Pillion
Bike Chat Forums Index -> Biking News & Rumours
CKBear This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
The Artist
PostPosted: 21:48 - 27 Dec 2015    Post subject: Reply with quote
Unlikely. Make sure the suspension doesn't compress all the way with you both on and you will be fine.
binge
Emo Kiddy
PostPosted: 23:03 - 27 Dec 2015    Post subject: Reply with quote
Will it be your pillions first time also?
Chuffin Nora
PostPosted: 06:54 - 28 Dec 2015    Post subject: Reply with quote
What's the bike?
What value of lard-arseness are you and they fully togged?
There's a fine line between integrity
c_dug
PostPosted: 09:19 - 28 Dec 2015    Post subject: Reply with quote
I dont think I've ever adjusted the preload for a pillion, I might if I had fancy electronic suspension, or even just an easily accessible preload knob.
Not for 5 miles though, that wouldn't be worth the hassle.
Ichy
PostPosted: 09:23 - 28 Dec 2015    Post subject: Reply with quote
Hard to comment unless you tell us the bike. Small commuter, probably. Large tourer? Nah.
Ichy
PostPosted: 09:29 - 28 Dec 2015    Post subject: Reply with quote
Good question. First time pillions can be a whole new opportunity for fail, especially if they carry some weight. Tell them not to move and be prepared to be headbutted. Make sure you've got your feet really planted when they get on and off.
talkToTheHat
PostPosted: 22:56 - 29 Dec 2015    Post subject: Reply with quote
I found going from 3/5 to 5/5 preload on the old 535 worked the magic of keeping the headlamp aim thereabouts similar. Not been more than 200 yards with same bike and a pillion at 3/5 before convinced more preload required, similarly a ride home solo in the rain at 5/5 was an education in how quickly out of shape the bastard thing got when the suspention topped out. I think with a modern monoshock with a progressive linkage you will have less of an issue.
If it's a multi-position cam thing and you can carry a c-spanner under the seat, consult owner's manual for best guess and crank up some preload. If you have threaded shock body and need to fuck about with a ruler then i wouldnt bother.
Of course if pillion is smaller than dani pedrosa then don't mess around. If pillion looks like he/she/it could eat a 90lb racing snake as a light snack then consult owners manual for max load, max tyre pressures and crank up that preload.
Bandit. does. everything.
CaNsA
PostPosted: 00:08 - 30 Dec 2015    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=221744
https://www.bikechatforums.com/viewtopic.php?t=215384
https://www.bikechatforums.com/viewtopic.php?t=204207
https://www.bikechatforums.com/viewtopic.php?t=256759
CaNsA wrote:
This is the advice i give to everyone who asks the "Pillion" question.
A few points to remember.
1. It will take a bit more throttle to move off,
2. A bit more breaking to stop,
3. Get them to squeeze you with their legs when you break and accelerate.
4. One hand on your waist, one on the grab rail.
5. If they wiggle, slap them.
6. Tell them to look at the traffic ahead and they will learn when you are gonna break and accelerate.
7. Don't wheelie unless you tell them before, cos they will fall off and hurt his/her boobs
8. NO he/she cant use his/her phone while on the bike.
CKBear
PostPosted: 00:19 - 30 Dec 2015    Post subject: Reply with quote
Oops sorry, I have only just logged back on to reply. The bike is a GPZ500, im a bit heavier than average, and she is average build. I plan on just popping up the A25 at around 40mph for around 5 miles. We are both pillion virgins.
Thanks Laughing
CKBear
PostPosted: 00:21 - 30 Dec 2015    Post subject: Reply with quote
And i have NO IDEA why i put this in Biking News....I must have been pissed.
PostPosted: 11:38 - 30 Dec 2015    Post subject: Reply with quote
The rear shocks are saggy from stock, you'll definitely want to have a go at the preload, if it's not seized to buggery.
PostPosted: 13:03 - 30 Dec 2015    Post subject: Reply with quote
I've got nothing better to do and I feel like being a bit of a nob. Razz
4. One hand on your waist, one on the grab rail - Some bikes don't have a grabrail. Some pillions prefer holding around the waist.
Brake.
CaNsA
PostPosted: 13:48 - 30 Dec 2015    Post subject: Reply with quote
https://i.imgur.com/hi4gf3Q.jpg
MCN
PostPosted: 14:41 - 30 Dec 2015    Post subject: Reply with quote
Be careful you don't 'break' too violently. It's an easy noob mistake to make.
Always BRAKE smoothly. Razz
Most important is mounting and dismounting the bike.
It is a more common point of hassle as you cannot avoid it. Smile
Easier on Level ground.
Novice Advice:
Before anyone of you gets on.
Tell the pillion to follow your body movement and not to try to 'lean the bike'. Rolling Eyes They are not Barry Bastart Sheene.
Show your pillion where the pegs are and where to sit.
Show them your pegs too and let them know to keep their plates of meat OFF the rider's pegs (or you'll kick their head in).
1st thing, try to make it clear to your pillion or tell your pillion only to get on when you say to get on. If they just jump on you. may not be ready and you could both end up on the ground.
And you may as well tell them the same rule applies for getting off, when the time comes, that they only get off when you say so.
No loose gravel (it's like ball bearings underfoot).
Bike in neutral or engine off 'Belt and Braces' (engine off is more difficult for kick-started machines).
Hold both handle bar grips AND the front brake.
Both feet on the ground, flat on ground if you can.
Then the pillion climbs aboard.
One hand on your shoulder for steady.
Left foot on left pillion peg.
Carefully swing a leg ower the back of the bike to land on the opposite right side peg. Without pulling the bike over of course. Some folk are genetically clumsy.
If you don't hold the brake, are not on level ground, both feet on the ground then disaster will be more imminent.
When they let you know they are cumfy and holding on you can pull away. No wheelies (yet).
After two or three ons, scoots aboots and offs the whole frigmarole become 'memory moves' for the body.
If they do not enjoy it then un-friend/block them on Facetube and score them off your Christmas list etc.
Have/had fun.
Chuffin Nora
PostPosted: 22:56 - 30 Dec 2015    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?p=4179347&highlight=#4179347
Chuffin Nora wrote:
A fullish tank of fuel at the outset will help to keep the front end planted, and by the time that it's emptyish the other half, if she has the Gift, will have bestowed the trinity of rider-pillion-bike with the Oneness for which Life, the Universe and Everything was invented.
It's Rocket Science!
Initiate The Twang!
Just before they place their left foot onto the left peg, lean the bike a few degrees to the right. This will ensure that at the moment when they lift their right foot -- all of their weight thus bearing down on the left side of the bike -- the bike will swing back to the perpendicular as they swing their arse over and their centre of mass aligns with the bike's wont to be perfectly upright.
Whereas if the bike is perpendicular to begin with, with all of their weight on the left peg, the bike will also therefore tend to (precariously Shocked) lean, thus putting undue pressure on your left leg, with the very real possibility, especially where dodgy ground's afoot, of the imminent pull-away literally biting the dust!
It's worth mentioning also that from the outset the rider's feet ought to be -- on firm ground, at least -- as far out from the bike as is comfortably possible, thus making like an efficient A-frame.
talkToTheHat
PostPosted: 02:14 - 31 Dec 2015    Post subject: Reply with quote
The redhead to my right would like to helpfully suggest that the little straps made of seat-cover vinyl and affixed to some pillion seats are both in the wrong place and stretchier than a good bungee strap, and are thus worse than useless.
The last post was made 10 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 98.91 Kb
