| AzzA1990 |
 AzzA1990 Nova Slayer
 Posted: 17:34 - 22 Nov 2015 Post subject: Adjusting float height on Yamaha RXS100 |
Hi all my RXS leaks fuel from the overflow pipe when the fuel tap is left on, i took the carb off to check inside and surprisingly it's very clean in there however the float looked as if it's not sitting quite right (i think the fuel in the float bowl fills up too much before the float gets a chance to shut off the fuel supply) i was wondering how you actually adjust the float height? from what i could make out it looks as if you need to ever so slightly bend the tag on the float that pushes on the needle valve that shuts off the supply of fuel to the float bowl, is this correct? i didn't want to go ahead and do it if it's not the right way of doing hence why I'm asking on her first!
Appreciate any advice! Thanks in advance |
| wodge |
 wodge Nitrous Nuisance
| AzzA1990 |
| john24ssj |
 john24ssj Trackday Trickster
| AzzA1990 |
 Posted: 13:11 - 23 Nov 2015 Post subject: |
Does anyone know where i measure the float height from? I've done some research and found that the float height needs to be 21mm but where do i take this measurement from? I have a digital vernier calliper to take the measurement with but I'm unsure of the where about's I'm meant to be measuring  |
| andys675 |
 andys675 World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 19:20 - 23 Nov 2015 Post subject: |
I don't recall ever using measured settings but I guess it's the efficient way to go...if the carb isn't getting enough fuel I just bend the tab back in small incerments until it's right and reverse if the carb is flooding. If you've got the carb off, you can blow into the fuel pipe while closing the floats by hand to get an idea how close they are/aren't....just don't blow too hard and with no spittle  ____________________ Space Is Deep |
| wodge |
| AzzA1990 |
| andys675 |
| wodge |
The last post was made 10 years, 326 days ago. Instead of replying here, would creating a new thread be more useful? |
