Motorway commuter? [UPDATE]
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3, 4, 5  Next
techathy
PostPosted: 09:50 - 03 Dec 2015    Post subject: Reply with quote
G wrote:
Quoted time for the latest Focus RS is 4.7s. Time for the CB500 is 4.9s.
Get a poor start on the bike and you could be a good chunk behind if the car driver gets a good launch.
And in my experience it's easier to launch a car quickly than a bike.
PostPosted: 09:54 - 03 Dec 2015    Post subject: Reply with quote
The opposite for me, but I started on bikes.
Keep the front wheel just before it's going to lift and you've got it close-enough nailed on the bike. With a car it's a case of being just before you get wheel spin, which for me is harder to judge.
PostPosted: 09:58 - 03 Dec 2015    Post subject: Reply with quote
https://i.ebayimg.com/00/s/MTE1Mlg3ODM=/z/wxkAAOxyUylTRR6y/$_35.JPG VS https://i.ebayimg.com/00/s/MTQ2M1gxMDIy/z/2ZsAAMXQLw1R1FXd/$(KGrHqZ,!ooFG4,dVYhYBR1F(dPDYg~~60_35.JPG
FITE.
9,000 miles a year, get whatever you want, it'll be fine.
PostPosted: 10:08 - 03 Dec 2015    Post subject: Reply with quote
Turbo R1. You'll need the extra power. Thumbs Up
techathy
PostPosted: 10:17 - 03 Dec 2015    Post subject: Reply with quote
Assuming mechanical handbrake. Legal method for FWD/AWD cars - release hand brake at the same time feed in the throttle smoothly & quickly while feeding out the clutch in the same manner. When the steering starts to feel slightly lose feather the throttle gently until normal steering returns.
Matt B
PostPosted: 10:30 - 03 Dec 2015    Post subject: Reply with quote
This thread is going wayyyy off track.
Implying there are illegal ones. So I could possibly be convicted for using any other method? Thinking
techathy
PostPosted: 10:36 - 03 Dec 2015    Post subject: Reply with quote
It's not the only legal method of pulling away but it's the fastest legal method. All faster methods require spinning your wheels. So unless you're on snow/ice then you're more than likely going to fall foul of "driving without due care & attention" as well as "failing to control your vehicle".
PostPosted: 13:15 - 03 Dec 2015    Post subject: Reply with quote
Only if there's a particularly pure example of an arsehole for a copper watching.
techathy
PostPosted: 14:15 - 03 Dec 2015    Post subject: Reply with quote
The crime is the act, not getting caught. Wink
If the officer feels the need to be seriously retentive then add excessive acceleration to the list. Rolling Eyes
stevo as b4
PostPosted: 19:11 - 03 Dec 2015    Post subject: Reply with quote
Just to be even even more off topic. Laughing
The latest Ford Focus RS is hardly even out on sale yet. When did 58bhp CB500's stop being built?
The lurid Kermit green mostly Mk2 RS is a good chunk slower accelerating (still hugely impressive for a 4wheel vehicle that many people can buy), and it's also an fwd'er not a 4wd like the latest/current only just model.
Even more off topic since we're on about peoples launching skills, but how easy is it to launch these modern ultra trick superbikes like the Ducati 1299 and new R1 with the launch control and anti flip like a bastard devices?
Do you pin the throttle at the lights, and hold on tight and the bike will sort everything out while you go into warp factor 10?
kramdra
PostPosted: 21:46 - 03 Dec 2015    Post subject: Reply with quote
wr6133 wrote:
kramdra wrote:
My CBR250rr also does 120 and probably with a lot less stress on the engine than would be on a CB500 as its nowhere near redline.
Is yours very special then?
Indicated 118 mph (190kph) touching the redline
https://www.youtube.com/watch?v=6UWYfRKq2b0
Nothing special about mine and happy to prove or disprove it using gps, which I have been planning to do.
