Honda MTX Engine swap
CurtisBowden
PostPosted: 19:28 - 03 Dec 2015    Post subject: Honda MTX Engine swap Reply with quote
Hi guys, swapping out the UK non powervalved engine with a JC20 NSR engine.
Anything I need to be worried about? Batteries, wiring, etc.
Engine has arrived!
'87 Honda MTX 125. Fully restored.
alains
PostPosted: 20:00 - 05 Dec 2015    Post subject: Reply with quote
buy a JC20 loom if you win to fit the engine on the frame !
CurtisBowden
PostPosted: 13:52 - 07 Dec 2015    Post subject: Reply with quote
Will the MTX loom not fit or be close to?
alains
PostPosted: 14:12 - 07 Dec 2015    Post subject: Reply with quote
the problem is the terminals & connections with all the electronics
dont remember you need :
- servo-motor with a valves controler
- cdi unit
- reg/rec
- battery YTX5L-BS
stirlinggaz
PostPosted: 14:34 - 07 Dec 2015    Post subject: Reply with quote
hi,
iirc my mtx could run without a battery & had a very basic wiring loom.
would definitely need a nsr loom, though might be able to "lose" some wires.
cheers,
GAZ
CurtisBowden
PostPosted: 10:51 - 08 Dec 2015    Post subject: Reply with quote
I get you.
This is the engine in question, arrived a couple days back, looks pretty clean!
https://www.ebay.co.uk/itm/Honda-NS125-NS-125-JC20-Alcast-Full-Complete-Engine-H1-JC20E-01635-/262152522403?hash=item3d09820aa3:g:~LsAAOSwlV9WTz6C
alains
PostPosted: 11:50 - 08 Dec 2015    Post subject: Reply with quote
you need a lot of spares now
- 28PHBH/FS carb + reeds + air box
- starter relay
- reg/rec
- valves system with cables
- control box (TV78) + CDI (CI572)
and obviously engine top end de-coking , rings change , eventually with piston change
stirlinggaz
PostPosted: 22:20 - 08 Dec 2015    Post subject: Reply with quote
hi,
I havnt looked at your link but is it a leccy start jc20 engine?
if so your gonna need starter motor, wiring & switchgear also.
good luck! Smile
cheers,
GAZ
The last post was made 10 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 55.57 Kb
