CBF125 Idle Speed Screw Location
Snop Doog
PostPosted: 01:24 - 17 Dec 2015    Post subject: CBF125 Idle Speed Screw Location Reply with quote
~2009 Honda CBF 125
I have yet to buy a manual for this bike because I'm poor.
Anyway, nothings wrong with the bike, well there might be but it doesn't really bother me. But now that I've mentioned it I may as well explain it.
Ever since I've had the CBF its lights (dash, headlight, tail lights) dim and brighten up very quickly in the same fashion that the engine idles. Everything's fine when the bike idles after it has a cold start up as the RPMs are relatively higher but once it settles the lights do their thing. I've got two other friends with CBFs, ones a 2008 model and the other's a 2015 model. They both do the exact same thing. This leads me to believe that they all do it and it's got something to do with the fact that this bikes lights are powered by the alternator?
The main purpose of this thread was to see if there are any CBF owners who know the location of the idle screw as the only YouTube comment I found about it didn't really help me.
A picture of it would be greatly appreciated.
TL:DR: Anybody got a picture of the CBF's idle screw? - Google, YouTube and my brain haven't helped me.
ForestRunner
PostPosted: 08:24 - 17 Dec 2015    Post subject: Reply with quote
There isn't one.
Fuel injected. The lambda sensor is on the front of the engine near the horn.
IIRC this can cause problems with idle and feeling in general.
Slowly learning...
CBF125 Red (Stolen) -> CBF125 White -> 1999 Hornet
Snop Doog
PostPosted: 00:20 - 18 Dec 2015    Post subject: Reply with quote
ForestRunner wrote:
There isn't one.
Thanks!
Hmm, that's great. So the CBF's idle speed can't be adjusted?
Also, what can cause problems with idle and feeling?
finniee
PostPosted: 01:47 - 20 Dec 2015    Post subject: Reply with quote
I thought something was dodgy with my cbf lights when I first got it.
I took it down to the wall when it was dark and let it idle, then I applied a little bit of throttle and the lights got brighter.
Honda CBF125
Taught2BCauti...
PostPosted: 11:37 - 20 Dec 2015    Post subject: Reply with quote
You probably can't adjust the idle-air mixture, but there should be a throttle stop screw somewhere on the throttle body to adjust the idle speed.
Remove the right-hand cover and have a look at the throttle body, and you should be able to see a small hex-headed screw with a lock-nut that adjusts the position where the throttle valve (butterfly valve) comes to rest.
There are other things that can affect the idle speed on those though - so remove and check your spark plug to see if it running lean or rich, and check your air filter.
Valve clearances are also known to cause idle speed problems.
You might get better help from a specific forum or blog - try This One.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
PostPosted: 13:48 - 20 Dec 2015    Post subject: Reply with quote
Have a gander at this guy's blog - he's done a fair bit on his CBF125 :-
https://www.bikesandtravels.com/biker.aspx?ride=488
Snop Doog
PostPosted: 18:42 - 20 Dec 2015    Post subject: Reply with quote
Thanks for the replies!
I mean, there's nothing wrong with the way the bike idles, I just wanted to have a play around to see if I could get the lights to stop being so difficult.
It seems finniee's got the same problem (if it is a problem?) that I have.
Seeing as my bike doesn't have a tachometer, I can't tell if it's running to slowly or too quickly in the first place. I mean, I could make a sound recording of the engine if that helps.
finniee
PostPosted: 19:45 - 20 Dec 2015    Post subject: Reply with quote
Its not a problem, just the way it is I suppose.
https://images.mcn.bauercdn.com/upload/253776/images/14honda-cbf125.jpg
I'm guessing this is what your dash looks like.
Honda CBF125
Snop Doog
PostPosted: 19:48 - 20 Dec 2015    Post subject: Reply with quote
Yep, except only one light works as I only replaced the Speedo's dashlight as none of them worked when I bought it Laughing
finniee
PostPosted: 20:05 - 20 Dec 2015    Post subject: Reply with quote
You could go up in 10s for every gear like you do in a car to be honest.
Honda CBF125
Snop Doog
PostPosted: 21:22 - 20 Dec 2015    Post subject: Reply with quote
Why would I do that? I have no issue changing gears? Lol.
finniee
PostPosted: 22:14 - 20 Dec 2015    Post subject: Reply with quote
re-read your last post about your unsure if its running too slow or quick. My mistake I thought you ment how were you suppose to change gear like rpms. If you make a sound recording I should be able to help.
Honda CBF125
Snop Doog
PostPosted: 00:24 - 21 Dec 2015    Post subject: Reply with quote
No worries. Yeah I'll make a sound recording tomorrow.
PostPosted: 00:25 - 21 Dec 2015    Post subject: Reply with quote
Can I be the first to say. "If it aint broke, don't fix it.".
Doesn't sound like anything is broke to me so put the screwdriver down and step away from the vehicle.
Snop Doog
PostPosted: 02:07 - 21 Dec 2015    Post subject: Reply with quote
But... Sad
The last post was made 10 years, 292 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 90.21 Kb
