. The Hyosung I had a go at had adamantite rivets holding the end can on, I dulled several unobtanium bits drilling them out.
Look forward to similar anti-tamper insanity on A1 and A2 bikes sold in Europe from next year, although I don't know what details (if any) were settled on.
stirlinggaz
PostPosted: 19:57 - 23 Nov 2015    Post subject: Reply with quote
hi,
seen plenty of these security/shear bolts on ignition barrels before but never on a front sprocket....
easy enough to remove diy though.
cut a slot in the domed head with a hacksaw or preferably a dremel.
a nice deep clean slot helps Smile
then just use an impact driver or large screwdriver to undo the nasty "bolt".
then take it outside & kill it with fire, then bury it in concrete at the bottom of your garden Smile
& then replace it with a standard bolt.
cheers,
GAZ
monkeybiker
PostPosted: 20:10 - 23 Nov 2015    Post subject: Reply with quote
Can you take a picture of this bolt?
PostPosted: 20:32 - 23 Nov 2015    Post subject: Reply with quote
https://i1123.photobucket.com/albums/l542/vladthetodge/Mobile%20Uploads/DSC_0239.jpg
A sheared shear bolt then a standard bolt by the look of it.
Or a mangled dome headed allen bolt?
bugeye_bob
PostPosted: 20:47 - 23 Nov 2015    Post subject: Reply with quote
certainly a shear bolt.
Fisty
PostPosted: 20:50 - 23 Nov 2015    Post subject: Reply with quote
Vincent wrote:
I'd imagine the makers had complaints about the sprockets coming loose. I'd grind it off.
And how do you figure a shear bolt would help?
It is indeed a shear bolt, some Korean/chinese takeaway bikes have them fitted for the reasons Roger stated, I encountered one a couple of years ago.
We ground a couple of flats on it and wound it out with mole grips. Do it before you remove the chain, make life easier.
Fatter and faster than Fret
PostPosted: 20:54 - 23 Nov 2015    Post subject: Re: front sprocket security pin?? removal help please!! Reply with quote
Does look like a shear bolt.
One step back from a welded sprocket.
Wait a minute, I know a user on here who used to own a Daelim.... Thinking
PostPosted: 20:55 - 23 Nov 2015    Post subject: Reply with quote
Vincent wrote:
I'd grind it off.
I wouldn't. Grinding the head off will leave you with a stub still bolted into the sprocket and flush with the retainer that'll still stop it rotating and coming off the spline.
What Gaz / Fisty said / Irwins / grips / weld a nut on / (reverse) drill and use a big bolt extractor / take it down to the local independent - they might take it out in return for the laugh it'll give them. Wink
yen_powell
PostPosted: 21:41 - 23 Nov 2015    Post subject: Reply with quote
The bikes I've had with two bolts holding the front sprockets on have always been very very easy to undo (unlike the single bolt variety which have sometimes been bastards).
Might be worth just trying the punch and hammer trick in an undoing direction before breaking out the heavy tools. Put the bike in gear and get someone to put pressure on the sprocket to take out any play in the transmission first.
XT1200Z and a DR350 in bits
PostPosted: 21:43 - 23 Nov 2015    Post subject: Reply with quote
Rogerborg wrote:
Shear...
The plate not the bolt...
Raffles
PostPosted: 21:53 - 23 Nov 2015    Post subject: Re: front sprocket security pin?? removal help please!! Reply with quote
Deja vu?
Raffles
PostPosted: 22:35 - 23 Nov 2015    Post subject: Reply with quote
Vincent wrote:
The plate goes on over the splines than spins 180 degrees on a groove in the shaft so the splines no longer line up and then is tightened down to stop the sprocket drifting out on the shaft.
If the plate was spun 180 degrees, the sprocket would be free to do whatever it pleased.
The last post was made 10 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.07 - MySQL Queries: 13 - Page Size: 133.62 Kb
