PC, bad grounding...
RhynoCZ
PostPosted: 21:32 - 18 Dec 2015    Post subject: PC, bad grounding... Reply with quote
Today, I was cleaning my old Q6600, after I was done, I plugged all back in, turned it on, but forget to plug in my PC speakers. When I touched the jack (the amp was off), so I could plug it in, while having my hand on the PC case, I got a small electric shock from the tip of the 3.5mm jack. With my hand off the case, it doesn't do it.
What's going on here? Thinking
Everything works as it did before, by the way. I do not recall this happening before.
doggone
PostPosted: 22:42 - 18 Dec 2015    Post subject: Reply with quote
You could see what happens if you touch the plug while grounded on a different metal object?
RhynoCZ
PostPosted: 23:27 - 18 Dec 2015    Post subject: Reply with quote
No, can't do. Everything else around me is either in wood or plastic.
CaNsA
PostPosted: 23:35 - 18 Dec 2015    Post subject: Reply with quote
if i touch the jack for my pc speakers I hear a buzzing and sometimes a crackle.
there's static everywhere and the speakers are sensitive enough to pick it up.
stop yer bitching.
ThoughtContro...
PostPosted: 00:13 - 19 Dec 2015    Post subject: Reply with quote
There's a difference between noise like mains hum caused by ground loops and enough voltage to cause a shock. The former is a PITA, especially if you're running a DAW, the latter is potentially dangerous.
You have your finger on the tip of a 3.5mm jack of mains powered speakers and another hand on the PC case? That sounds like your speaker system has a problem. Use a multimeter on AC to measure any voltage present. If your PC case had large stray AC or DC voltages present then I'd expect it to fry components.
Incidentally dangerous voltages and using hands as the test probes is the worst thing to do. If there is anything nasty it would travel straight through your heart.
Prize cunt
The last post was made 10 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 43.82 Kb
