Scottoiler.
Itchy
PostPosted: 16:21 - 28 Nov 2015    Post subject: Reply with quote
If this is for your fazer (carb) then you don't need any of those parts.
What you need is some tubing to connect to your carb vacuum nipple. Then you need some 2mm tube. You need to mate them somehow as the vacuum nipple IIRC is 5-6mm while the tube which goes into the top of the scotoiler is 2mm diameter. You can drill a small rubber bung or use silicone as the vacuum draw is tiny.
The nib is just a thick white straw and a 2mm thick black straw which tapers into a small 2mm tube which contains a bit of metal like a paperclip. BTW the nib tube is the same tube they use to connect to the vacuum knuckle but containing the paper clip.
My scotoiler end fell off somewhere in Yorkshire. I simply replaced it with the above for the distribution nib. You can cable tie it on or use some self taping screws and drill the swing arm and a small U shaped bit of metal to hold the tube in place.
Oldie
PostPosted: 16:22 - 28 Nov 2015    Post subject: Reply with quote
I have the following parts which you can have for free (that's if they're any use to you). I can't actually remember what they're for Neutral
https://lh3.googleusercontent.com/-JA6gnPf22to/VlnUVRkUBCI/AAAAAAAAFCE/CBf7vRwebyM/s800-Ic42/IMG_20151128_161658143%25255B1%25255D.jpg
Oldie
PostPosted: 16:35 - 28 Nov 2015    Post subject: Reply with quote
Also found this which might help you.
https://lh3.googleusercontent.com/-87yJgpa8PHo/VlnXf6Wu6fI/AAAAAAAAFCg/VwMFoiEeeSY/s800-Ic42/IMG_20151128_163307132_HDR%25255B1%25255D.jpg
Itchy
PostPosted: 16:44 - 28 Nov 2015    Post subject: Reply with quote
The parts are as follows
A holds the oil tube and the nib just before it goes onto your sprocket.
B is the nib and or vacuum hose (same pipe type but the vacuum house should be longer of course)
C connects to the carb vacuum
D either clips the scotoiler tank in place or holds a tube in place
E are additional oil pipe connectors if yours blocks or snaps (they never do)
F is thin metal you can put on your rear spindle in case you want to use that as a mounting for the nib.
MCN
PostPosted: 20:21 - 28 Nov 2015    Post subject: Reply with quote
Goto Scotoiler's webpage and you will find more than enough info on install and set up.
Just look for your system.
Don't try to 'Slack-Hand full' the setting as Scottoiler seem to know wot they're on about. Embarassed
Oldie
PostPosted: 07:13 - 29 Nov 2015    Post subject: Reply with quote
Loobman? Got one of those as well Very Happy
Can't remember what bike it was bought for - not sure that it matters - but you can have it for nowt if you want it.
https://lh3.googleusercontent.com/-vrji06PLIXE/VlqkvUd3vzI/AAAAAAAAFDE/whdBopEevdA/s800-Ic42/IMG_20151129_070846620%25255B1%25255D.jpg
Oldie
PostPosted: 16:12 - 30 Nov 2015    Post subject: Reply with quote
Posted 1st Class this afternoon Thumbs Up
The last post was made 10 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.34 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 63.18 Kb
