Engine oil everywhere.. What's the damage?
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Tomahawk
PostPosted: 18:04 - 22 Nov 2015    Post subject: Engine oil everywhere.. What's the damage? Reply with quote
I just lowsided going around a roundabout on a wet road.
It wasn't terribly high speed, only about 30 mph -- mainly due to leaning too much on a slippery road.
Anyway, besides the body damage, I seem to have lost a huge amount of engine oil as the bike was sitting there in a huge puddle of oil. What could have caused this? Does this indicate damage to the engine?
EDIT: I added pictures, see below..
WD Forte
PostPosted: 18:11 - 22 Nov 2015    Post subject: Reply with quote
Only if the engine was running after it lost its oil (possibly)
Do not run it until the leak has been found, fixed and oil renewed.
If you rode it home like that after the spill you've likely killed it.
You may have cracked or scuffed through a casing so give it a close examination
What bike? if its a 125 they often only hold about a litre so don't need to lose much to go critical.
A bigger engine may be more forgiving
<grumpyrant>
WHY THE FUCK DO PEOPLE NEVER FUCKIN SAY WHAT FUCKIN BIKE THEY'VE FUCKIN GOT ?
</grumpyrant>
bikers smell of wee
Tomahawk
PostPosted: 18:37 - 22 Nov 2015    Post subject: Reply with quote
<grumpyrant>
</grumpyrant>
No I didn't ride it home; the engine cut off a few seconds after going down and I didn't try to start it again. I just put it in neutral and walked it home. Bike is a ZX6, holds nearly 4 litres of oil and I don't think I lost all of it.
mysterious_rider
PostPosted: 18:43 - 22 Nov 2015    Post subject: Reply with quote
Be fine just a cracked sidecase is all.
Betting its shifter side.
KAWASAKIIIII
Tomahawk
PostPosted: 19:23 - 22 Nov 2015    Post subject: Reply with quote
Why would a cracked sidecase leak engine oil?
The bike went down on its right side.
Scythe
PostPosted: 19:46 - 22 Nov 2015    Post subject: Reply with quote
Why do you think? Idea
2009 Yamaha YBR125 -> 2000 SV650S -> 2005 Kawasaki ZX6R 636
Tomahawk
PostPosted: 19:54 - 22 Nov 2015    Post subject: Reply with quote
I don't know, because I don't know what a sidecase or a cracked sidecase is. I was hoping maybe I'd be able to deduce it based on the answer to that question but I got found out Razz
PostPosted: 20:04 - 22 Nov 2015    Post subject: Reply with quote
A picture paints a thousand words.
TAKE SOME FUCKING PICTURES Evil or Very Mad
PostPosted: 20:09 - 22 Nov 2015    Post subject: Reply with quote
Have you not looked at the bike closely to figure out where the oil is coming from? Laughing
As Polarbear says, a photo would be incredibly useful. Especially if you want us to able to help you. Smile
Tomahawk
PostPosted: 20:28 - 22 Nov 2015    Post subject: Reply with quote
So much caps lock rage here, lol.
Ok, I'll take some pictures tomorrow when it's light out. Just thought I'd ask in case it's a common thing that happens all the time when a bike goes down.
Thanks for your help guys.
Tomahawk
PostPosted: 22:33 - 05 Dec 2015    Post subject: Reply with quote
OK guys I took some pictures.
The damage looks like it's mostly to the frame, so I can't see why I should be losing so much engine oil.
There is a part that broke off (see 3rd picture)
PostPosted: 23:02 - 05 Dec 2015    Post subject: Reply with quote
That scuff mark where the orange paint meets the black - behind there you'll find a cracked engine side casing.
Remove the fairing, take pictures.
kramdra
PostPosted: 23:46 - 05 Dec 2015    Post subject: Reply with quote
Looks like it was a nice bike you have ruined Laughing
I assume the broken off piece is part of the engine casing that has ripped off as the bolt wore down. I guess the thread might need an insert. From your pics I cant see any exposed part of the engine case where a bolt could do this.
