| blue_painted |
 blue_painted Nova Slayer
| Robby |
 Robby Dirty Old Man
| blue_painted |
| MCN |
 MCN Super Spammer
 Posted: 17:04 - 05 Dec 2015 Post subject: |
Without looking at any spec./off the top of my head:
If the engine is 'Oiling' then you have drained the oil from the sump. On separate oil systems there should only be a small amount a few CCs of oil in the sump.
When the engine is running the oil is pumped back by the scavenge pump. The scavenge pump is bigger than the oil pump so that the sump is never full.
The oil is held in the tank by a check valve or non-return valve of some sort. If this valve isn't seating properly then oil can seep back into the sump.
Perhaps the system was over filled.
This is possible if the engine oil is topped up when the engine has sat for some time and the oil had trickled down into the sump which would produce a 'low' level in the tank.
The tank is where the oil is added on service/top up. It should be filled to the level.
They normally don't hold a lot of oil when compared to a more modern bike as most bike have gearbox and engine using common oil so in effect you fill two sumps.
Separate oil tank systems have one lot of oil for the gearbox and another lot of oil for the engine.
I am the first to admit it but I may be talking shite.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Nobby the Bastard |
| Polarbear |
 Polarbear Super Spammer
| Ariel Badger |
 Ariel Badger Super Spammer
| Robby |
 Robby Dirty Old Man
| jimspeed |
 jimspeed World Chat Champion
| Ariel Badger |
| jimspeed |
 Posted: 00:20 - 06 Dec 2015 Post subject: |
It used to be a common problem with saabs some of those had a gearbox underneath the engine and 2 separate drain plugs. ____________________ Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?" |
| blue_painted |
The last post was made 10 years, 349 days ago. Instead of replying here, would creating a new thread be more useful? |
