Fitted a Scorpion
Dav1son
PostPosted: 18:37 - 11 Dec 2015    Post subject: Fitted a Scorpion Reply with quote
Evening all,
Bought myself a little S/S Tagma for my 2010 GSXR 750 and fitted it this afternoon.
I had to remove the OE gasket on the link pipe as the can wouldn't go over it so its sealed metal to metal with the clamp over the top.
Though the clamp is tight and in the middle of the slotted area it isn't causing enough nip to hold the can on the sleeve.
Any suggestions for clamping this better, exhaust paste seems an option as a gasket would have to very thin.
Thanks
Dav1son
SQL
PostPosted: 19:43 - 11 Dec 2015    Post subject: Reply with quote
Silicon never exhaust paste
MCN
PostPosted: 19:52 - 11 Dec 2015    Post subject: Reply with quote
Best I could claim at short notice.
As you tighten the clamp try tap tap tapping the clamp to help it snug into the can. These are 'slip on' and can move a little.
There shouldn't 'really' be any need for any sealant and the gas will suck air into the joint (venturi effect) rather than blow out.
Dav1son
PostPosted: 20:30 - 11 Dec 2015    Post subject: Reply with quote
It didn't pass any gases when putting my hand over the outlet. Just not happy with the movement as the hanger is doing all the work of stopping it's twisting or pulling off.
Will look at removing it and either opening up the tines to fit the OE gasket or closing them in for a tighter fit on the link pipe.
PostPosted: 20:31 - 11 Dec 2015    Post subject: Reply with quote
That's the job of the hanger. To support the can. If it's not leaking gas it's fine.
mudcow007
PostPosted: 22:08 - 11 Dec 2015    Post subject: Reply with quote
i couldn't get a clamp to fit my scorpion either
i ended up siliconing (that a word) on, hanger is solid an doesn't seem to be leaking
The last post was made 10 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 3.85 - MySQL Queries: 13 - Page Size: 47.58 Kb
