NO LIGHTS HAD FOR A WEEK
lapras83
PostPosted: 19:13 - 15 Dec 2015    Post subject: NO LIGHTS HAD FOR A WEEK Reply with quote
hi my motorbike honda cbf 125 lights have stopped working, both front main and rear tail light, all indicators and brake lights work. just popped into a shop for ten mins started it up and nothing after any help would be appreciated many thanks G
DRZ4Hunned
PostPosted: 19:14 - 15 Dec 2015    Post subject: Reply with quote
Fuse
DRZ400-SM
FZS600
kerr
PostPosted: 19:15 - 15 Dec 2015    Post subject: Reply with quote
Have you checked the fuses?
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
lapras83
PostPosted: 19:16 - 15 Dec 2015    Post subject: Reply with quote
Changed main fuse and three side ones in case on left hand side under fairing all 10amp still nothing was advised the lights and panel lights worked on the right hand side fuse under fairing changed still nothing was a lil white corrosion around bottom on old fuses????
Hahadumball
PostPosted: 19:20 - 15 Dec 2015    Post subject: Reply with quote
make sure its the headlight fuses you're changing, some have separate fuses in different places.
get a battery tester and check continuity on the wiring.
check bulbs
check ignition.
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
lapras83
PostPosted: 19:27 - 15 Dec 2015    Post subject: Reply with quote
i have a multimetre and very basic knowledge off electrics, im a mechanic man lol wouldnt know where too start, i appreciate all help so far thank you
Hahadumball
PostPosted: 20:11 - 15 Dec 2015    Post subject: Reply with quote
do the lights do anything when you put the parking lights on by turning the key just past the lock position?
Get the wiring diagram and take a look... https://s574.photobucket.com/user/hmmmnz1/media/Honda/cbf125COLOUR.jpg.html?t=1312325525
This is a quick idiots guide to finding an electrical issue in the loom providing youve checked ALL the fuses and bulbs.
So you have no rear light but indicators all work
indicators need 2 wires to function, below is the wiring for your rear light and indicators, they all share the green wire so that is ruled out as both indicators work
this leaves 2 wires that could be the problem yellow/green and yellow, so move to the front wiring and find the yellow/green and yellow, find where they meet up and what they connect to and go from there checking for damaged wires or plugs.
https://i.imgur.com/My8zhuA.png
So.. trace the wires to something significant
the big grey highlight (yellow wire) goes back to... the handlebar switch.. the green/yellow goes to the switch for the front and rear levers to illuminate the brake light so its not that.
from the handlebar switch for the lights is sidelight (small bulb in headlight) and then another wire (pink highlight) for the actual headlight bulb itself.
So from this what do we get?
https://i.imgur.com/jbGu6bu.jpg
lapras83
PostPosted: 20:49 - 15 Dec 2015    Post subject: Reply with quote
side stand switch?
Hahadumball
PostPosted: 21:13 - 15 Dec 2015    Post subject: Reply with quote
lights will still come on regardless of whether the side stand is up or down
SIG1981
PostPosted: 21:58 - 15 Dec 2015    Post subject: Reply with quote
behind left hand front indicator is wiring for front , clocks etc. check connections are in and ok , unplug and plug back in. also pull the square black diode out and check its not green at terminals ( in with wiring behind indicator ) and refit.
wiring known to break behind horn ( under left hand side of petrol tank at front where it cable tied to frame ( although normally causes to cut out ).
last thing is earth block behind left hand grey panel or reg / rec wiring behind left hand side of rear panel which are also known to rot.
edit - starter switch may be sticking when pressed - spray with wd40 and press a few times ( when starter is pressed lights turn off until released )
cb1rocket
PostPosted: 15:44 - 16 Dec 2015    Post subject: Reply with quote
Stator has gone kaput, commonm problem
sgtcalle
PostPosted: 16:11 - 22 Dec 2015    Post subject: Reply with quote
See my thread here: https://www.bikechatforums.com/viewtopic.php?t=308490
Exact same problem as you, fixed (in my case) by replacing stator which had some burnt windings. Take your left hand engine case off and take a look at your stator, if any of the windings are fried, replace it. Remember to have your bike on the centre stand when you do this or it'll leak a load of oil.
CBR600F '02
Manchester
The last post was made 10 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 70.79 Kb
