Indicator / sidelight issues
david mcc
PostPosted: 14:19 - 23 Dec 2015    Post subject: Indicator / sidelight issues Reply with quote
Hi all, I've got a 2003 deauville which was been in the garage for 3 weeks but mechanics are struggling to fix fault.
basically when I start up bike the sidelight is on all the time. Indicators work fine and flash as normal. However, when I turn lights on for both sidelight or headlight the indicators stop flashing and stay lit.
Any suggestions? Garage have already replaced indicator relay with no change.
I don't think sidelight should be on when switch is off. is this correct for a 2003 model?
Thanks for any help
David McC
Honda Deauville 650 V3
Taught2BCauti...
PostPosted: 14:53 - 23 Dec 2015    Post subject: Reply with quote
Could be an internal problem in the combination switch, or a bad earth somewhere.
It would help to know if it was like this when you got the bike, or if happened after another event - like you dropped it, changed the bulbs, lent it to a mate, etc.
If the garage replaced something for free, that suggests some sort of warranty - in which case, I would let them get on with it.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
david mcc
PostPosted: 15:07 - 24 Dec 2015    Post subject: Reply with quote
Been like this since I bought the bike in summer 2015. Garage have replaced relay trying to find fault. They weren't the original sellers.
David McC
WD Forte
PostPosted: 16:57 - 24 Dec 2015    Post subject: Reply with quote
3 weeks and a bit of swap and hope?
Not impressed with your mechanics
I assume its the carb version with linked brakes and pre 'always on' lights?
It shouldn't be that hard to find and fix the fault with a meter and relevant wiring diagram but a good start would be to get some switch cleaner and open/check/clean all the multi connectors from the bar switches and squish some the switches too.
bikers smell of wee
The last post was made 10 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 39.47 Kb
