high idle
Ric
PostPosted: 17:23 - 10 Feb 2005    Post subject: high idle Reply with quote
bit of a minor issue
but the bike gets stuck idleing at 2k revs
then drops dunno whats doin it
also its very black around my exaust exit
what can this mean?
Scotsman37
PostPosted: 18:21 - 10 Feb 2005    Post subject: Reply with quote
Have you oiled your choke cable as it maybe rusted up !
Jrod
Page 3 Girl
PostPosted: 01:25 - 12 Feb 2005    Post subject: Reply with quote
I have the EXACT same thing!!! Hm any help would be good Confused
Git
PostPosted: 01:35 - 12 Feb 2005    Post subject: Re: high idle Reply with quote
what can this mean?
You need some loo roll??
sorry, that was not much help was it Laughing
I'm not that hot with carbs but like above, could the choke be stuck on a bit, that would make the bike idle a bit high and also give you a black exhaust I would think.
Dirty air filter?
Not sure Confused
fazed
Korn is my hero!
PostPosted: 02:36 - 12 Feb 2005    Post subject: Reply with quote
get the carb's cleaned needles , slide's etc. , Something is sticking when u close the throttle.
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
Jrod
Page 3 Girl
PostPosted: 02:41 - 12 Feb 2005    Post subject: Reply with quote
Only had my carbs cleaned about 3 months ago. (put it on reserve only to block them up Thumbs Down )
It's not really bad just sometimes it stays at 2k then will drop to 1.5 after a few secs, don't know if rics is the same?
fazed
Korn is my hero!
PostPosted: 02:46 - 12 Feb 2005    Post subject: Reply with quote
Might just be a bit of fuel getting through then .
Flip
PostPosted: 17:05 - 12 Feb 2005    Post subject: Reply with quote
Mine does exactly that. Thumbs Up
https://www.bikechatforums.com/viewtopic.php?t=41166
loply
PostPosted: 17:48 - 12 Feb 2005    Post subject: Reply with quote
When my bike is on choke it will rev at 3k then when its warmed up it drops (by itself) to 1.5k.
And its carbed. Dunno why it does this exactly, but there yah have it.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Scotsman37
PostPosted: 18:07 - 12 Feb 2005    Post subject: Reply with quote
Is that with the choke remaining on ?
What happens to the engine after it has warmed up and you take the choke off say after 10 - 15min ?
Suggestion: inspect your spark plugs as one or more of them maybe slightly loose and so remove & inspect the threading and tighten them up again properly as that might be causing a loss of compression when the bikes warmed up.
In regards to blackened exhaust it can be the following;
Air filter clogged
Main jet to large or loose
choke cable/linkage shaft stuck: causing fuel to be pulled through choke circuit
fuel level to high
float needle valve held off needle seat: clean the float chambers and fuel line and replace needles and seats if necessary
bish777
PostPosted: 18:13 - 12 Feb 2005    Post subject: Reply with quote
either the choke is stuck or there is an air leak somewhere, check that all clips are tight, all hoses etc are attached, the airbox doesnt have any cracks.
Inspect all rubber bits for accidental screwdriver holes!
The last post was made 21 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 65.96 Kb