Musketeer
PostPosted: 01:59 - 06 Dec 2015    Post subject: Reply with quote
From the third photo is that actually a piece of your crank case? Because it very much looks like it.
If so then you're f00ked. It's going to be a major engine rebuild work to get it properly fixed.
Maybe a welding artist is needed Razz
PostPosted: 10:28 - 06 Dec 2015    Post subject: Reply with quote
That looks like a fairing mount rather than casing.
redeem ouzzer
PostPosted: 12:09 - 06 Dec 2015    Post subject: Reply with quote
That's FUCKED. Laughing
Old Git Racing
PostPosted: 12:20 - 06 Dec 2015    Post subject: Reply with quote
Broken bit looks like it has a piece of gasket on it. Can't you at least take the side fairing off and take some close up pics of the right side of the engine where it appears to be damaged. The only way that much oil can come out is if the engine has a hole in it.
Don't try and start it.
OGR
Tomahawk
PostPosted: 14:15 - 06 Dec 2015    Post subject: Reply with quote
OK, I took the fairing off and I found out where the broken off part came from.
There are a couple bits damaged in the slide, a bolt broken at the top and a chunk that came off at the bottom. (see first image)
There is a hole in the casing where the chunk came off -- see second image. Is that the engine casing or the clutch casing?
Everything else seems to be OK.
How bad is it? Can I just replace the casing and put it back together?
Aff
PostPosted: 14:26 - 06 Dec 2015    Post subject: Reply with quote
Thats pretty damn unlucky.
Pretty much a full engine rebuild to replace the bit that cover bolts onto.
A weld repair doesn't look very likely either.
Electric Bike Project
PostPosted: 14:44 - 06 Dec 2015    Post subject: Reply with quote
https://www.bikechatforums.com/download.php?id=96738
You insured comp? Because that's a smashed crankcase and your engine is pretty much scrap.
Possibly could be fixed by a skilled aluminium welder but even then it's an engine out and full strip job
Tomahawk
PostPosted: 14:56 - 06 Dec 2015    Post subject: Reply with quote
Nope, just got 3rd party.
Why does that mean a scrapped engine? Can't you just replace the crankcase?
Aff
PostPosted: 15:01 - 06 Dec 2015    Post subject: Reply with quote
The part you have broken is what's holding the gearbox and crankshaft in.
To replace it you have to take pretty much every part out of the engine.
If you are happy doing the work yourself then its worth doing. Otherwise it will probably be more economical to replace the engine.
Tomahawk
PostPosted: 15:10 - 06 Dec 2015    Post subject: Reply with quote
Thanks mate.
Do you know approximately how much a shop would charge to do this work?
Or the approximate cost of an engine replacement?
Musketeer
PostPosted: 15:35 - 06 Dec 2015    Post subject: Reply with quote
Like above. It's a major job to replace a crank case. Engone out and all engine internals need to go out. Not to mention a hell of work before you even touch the engine.. you need to disconnect/remove pretty much everything - drain the rest of the oil, drain the coolant, remove exhaust collector and end pipe, radiator, suspension linkages, rear shock, bolts that attach the engine to the frame, before that the seat, tank, air box and intake, injectors, throttle cables, wiring loom, all sorts of vacuum/overflow pipes. If you DIY then all you need is a room/garage, new crank case and gaskets and some bolts replacements and a lot of time.
To pay to someone to fix it will cost a lot. Many, many hours of work
Alternatives are:
- Some welding magician in your area (not likely)
- Whole engine replacement
Tomahawk
PostPosted: 15:42 - 06 Dec 2015    Post subject: Reply with quote
Alternatives are:
Thanks for the explanation, much appreciated.
I don't really want to replace the engine as it's got a good engine (only 6400 miles!)
How long does it take to do all of the things you said? I don't really have a garage, would I be able to get it done over a weekend when the weather is reasonable?
If I find a welder, what do I tell him? Just tell him to seal up the hole?
The last post was made 10 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 129.99 Kb
