Skylake
PostPosted: 12:49 - 30 Nov 2015    Post subject: Skylake Reply with quote
By all accounts this is a relatively big step forward, I have one of the original i7s but feel I could use an upgrade.
Looking at the 6700k and a Z170 mobo and 2x8gb DDR4, still a tad Pricey at £6xx would be much happy paying low £5xx.
Any recommendations for kit or suggestions on the build? Any idea when there will be a price drop?
Rest of the kit is
Corsair H100i
GTX780
Crucial M550(OS Drive) + M4(Steam drive)
Corsair HX850
Asus Xonar
notbike
PostPosted: 15:41 - 30 Nov 2015    Post subject: Reply with quote
I jus upgraded my whole rig to skylake. If you wana save a bit of £, then the 850w PSU isn't necessary for the gfx card you're using unless you're going SLI or overclocking your rig.
My whole rig draws around 500 odd watts, only reason I put the AX860 in is because I'm likely gonna shove a 2nd gtx 980ti in there for SLI and it'll be drawing another 200-300.
Furhtermore you can drop the sound card to save a few £ unless you're doing high level music production.
For gaming, Audio Boost 3 on most 170 chipset mobo's will be perfectly fine for all your gaming needs. It's pretty good for other stuff too like music/movies cause the software comes with audio profiles.
Out of curiosity which mobo you going for, and also what are you using PC for?
I'm on MSI z170a m7 and it's pretty sweet.
PostPosted: 15:51 - 30 Nov 2015    Post subject: Reply with quote
Sorry I should say the rest of the build I already have, I'm only upgrading the CPU MOBO and RAM, also overclocking and SLI will be on the cards. In fact another 780 will be along as soon as I see a good deal.
Primarily Gaming, Photo Editing and some video editing too.
I was looking at the MAXIMUS VIII, but I really don't know, I'm thinking about going for something cheaper as the £650 it'll all cost feels just a bit to much.
supZ
PostPosted: 17:30 - 30 Nov 2015    Post subject: Reply with quote
just upgrading myself as my current pc threw a major hissy fit on friday.
i7 4790k 4ghz cpu
MSI Z97 Gaming 5 mobo
Corsair Vengeance Pro Series 16GB DDR3
MSI NVIDIA GTX 970 Twin Frozr
bit of a step up from my 2500k Smile
CBR954RR - Daily toy
CBR600RR - Trackbike
PostPosted: 17:38 - 30 Nov 2015    Post subject: Reply with quote
Any reason you didn't go DDR4? Seems silly to me personally to buy new gear but not get the new form factors.
notbike
PostPosted: 17:41 - 30 Nov 2015    Post subject: Reply with quote
MSI Z97 only supports DDR3
Im-a-Ridah
PostPosted: 19:29 - 30 Nov 2015    Post subject: Reply with quote
That's a huge amount of money for what looks like 10fps increase on an already very fast CPU. The benefit of the newer chips is more in power efficiency, not speed. If it were a laptop chip then I could see the point.
https://www.eurogamer.net/articles/digitalfoundry-2015-intel-skylake-core-i7-6700k-review
notbike
PostPosted: 20:21 - 30 Nov 2015    Post subject: Reply with quote
I agree people shouldn't upgrade if theyre still on haswell or even ivy bridge, especially in gaming.
But more efficiency = lower TDP = more overclocking headroom. The fact it'll run less hot will let you overvolt it a little more meaning it'll run more stable at higher clockspeeds.
Difference of OC is negligible in gaming though, some games showing around a 2% increase in FPS when OC'd to 4.4ghz (really not worth doing, may aswell OC gfx card) however your render times will fall dramatically in any kind of editing/rendering software.
I upgraded from a locked 3.6ghz Sandy Bridge cpu and FHD video rendering is noticeably faster. So I'm tempted to OC to 4.4-4.6ghz and see what happens Very Happy
PostPosted: 22:06 - 30 Nov 2015    Post subject: Reply with quote
I meant a DDR4 mobo...
Seb
PostPosted: 01:01 - 01 Dec 2015    Post subject: Reply with quote
Still not found a reason to replace my ye olde i7-950 tbh.
Does just fine with a single 780ti, although the upgrade would make a lot more sense if I ran SLI.
I suspect Pascal will be the trigger for a fresh pc though.
2010 Triumph 1050 Sprint ST
Jayy
Mr. Ponzi
PostPosted: 15:11 - 02 Dec 2015    Post subject: Reply with quote
Only reason I see of upgrading my Ivybridge is the DDR4 ram on the board. I know Skylake won't exactly leap me in to cutting edge speeds compared with Ivybridge but I'd like to utilise DDR4 and everything else an upgraded board comes with.
My rig is used for occasional gaming (Tri SLi), occasional video editing and mostly design work.
The last post was made 10 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 71.42 Kb
