fzr1000 1994
40tytowers
PostPosted: 21:51 - 23 Nov 2015    Post subject: fzr1000 1994 Reply with quote
Hi guys, im having a tick over problem, 1994 fzr1000ru. It wont settle at 900-1000rpm,i have to have it at 12-1500rpm . Done all the usual cleaned & balanced carbs, petrol tank , petrol & tap. Ive even tried another set of carbs !! Any ideas ??? cheers John
redeem ouzzer
PostPosted: 21:55 - 23 Nov 2015    Post subject: Reply with quote
Worn carbs needles / slides or a slightly tired engine.
40tytowers
PostPosted: 22:02 - 23 Nov 2015    Post subject: Reply with quote
Hi, thanks- its only done 41000 miles runs brilliant just the tick over issue
redeem ouzzer
PostPosted: 22:07 - 23 Nov 2015    Post subject: Reply with quote
Depends how it's been ridden. My GSXR1100 runs ok but has tickover issues cause the carbs are badly worn. 41k is plenty to knacker a set of needles if it's been ridden in town alot.
40tytowers
PostPosted: 22:12 - 23 Nov 2015    Post subject: Reply with quote
Thanks any idea were I can get needles & slides ?
PostPosted: 22:17 - 23 Nov 2015    Post subject: Reply with quote
And if a dynajet kit has been fitted, the needles on those have a reputation for causing wear far more rapidly.
However the other thing to check is the cable for the idle speed adjuster. Can develop a fixed bend to it will only sit in one position. Hence one full turn is the smallest adjustment you can get it to hold.
Katy
PostPosted: 22:32 - 23 Nov 2015    Post subject: Reply with quote
Kickstart wrote:
Katy
Suddenly Katy... what is this magic.
redeem ouzzer
PostPosted: 23:36 - 23 Nov 2015    Post subject: Reply with quote
I've just bought OEM needles and tubes for my 1100. Not cheap though.
RhynoCZ
PostPosted: 23:39 - 23 Nov 2015    Post subject: Re: fzr1000 1994 Reply with quote
I'm not a FZR expert, but most of the motorcycles have the idle between 1200 and 1500 rpm. Not many bikes (in-line fours) i've ever seen had the idle much lower than 1200 rpm.
I might be wrong though. Thumbs Up
PostPosted: 21:02 - 24 Nov 2015    Post subject: Re: fzr1000 1994 Reply with quote
Most are quite low, although often owners set them higher. FZR1000 EXUP is listed as 950~1050rpm.
Katy
Nobby the Bastard
Harley Gaydar
PostPosted: 21:55 - 24 Nov 2015    Post subject: Reply with quote
Have you had a look at the carb rubbers (carb to head)?
If they are anything like the ones on mine, they are perished to fuck after 20 years and have cracks allowing air to leak in. Mine was a fucker for the tickover as well.
Triumph Sprint ST 1050
The last post was made 10 years, 290 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 66.86 Kb
