wk125 sport rubber hoses under fuel tank
Old goat
PostPosted: 09:46 - 27 Nov 2015    Post subject: wk125 sport rubber hoses under fuel tank Reply with quote
Hello I'm wondering if someone can help me out,
Right my sons wk125 sport started cutting out so starting to take the bike apart to clean the carb and adjust the mixture screws, when I lifted the tank off I found that their 3no pipes coming from what I can only think is a vacuum pump bolted just under the tank near the head stock , 1 no small pipe goes in to the carb housing and the other are large pipes one even has a filter in it but my problem is they are not connected to anything and I don't know where they need to go,
i have searched the net but can't find the answer , as the pipes must go somewhere
Can someone please advise me as this is my last hope !!!!!!!!
PostPosted: 10:06 - 27 Nov 2015    Post subject: Reply with quote
Pictures would help.
Like this?
https://i.ebayimg.com/00/s/OTAwWDEyMDA=/z/yS4AAOSwHjNV-sTF/$_35.JPG
That would be an EGR valve. If it is, one hose should connect to an outlet near the exhaust something like this.
https://www.chinesemotorcyclepartsonline.co.uk/images/partimages/129905015_HT125-8(Lexmoto)_150.jpg
Third one, uh, I misrecollect. Airbox? Could just be a vent. Thinking
Owners tend to blank off the outlet because, fack it, it's only emissions and that, probably losing 5hp, innit.
However, without seeing the plumbing in question that's speculation.
Old goat
PostPosted: 10:28 - 27 Nov 2015    Post subject: Reply with quote
Right ok yes agreed it is the EGR valve
The smallest hose goes to the rear of the engine and has a slight rip in it where if fits just before the carb on the rubber bit that bolts the carb to the motor,
If I blank one of the bigger hoses off does it matter witch one as the longer of the two hoses has the filter on it and still can't see where they need to go I've looked for the second pic you posted and I can't see it on the motor would it be possible someone has removed this and blanked for some reason
Old goat
PostPosted: 12:34 - 27 Nov 2015    Post subject: Reply with quote
This may sound daft, but if the tank over flow is connected would it throw the excess in the carb inlet through the EGR valve ???
And what exactly does the EGR valve do with the pipes does it give more air to the carb with the little pipe ????
Does anyone know I'm loosing the will to live with this
Cheers for all the advice so far
Old goat
PostPosted: 13:09 - 27 Nov 2015    Post subject: Reply with quote
So with that the bike should run fine without it being connected apart from losing a few bhp
Am I right in saying that I can leave the pipes off ????? And not use the EGR valve
But if I have to fit it this I how it should work
EGR valve 2no big pipes ( 1 with a directional flow filter ) 1no small pipe
Small hose to carb area rear of the motor
One of the big one to the tank over flow - presume this one I'll use with the filter on it
3rd one may just be a breather pipe
Old goat
PostPosted: 01:17 - 28 Nov 2015    Post subject: Reply with quote
Ok finally
Bike back together ticks over like a dream revs up spot on
The 2no bigger hoses left of no idea where they go still
The small one is connected to the inlet manifold ( the rubber housing between the carb and engine)
If anyone has a pic of where they should be I would still like them on just peace of mind really
Don't want my son calling about 3am dad I've broke down can you get me 🙄🙄
Thanks people
The last post was made 10 years, 304 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 57.95 Kb