Firstly speedo's are known to be inaccurate on most bikes and various reasons the 250rr more likely.. few have standard size tyres, my rear is larger profile (which should make it more accurate). Mine will indicate 220km/h where the needle will stop although still accelerating very slowly. A good example is the tacho, although it reads upto 20k (19.5k in your vid), this graph shows limiter is 17k as standard.. not much higher than a 600rr Laughing You can see the ignition is retarded, apparently to protect the engine. I believe if they redesigned this engine with modern technology it could have significantly more power.
https://www.eclipze.com.au/files/cbr250/ecu/cbr250rr_bluefox_advance_curve_hires.jpg
Power, most bikes loose a bit at redline, unless they are tuned for racing. 250rr's are tuned and geared to be very rideable, and my claim of top speed being achivable at 13k rpm is not far off according to this graph. Riding on the limiter is retarded.
https://www.rooracing.com/images/dyno.jpg
The actual rpm when mine is indicating 13k is likely to be ~12k.
wr6133
PostPosted: 22:05 - 03 Dec 2015    Post subject: Reply with quote
Go on then helmet cam photo showing GPS reading 136 MPH (your claim of 220 kph) and tacho showing 13k.
I think you are full of shite.
kramdra
PostPosted: 22:54 - 03 Dec 2015    Post subject: Reply with quote
I claim 220+km/h indicated with a speedo I suspect is not the most accurate so you can fuck off with your GPS reading of 136mph. Most speedos over read 10% so I'm fairly certain it will be at or above 120mph considering the tire is larger profile.
wr6133
PostPosted: 23:08 - 03 Dec 2015    Post subject: Reply with quote
GPS 120MPH/speedo 220kph @ 13k then
Still think you are full of shit.
kramdra
PostPosted: 23:34 - 03 Dec 2015    Post subject: Reply with quote
Somewhere around that yes.
However my original point was that a CB500 would *not* be suitable for higher speed commuting. It might do it occasionally but holding it would explode the engine. It'll be right on the limiter
https://www.youtube.com/watch?v=dOyUZ89cdyI
Do not want.
stevo as b4
PostPosted: 00:34 - 04 Dec 2015    Post subject: Reply with quote
CB500's rev very nicely to nearly 11k and would not explode held at 110-120mph for 6hours if you stopped for petrol.
As for your CBR, first your saying the indicated speed might be out a bit which is normal, and then your saying the indicated rpm is 1000rpm above true engine speed.
You also said engines tend to lose power at or just before the red line, it depends on the engine, but it would be totally normal on an IL4, even a WSB bike will drop off before the rev limiter, its not a fault though!
spottedtango
PostPosted: 01:19 - 04 Dec 2015    Post subject: Reply with quote
Another +1 for an NTV600/650
Ive owned a few of them. One went through 2 winters with one wash and was still not too rusty. They will hit 100mph no problem which is fast enough for a normal motorway jaunt. As others have said needs a 6th gear and lacks a bit of edge but perfect for motorways. It's basically a car on two wheels
drzsta
PostPosted: 17:52 - 05 Dec 2015    Post subject: Reply with quote
UPDATE: Well I went and got a F800ST '09 16000 miles for £2350. Well pleased Very Happy
https://i184.photobucket.com/albums/x254/FearThis-AK/Mobile%20Uploads/DSC_0026_zpspj8wsv24.jpg
And back at home... Thumbs Up
https://i184.photobucket.com/albums/x254/FearThis-AK/Mobile%20Uploads/DSC_0027_zpsithzirfe.jpg
PostPosted: 18:35 - 05 Dec 2015    Post subject: Reply with quote
Nice. Well, hideous but mantlepiece, fire. Wink
Kal
PostPosted: 18:54 - 05 Dec 2015    Post subject: Reply with quote
Very tidy. Now if you wouldn't mind being quiet about your new purchase on your own thread I want to see if anyone will post another graph.... Twisted Evil
<popcorn>
Kal...
kramdra
PostPosted: 20:06 - 05 Dec 2015    Post subject: Reply with quote
You went with ugly, grey and ugly Laughing
Val
PostPosted: 20:23 - 05 Dec 2015    Post subject: Reply with quote
Congrats this beemer looks cool Thumbs Up
Matt B
PostPosted: 09:46 - 06 Dec 2015    Post subject: Reply with quote
I reckon it's a good choice for what you want. Never ridden one but reviews rate them as a decent bike. They seem to come up cheap for their age so you get a lot of bike for not much money.
c_dug
PostPosted: 09:54 - 06 Dec 2015    Post subject: Reply with quote
Will it out drag a focus RS though?
The last post was made 10 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Page 4 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 134.23 Kb
