Asbestos testing
Ribenapigeon
PostPosted: 16:48 - 07 Dec 2015    Post subject: Asbestos testing Reply with quote
Is there a ghetto test for asbestos? I have Artex and I want to put a loft access hatch in but will have to cut through some artex. Online testing kits are forty quid+ which seems a bit steep.
Monkeywrenche...
PostPosted: 16:53 - 07 Dec 2015    Post subject: Re: Asbestos testing Reply with quote
Take a sample (Half a handful of finely ground material should do) Inhale deeply and wait 25/30 years see if anything happens.
arry
PostPosted: 17:02 - 07 Dec 2015    Post subject: Reply with quote
It's OK - you'll get murked by a disgruntled former employee of a motorcycle accessories retailer before pleural plaques take hold so I'd not worry
c_dug
Not to state the obvious (but I will since I have no idea how much you know), but you could eliminate the possibility altogether if you know when the building was built?
MCN
PostPosted: 17:19 - 07 Dec 2015    Post subject: Reply with quote
WTF are you doing living in the 70s? Smile
Allegedly, there's a 'less harmful' asbestos in Artex but it is still asbestos and it still creates dust.
Any dust should be/is considered harmful and proper PPE and work practices are recommend and or legislated for.
Normal work requires cheap PPE. Tyvek overalls and an asbestos appropriate respirator/mask.
The important point is Job Planning to avoid creating dust.
Good hygiene by not contaminating 'clean' areas with material and PPE from 'dirty' areas.
That is what most of the phaph is about. Proper training.
Some cool info here:
https://www.asbestoswatchdog.co.uk/home
I worked for a demo company and one of the major cash earners was asbestos removal. Money for old rope really. Smile
Ribenapigeon
PostPosted: 17:20 - 07 Dec 2015    Post subject: Reply with quote
The building was 1925 the artex possibly 1980s onwards.
PostPosted: 17:26 - 07 Dec 2015    Post subject: Reply with quote
What will you do differently based on the answer?
Might be simpler to go ahead and assume that it does have asbestos and treat it accordingly.
https://www.hse.gov.uk/asbestos/essentials/index.htm#a2
Ribenapigeon
PostPosted: 17:28 - 07 Dec 2015    Post subject: Reply with quote
Ribenapigeon
PostPosted: 17:42 - 07 Dec 2015    Post subject: Reply with quote
I suppose go a bit more over the top if I know its got asbestos in it. I have the recommended PPE. I have a 3m respirator rated for use with chemicals but filters are expensive and would obviously have to be ditched rather than reused. But then a £30+ for a test it probably cheaper to just assume there's asbestos.
Its a fucking pain though. Whoever invented Artex was a twat.
PostPosted: 18:05 - 07 Dec 2015    Post subject: Reply with quote
1980's artex usually contains very low levels of crysotile (or nothing) but it could potentially contain any of the amphibole types or a mix of all of them in any concentration.
There is NO way to self-test for the stuff unless you happen to be an analyst. Fibres require a microscope to identify (and training).
PostPosted: 18:11 - 07 Dec 2015    Post subject: Reply with quote
Just assume that there is Asbesdoes unless you fancy getting the bad aids. And stop being such a tight cunt and wear the correct PPE. Thumbs Up
arry
PostPosted: 19:13 - 07 Dec 2015    Post subject: Reply with quote
Pretty much this
It's almost certainly non licenced non notifiable asbestos and not in a distressed state. All the advice is on the HSE website. If you do decide to get someone in to do it, they don't need decontamination pits or the like and it's something they're used to dealing with so if they try to rip you off just hire another contractor.
J4mes
PostPosted: 19:31 - 07 Dec 2015    Post subject: Reply with quote
Spray the area you're cutting with shaving foam and get on.
I don't give a fuck what any HSE advice says, I did this 3 years ago and I haven't died yet.
arry
PostPosted: 19:32 - 07 Dec 2015    Post subject: Reply with quote
Give us an update in 20 years please.
PostPosted: 19:34 - 07 Dec 2015    Post subject: Reply with quote
If you're prepared to entrust your health to a £2.99 can of shaving foam then fair play.
Personally I'd rather protect myself properly against that stuff. Thumbs Up
RhynoCZ
PostPosted: 19:54 - 07 Dec 2015    Post subject: Reply with quote
Can't you take a sample and ask a local lab? University of some sort should have a lab where they test such a thing. One glance under the microscope and you should know the answer. Wink
Googling around, there are places in the UK, where they perform test for asbestos.
Ribenapigeon
PostPosted: 19:55 - 07 Dec 2015    Post subject: Reply with quote
Local authority website actually recommends shaving foam as a barrier. But not for any substantial removal I think shaving foams just meant for if your drilling through or nailing through.
Ribenapigeon
PostPosted: 20:24 - 07 Dec 2015    Post subject: Reply with quote
There's a guy who used to drive a bin lorry in Glasgow who has the same attitude to H+S.
PostPosted: 20:59 - 07 Dec 2015    Post subject: Reply with quote
Your look out. Thumbs Up
J4mes
PostPosted: 21:25 - 07 Dec 2015    Post subject: Reply with quote
Will do!
Don't hold me to it though. Wink
almostthere
PostPosted: 21:29 - 07 Dec 2015    Post subject: asbestos Reply with quote
Pay the £40 you tight cnut unless your life's not worth that much Middle Finger
or get in touch with the council tell them your too fucking tight to pay for it to be removed they might do it for you
Beer, It's the reason I get up every afternoon
www.mfairco.uk
drzsta
PostPosted: 22:26 - 07 Dec 2015    Post subject: Reply with quote
Asbestos related diseases from cutting a loft access in artex?
I've more chance of dieing from legally obtained substances such as alcohol and tobacco.
MCN
PostPosted: 22:28 - 07 Dec 2015    Post subject: Reply with quote
OP asks a simple question on bcf and is branded 'a tight cunt'. Very Happy
BCF, the forum that keeps on giving.
andyscooter
PostPosted: 08:38 - 08 Dec 2015    Post subject: Reply with quote
he has also been known as a right cunt as well Laughing
grr666
PostPosted: 11:35 - 08 Dec 2015    Post subject: Reply with quote
Past tense?
The last post was made 10 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 128.31 Kb
