Nobcat is poorly :(
CaNsA
PostPosted: 17:34 - 08 Dec 2015    Post subject: Nobcat is poorly :( Reply with quote
The driver has detected that device \Device\Harddisk1\DR1 has predicted that it will fail. Immediately back up your data and replace your hard disk drive. A failure may be imminent.
Windows Disk Diagnostic detected a S.M.A.R.T. fault on disk M4-CT128M4SSD2 (volumes C:\). This disk might fail; back up your computer now. All data on the hard disk, including files, documents, pictures, programs, and settings might be lost if your hard disk fails. To determine if the hard disk needs to be repaired or replaced, contact the manufacturer of your computer. If you can't back up (for example, you have no CDs or other backup media), you should shut down your computer and restart when you have backup media available. In the meantime, do not save any critical files to this disk.
PostPosted: 17:41 - 08 Dec 2015    Post subject: Reply with quote
Bad feline aids?
CaNsA
PostPosted: 17:45 - 08 Dec 2015    Post subject: Reply with quote
too many bytes written-itus
budget of around £100-£140
Recommendations?
PostPosted: 18:08 - 08 Dec 2015    Post subject: Reply with quote
Put Nobcat to sleep. Get a Nobdog.
techathy
PostPosted: 19:24 - 08 Dec 2015    Post subject: Reply with quote
Intel Pro 2500 180GB or possibly 240GB
Sload
PostPosted: 19:25 - 08 Dec 2015    Post subject: Reply with quote
Which drive plopped on you, is it a red?
Edit: Muppets should read the smart report....
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
CaNsA
PostPosted: 19:32 - 08 Dec 2015    Post subject: Reply with quote
I'm thinking...
https://www.amazon.co.uk/dp/B00LMXBOP4
techathy
PostPosted: 19:36 - 08 Dec 2015    Post subject: Reply with quote
CaNsA wrote:
Not a bad choice, just found Intel Pro series SSDs to be that little bit more resilient than Samsung, OCZ & Kingston at work.
wots
PostPosted: 20:31 - 08 Dec 2015    Post subject: Reply with quote
https://www.ebuyer.com/665519-sandisk-ultra-ii-480gb-2-5inch-sata-iii-ssd-sdssdhii-480g-g25
Bought one of these last week when they were £95. Crystal Disk Mark 550/500 on the fastest of the tests.
CaNsA
PostPosted: 20:42 - 08 Dec 2015    Post subject: Reply with quote
Looks good, but their customer service is awful.
I had a rant thread about it a few months ago when one of their sdcards failed.
PostPosted: 20:53 - 08 Dec 2015    Post subject: Reply with quote
Yeah but they're not as bad as overclockers. Razz
wots
PostPosted: 20:58 - 08 Dec 2015    Post subject: Reply with quote
Buy from Amazon then, as it happens, it's cheaper.
https://www.amazon.co.uk/SanDisk-SDSSDHII-480G-G25-Ultra-2-5-inch-Internal/dp/B00M8ABFX6/ref=sr_1_1
barrkel
PostPosted: 21:35 - 08 Dec 2015    Post subject: Reply with quote
A year ago, I would have said to not trust anyone but Intel or Samsung for SSDs.
I'm not longer as plugged into the hardware market, but if it was my money, I'd still wouldn't go anywhere else.
(I definitely would never have bought the Cruical M4. I've heard too many bad stories.)
techathy
PostPosted: 21:58 - 08 Dec 2015    Post subject: Reply with quote
I'd say that still holds true except for OCZ. The rest of the market seems to struggle for performance consistency & reliability. Intel give you industry leading reliability & performance consistency. Samsung is in the middle ground between performance, reliability & consistency. While OCZ holds the performance crown but their drives need a bit of active TLC on the OS to keep them on top of their game.
J.M.
PostPosted: 00:09 - 09 Dec 2015    Post subject: Reply with quote
I had the opposite when my 32gb MicroSD failed.
I'd had it over a year as I'd forgotten about it for ages after it failed. Sent them a long rant about the fact that they're the only branded flash storage that I owned (and didn't buy for a few ponds on ebay) and they're the only one that's failed. Got a replacement sorted for free, just took a week or two to arrive.
I bought all of my other flash storage (usb) really cheap because I didn't care if they died. I had backups.
2004 R1 & 2018 XSR900
CaNsA
PostPosted: 00:47 - 09 Dec 2015    Post subject: Reply with quote
The Crucial M4 has been flawless up to now.
