Raspberry Pi Zero...
ScaredyCat
PostPosted: 10:19 - 26 Nov 2015    Post subject: Raspberry Pi Zero... Reply with quote
https://vimeo.com/146893658
If you pick up a copy of the MAGPi magazine you'll get a free one attached to it..
Normal price for PiZero would be around £4 ...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
ThoughtContro...
PostPosted: 12:12 - 26 Nov 2015    Post subject: Reply with quote
Good luck finding one. I expect they'll all be snapped up very quickly, and no doubt more than a few will find their way on ebay in due course
Prize cunt
ScaredyCat
PostPosted: 14:04 - 26 Nov 2015    Post subject: Reply with quote
There were 4 in Tesco, Copdock, Ipswich - but I picked up 3 for myself and colleagues. I did leave the other one as I felt it would have been a little unfair to some poor kid that probably wanted one...
I'm such an angel...
ThoughtContro...
PostPosted: 15:59 - 26 Nov 2015    Post subject: Reply with quote
Poor kid? I'd be surprised if anyone buying a Pi was under 30. In an age where parents on benefits throw the latest and greatest smartphones at little Chantelle or if they don't face a monumental strop out, I'm not exactly sold on the kids "too poor to get into coding" argument. Call me a jaded and cynical old git.
Prize cunt
ScaredyCat
PostPosted: 16:06 - 26 Nov 2015    Post subject: Reply with quote
You're a ja.... too easy but at least you're in the right place for that attitude Wink
CaNsA
PostPosted: 16:48 - 26 Nov 2015    Post subject: Reply with quote
Already on fleabay for £17
https://www.ebay.co.uk/itm/281867930662
ScaredyCat
PostPosted: 17:32 - 26 Nov 2015    Post subject: Reply with quote
Standard jessie image works out of the box, even with some dodgy USB ethernet converter I found in a box.
Code:
pi@raspberrypi:~ $ cat /proc/cpuinfo
processor            : 0
model name         : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS            : 2.00
Features            : half thumb fastmult vfp edsp java tls
CPU implementer      : 0x41
CPU architecture         : 7
CPU variant         : 0x0
CPU part            : 0xb76
CPU revision         : 7
Hardware            : BCM2708
Revision            : 900092
Code:
pi@raspberrypi:~ $ lscpu
Architecture                : armv6l
Byte Order                  : Little Endian
CPU(s)                      : 1
On-line CPU(s) list         : 0
Thread(s) per core          : 1
Core(s) per socket          : 1
Socket(s)                   : 1
Model name                  : ARMv6-compatible processor rev 7 (v6l)
CPU max MHz                 : 1000.0000
CPU min MHz                 : 700.0000
pi@raspberrypi:~ $
Code:
pi@raspberrypi:~ $ lsusb -vv
Bus 001 Device 002: ID 0a46:9601 Davicom Semiconductor, Inc. DM9601 Fast Ethernet Adapter
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0a46 Davicom Semiconductor, Inc.
  idProduct          0x9601 DM9601 Fast Ethernet Adapter
  bcdDevice            1.01
  iManufacturer           1
  iProduct                2
  iSerial                 3
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              144mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass         0 (Defined at Interface level)
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               1
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 Unused
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.01
  iManufacturer           3
  iProduct                2
  iSerial                 1
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 Unused
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
pi@raspberrypi:~ $
Code:
pi@raspberrypi:~ $ cat /proc/meminfo
MemTotal:         445032 kB
MemFree:          177080 kB
MemAvailable:     363192 kB
Buffers:           14736 kB
Cached:           192780 kB
SwapCached:            0 kB
Active:            96832 kB
Inactive:         146664 kB
Active(anon):      36296 kB
Inactive(anon):     4640 kB
Active(file):      60536 kB
Inactive(file):   142024 kB
Unevictable:           0 kB
Mlocked:               0 kB
SwapTotal:        102396 kB
SwapFree:         102396 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:         35992 kB
Mapped:            37972 kB
Shmem:              4960 kB
Slab:              12864 kB
SReclaimable:       8060 kB
SUnreclaim:         4804 kB
KernelStack:        1000 kB
PageTables:         1800 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      324912 kB
Committed_AS:     528040 kB
VmallocTotal:     565248 kB
VmallocUsed:         964 kB
VmallocChunk:     342500 kB
CmaTotal:           8192 kB
CmaFree:            3744 kB
Nothing new or outstanding, clocked to 1GHz.
Note that there's only 1 USB, the one closest to the led is for power only. It's small, DDR3 small. I think the magazine give away is a landmark event.
https://dl.dropboxusercontent.com/u/188253/general/pi0.png
CaNsA
PostPosted: 17:57 - 26 Nov 2015    Post subject: Reply with quote
If anyone can find a copy of MagPi, could you grab it for me please.
PostPosted: 19:20 - 26 Nov 2015    Post subject: Reply with quote
I don't have a use for it, but I have a strong urge to insert one into me. Thinking
mudcow007
PostPosted: 16:02 - 27 Nov 2015    Post subject: Reply with quote
i bought the pi2, with big ideas even bought the camera module for it - rand it for a few weeks on Kodi then gave up
what do you do with your pi's?
ScaredyCat
PostPosted: 19:11 - 27 Nov 2015    Post subject: Reply with quote
I'm building a PiFi which supports squeezecentre, airplay and DNLA and also has purty analog VU meters. There's a DAC in the offing for the pi0 (https://shop.pimoroni.com/collections/raspberry-pi/products/phat-dac) so I could make it smaller too.
Also looking at building a smart mirror type display.
Currently have one controlling my cheerlights too, although that's due to go onto an arduino YUN.
J.M.
PostPosted: 19:38 - 27 Nov 2015    Post subject: Reply with quote
My Pi sits running OSMC and is configured to automatically download episodes for the TV shows I watch and movies too. It's connected to a 2TB HDD. I can also send YouTube videos to it, but it's not as good as a Chromecast for that.
The Pi Zero look great. Can't think of a use for it yet though.
2004 R1 & 2018 XSR900
PostPosted: 22:47 - 27 Nov 2015    Post subject: Reply with quote
SSH / Squid proxy.
For my safety and convenience, my employer uses the ZScaler web proxying service for all standard web traffic. This injects a CA cert and MITM hijacks all SSL connections to send our web traffic, in clear, to a Septic company. Including, for example, banking transactions.
Phuc.
Dat.
Biches.
The last post was made 10 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 91.08 Kb
