CBF125 Brake Pedal Angle
MKJ
PostPosted: 12:11 - 10 Dec 2015    Post subject: CBF125 Brake Pedal Angle Reply with quote
Recently bought a cbf125, with a scorpion exhaust fitted (don't really understand why). The brake pedal is very high, so much so that I must lift my foot 6 inches or so off the footrest to press the brake. How would I go about adjusting this, can I remove it and replace it at a different angle, or will I have to bend it? Very new to bikes so any help would be greatly appreciated
Thanks
PostPosted: 12:16 - 10 Dec 2015    Post subject: Reply with quote
Most are adjustable but in different ways. On my TDM I undo the bolt holding it on pull it off the splined shaft (snigger) and rotate it to a different position.
A picture of the lever would help.
PostPosted: 13:47 - 10 Dec 2015    Post subject: Reply with quote
https://www.bike-parts-honda.com/pieces-honda-detail-30158-17KWF901-CBF125MA-2010-F__1900-CBF+125.html
https://www.bike-parts-honda.com/thumbs/h/motog/17KWF901/IMGE/720_280/F__1900.jpg
Hmm, I can't tell if part 21 is an adjustable stop-screw limiting the travel of the lever, or if it's holding the pedal in place in the lever. Either way, see if you can find it and figure out what it does: either turn it to adjust the pedal height, or undo it to remove and re-orient the pedal.
After you adjust the pedal (or to give yourself some slack to do so) you'll want to adjust the tension in the cable and brake arm at the rear of the cable as shown here: https://www.youtube.com/watch?v=ZzEjZdbV9qo
PostPosted: 13:56 - 10 Dec 2015    Post subject: Reply with quote
Rogerborg wrote:
Hmm, it looks like a simple lever...
https://www.motorcycleproducts.co.uk/images/540529.jpg
... and threaded end on a cable at the drum...
Is there a lot of travel in the pedal before the rear brake engages? Or is the rear brake binding at all? If so, adjust it at the rear of the cable as shown in that video.
However, if the pedal is just sitting high, and it's not obviously bent, and the brake is engaging just fine, then... I'm not sure. It doesn't look splined. What is it attached to at the front end of the cable, and how?
Pics oot fur the lads.
The end of it is splined, it's the other way to my TDM where the lever is female.
I'm guessing there is an arm that attaches to the lever the other side of the mount, there'll be a bolt on it, take that out pull it off and readjust it correctly.
PostPosted: 14:07 - 10 Dec 2015    Post subject: Reply with quote
Yup, it's splined, here's a better picture.
https://images.wemoto.com/full/LEVER_BRAKE_HONDA/10021003.jpg
OK, easy peasy then, bolt 21 will be sitting in the groove between the splined parts and holding the pedal in place. Remove that bolt and the pedal will pull straight out, rotate it to where you want it, push it back in and replace the bolt. No need to touch the adjustment at the rear, although you may want to check it while you're at it.
Suntan Sid
PostPosted: 14:54 - 10 Dec 2015    Post subject: Reply with quote
You're right, however it's all dependent on what position the rear break arm has been fitted to the splined shaft on the rear brake cam.
If this is not lined up, with the mark on the brake cam, you'll never get the correct pedal height/angle with enough movement!
The set up in the diagram is, as near as damn it, the same as my XL125.  I can guarantee if you don't line up the punch mark on the rear brake cam/actuator you will never align the pedal, I know this from personal experience.  During my rebuild, I didn't realise this and spent, fcukin', ages trying to line everything up.
OP, you need to check the alignment of the arm on the rear brake cam/actuator arm!
MKJ
PostPosted: 16:20 - 10 Dec 2015    Post subject: Reply with quote
Thanks for the replies all, will take a good at it. I fear that the reason it is at this angle is because of the Scorpion exhaust means the pedal will foul it. When I get home will upload some pics and let you all know how I get on (and then probably return with more questions lol) Thanks again all Smile
MKJ
PostPosted: 17:34 - 19 Dec 2015    Post subject: Reply with quote
So, first chance I've had to have a good look. I've removed the pedal and had a look. The reason the pedal was too high seems to be the piece of metal under the footpeg, that stops the pedal rising was bent very high. I've bent this down and seems to have solved the problem. Am trying to put the pedal back in, but think I might have bent the spline a bit, it won't properly go in Sad Have had enough for today, will look at it tomorrow. I can get the pedal inbetween the two splined bits, but can't knock it entirely in. Extremely frustrating
PostPosted: 20:25 - 19 Dec 2015    Post subject: Reply with quote
https://www.tinygif.com/data/media/12/stop-hammer-time.gif
Give it a wiggle, give it a whack, it'll go back in.
MKJ
PostPosted: 13:20 - 20 Dec 2015    Post subject: Reply with quote
Haha, thats what I've been trying. I think I've widened the actuator a bit too much
PostPosted: 15:38 - 20 Dec 2015    Post subject: Reply with quote
All these clever little Japanese designers involved in the creation of this wondrous amalgamation of parts and you came along a 'bent a bit' Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 15:41 - 20 Dec 2015    Post subject: Reply with quote
Take the bolt out. The splined bit won't go past it. The bolt is supposed to be put in after the splined part is in place
Triumph Sprint ST 1050
MKJ
PostPosted: 15:54 - 22 Dec 2015    Post subject: Reply with quote
Yeah thats what I was trying. I placed the bolt in the actuator, and tightened a lot without the pedal in. This seemed to solve the problem. Took the exhaust off and got the pedal back in no problemo.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:24 - 22 Dec 2015    Post subject: Reply with quote
So where's my fucking karma?
The last post was made 10 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 86.79 Kb