But over 4yrs of 24/7 use in a winbox as a o/s drive.... I think it's done pretty well.
It may not actually be failing, but I'll replace it and bump it to less critical role.
I have an Intel 520 120gb in the laptop, runs fine but gets much less use.
Spunked for the Samsung 850 500gb EVO, should be here within 24hrs.
Addition. OCZ was bought out by Toshiba a few years ago when OCZ filed for bankruptcy.
Sload
PostPosted: 01:03 - 09 Dec 2015    Post subject: Reply with quote
Same, m4 in my main comp has been flawless and fast. Probably middle aged by now.
UncleFester
PostPosted: 08:30 - 09 Dec 2015    Post subject: Reply with quote
Also got one of those M4 drives and as above, its been fine. Got a few of those Samsung 850 drives too and they're lovely and quick.
The only ones that have failed for me ( multiple times ) have been made by OCZ.
2017 Z1000SX
orac
PostPosted: 11:18 - 09 Dec 2015    Post subject: Reply with quote
this is interesting, not heard much about SSDs failing as yet. I haven't use any due to not being able to afford to build a new rig as yet (will be holding off until DDR4 now).
mechanical hard drive failure is fairly rare,
I did find this which is an interesting read on the endurance of ssds
https://itblog.sandisk.com/ssd-endurance-speeds-feeds-needs/
this I found of interest and may affect the way drives are purchased for purposes of endurance
SSD endurance is commonly described in terms of full Drive Writes Per Day (DWPD) for a certain warranty period (typically 3 or 5 years). In other words, if a 100GB SSD is specified for 1 DWPD, it can withstand 100GB of data written to it every day for the warranty period. Alternatively, if a 100GB SSD is specified for 10 DWPD, it can withstand 1TB of data written to it every day for the warranty period. Another metric that is used for SSD write endurance is Terabytes Written (TBW), which is used to describe how much data can be written to the SSD over the life of the drive. Again, the higher the TBW value, better the endurance of the SSD. What’s important to be careful about in this endurance specifications is the methodology used to determine these values. For example, the shorter the warranty period, the higher the DWPD will be for that specific SSD. Or larger the SSD drive capacity, higher the TBW for that specific SSD. In fact the JEDEC Solid State Technology Association’s standards subcommittee has now published two standards to help both SSD vendors and customers determine SSD endurance specifications for typical application usage.
Obviously, the higher the endurance the longer your drive will be able to operate and the more data it will be able to have written to it. Sounds simple enough, doesn’t it? The trick isn’t in searching out the biggest number, but rather in understanding what you need and finding the solution that meets those needs without over-buying.
I am surprised that drives aren't made slightly larger (with the same capacity) with ICs in reserve that can replace damaged ICs on the fly. granted it would increase cost but could dramatically increase the lifespan of a drive and reduce the risk of data loss.
CaNsA
PostPosted: 13:30 - 10 Dec 2015    Post subject: Reply with quote
https://i.imgur.com/ds2lyLBl.jpg
https://i.imgur.com/DdC4hLcl.png
Seb
PostPosted: 20:10 - 10 Dec 2015    Post subject: Reply with quote
Might be time to put that 5315 out to pasture too Neutral
2010 Triumph 1050 Sprint ST
CaNsA
PostPosted: 20:16 - 10 Dec 2015    Post subject: Reply with quote
Never!
It's just a TS client really.
Spends most of it's time doing nothing, or RDP'd to NobCat.
PostPosted: 21:53 - 11 Dec 2015    Post subject: Reply with quote
A general non teccy question.
I have only had bog standard mechanical hard drives and only ever had 2 failures in all the years so I don't regard them as a problem reliability wise and you can get silly sizes for pennies now.
Are SSD's purely about the access speed. Would you recommend replacing a hard drive with SSD when 95% of my computer usage is web or microsoft office or are they purely for games?
Can you mix SSD and hard drives in a tower or does it revert to the slowest component and therefore pointless?
techathy
PostPosted: 22:38 - 11 Dec 2015    Post subject: Reply with quote
Yes, especially if your system is a little light on RAM.
Yes, the interface is universal you can mix and match as you please. There is no performance penalty on the faster drives as each drive gets its own dedicated interface. Actually a mix of smaller fast SSDs for system, applications & scratch space then large rotational hard drives for mass storage is a fairly common setup.
The last post was made 10 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 123.81 Kb
