Help with CG 125 - CAFE RACER STYLE
Joni_H
PostPosted: 19:04 - 12 Dec 2015    Post subject: Help with CG 125 - CAFE RACER STYLE Reply with quote
Hey all I've recently just passed my CBT I've brought a CG 125cc 98 REG... To practice on for a year before I do my direct access, now as you'd expect the CG isn't in pristine condition and I'm looking to change the following -
1/ rectangular light
2/ petrol tank ( MORE OF A CAFE RACER STYLE )
3/ the seat
4/ handle bars
5/ indicators
6/ colour of the fairings ...
7/ different exhaust style
8/ service
9/ change speedo
So as you can see I'm pretty much looking to go for a cafe racer style, my main question would be what other petrol tank will suitably fit my CG125?
Has anyone got any tips for me to help transform my CG please? NO SARKY COMMENTS PLEASE... Thanks everyone. Very Happy
wristjob
PostPosted: 20:36 - 12 Dec 2015    Post subject: Reply with quote
do number 8 in your list then stop messing about.
Kal
PostPosted: 21:29 - 12 Dec 2015    Post subject: Reply with quote
Won't be cheap. What's your budget.
Kal...
Kal
Kal...
Tierbirdy
PostPosted: 21:31 - 12 Dec 2015    Post subject: Reply with quote
Doing your DAS next year?
Save the money you'd waste on butchering a perfectly good CG and put it towards your DAS.
This will have the bonus effect of not killing the resale value of your CG when you come to sell it for a bigger bike.
PostPosted: 22:11 - 12 Dec 2015    Post subject: Reply with quote
Yes, we do need to know the answer to this question: do you have more money than sense?
wristjob
PostPosted: 00:23 - 13 Dec 2015    Post subject: Reply with quote
1st post on this forum and no response in 5 hours?
i say its a sock
Kal
PostPosted: 00:38 - 13 Dec 2015    Post subject: Reply with quote
Or not happy we weren't over whelmed.
Kal...
M.C
PostPosted: 00:58 - 13 Dec 2015    Post subject: Reply with quote
You can get bits and even completed bikes on eBay. I'm inclined to agree with the consensus that it isn't the best use of time/money, and you'd be better off putting the money towards your DAS.
PostPosted: 01:29 - 13 Dec 2015    Post subject: Reply with quote
You can practise for a year before doing DAS, or you could do you DAS now and then practise for a year.
Make a CG125 cafe racer thing if you want to, it's got nothing to do with doing DAS. Thumbs Up
If you want to transform it, fill it up with petrol and go ride it. That's not a sarky comment, it's a suggestion based on the assumption that you've got an interest in riding motorcycles.
Joni_H
PostPosted: 10:25 - 13 Dec 2015    Post subject: Reply with quote
Okay I see everyone's perspectives, maybe I'll just spray it, which isn't much at all to do, I've already taken the fairings off , and as I was in the car and body trade previous to my current job it should be a doddle,
So leading me back to a similar question how do you take off the petrol tank I can see a bolt at the bottom, but surely that can't be the only thing holding the tank on ? Lol
As for servicing my list would be -
Oil change
Filter change
Clean chain ( what would you use to get the muc off)
Spark plug ( any one have the code for the exact one I'd need ? )
Can you recommend anything else in the service please ?
Thanks all...
PostPosted: 11:40 - 13 Dec 2015    Post subject: Reply with quote
Yup, one bolt. There are two semi-circular mounts at the front. With the rear bolt removed the tank will lift up at the back and you can then pull it rearwards and up off the mounts.
This is a very useful resource for the CG, covering most maintenance and fault finding:
https://hondacg125.awardspace.com/servicing.htm
I really would suggest that unless you're prepared to throw the bike away that you leave it standard. CGs have a "bulletproof" mystique about them and may even start to increase in value - if left unmeddled.
Joni_H
PostPosted: 12:35 - 13 Dec 2015    Post subject: Reply with quote
Yeah I'll probably keep it pretty standard just have it sprayed black and re-decal the Honda emblem. This way like most of you have said the resell will be 100x easier once I've done my DAS course..
I have got a slight problem with the headlight though, doesn't seem to want to work, and I've heard that I've got the dreaded 6V wiring 👎 what's the first source of elimination to the problem please ? Sorry about the 21 questions but I am a complete novice and would like to attempt most of the work myself.
Any help would be greatly appreciated!
PostPosted: 12:52 - 13 Dec 2015    Post subject: Reply with quote
It'd have to be really old to have 6V. UK models went to 12V in 1985.
1995 saw electronic ignition rather than contact breakers.
2001 got electric start.
2004 got a front disc brake and fuel gauge but lost the chain casing (booo).
First port of call for any electrical problem is to spend £5 on a basic multimeter and then watch a few "how to use" videos on YouTube. It takes most of the guesswork out and will save you a lot of time and money.
Actually the first port of call for a headlight is to take the bulb out and see if the filament has blown. Wink
Kal
PostPosted: 17:12 - 13 Dec 2015    Post subject: Reply with quote
I miss my CG Smile
I agree with everything Roger has said. How tatty is your paintwork, and to echo just how old is your CG
The question I really wanted to ask is, is the headlight not working at all or is it just really feeble.
If it's that the light is really feeble then it's probably working to capacity, I remember a certain a mount of guesswork in riding at night.
Kal...
pdg
PostPosted: 10:57 - 14 Dec 2015    Post subject: Reply with quote
Don't paint it black.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Val
PostPosted: 19:15 - 16 Dec 2015    Post subject: Reply with quote
I assume you have not clicked the link from previous Rogeborg's post regarding the servicing.
Here it is again pointing to the headlight bulb change procedure Very Happy
https://hondacg125.awardspace.com/servicing.htm#How-to-replace-the-Headlight-Bulb
mudcow007
PostPosted: 15:42 - 17 Dec 2015    Post subject: Reply with quote
I miss my little CG aswell, I sold it when a builder drove past in a van taking the piss outta me Rolling Eyes
The last post was made 10 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 96.75 Kb
