| CKBear |
This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
 CKBear Two Stroke Sniffer
| The Artist |
 The Artist Super Spammer
| binge |
 binge Emo Kiddy
| Chuffin Nora |
 Chuffin Nora World Chat Champion
| c_dug |
 c_dug Super Spammer
| Ichy |
 Ichy World Chat Champion
| Ichy |
| talkToTheHat |
| CaNsA |
 CaNsA Super Spammer
| CKBear |
 Posted: 00:19 - 30 Dec 2015 Post subject: |
Oops sorry, I have only just logged back on to reply. The bike is a GPZ500, im a bit heavier than average, and she is average build. I plan on just popping up the A25 at around 40mph for around 5 miles. We are both pillion virgins.
Thanks  |
| CKBear |
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:38 - 30 Dec 2015 Post subject: |
The rear shocks are saggy from stock, you'll definitely want to have a go at the preload, if it's not seized to buggery. ____________________ Biking is 1/20th as dangerous as horse riding.
| Howling TerrorOutOfOffice |
| CaNsA |
 CaNsA Super Spammer
 Posted: 13:48 - 30 Dec 2015 Post subject: |
| MCN |
 MCN Super Spammer
 Posted: 14:41 - 30 Dec 2015 Post subject: |
Be careful you don't 'break' too violently. It's an easy noob mistake to make.
Always BRAKE smoothly.
Most important is mounting and dismounting the bike.
It is a more common point of hassle as you cannot avoid it.
Easier on Level ground.
Novice Advice:
Before anyone of you gets on.
Tell the pillion to follow your body movement and not to try to 'lean the bike'. They are not Barry Bastart Sheene.
Show your pillion where the pegs are and where to sit.
Show them your pegs too and let them know to keep their plates of meat OFF the rider's pegs (or you'll kick their head in).
1st thing, try to make it clear to your pillion or tell your pillion only to get on when you say to get on. If they just jump on you. may not be ready and you could both end up on the ground.
And you may as well tell them the same rule applies for getting off, when the time comes, that they only get off when you say so.
No loose gravel (it's like ball bearings underfoot).
Bike in neutral or engine off 'Belt and Braces' (engine off is more difficult for kick-started machines).
Hold both handle bar grips AND the front brake.
Both feet on the ground, flat on ground if you can.
Then the pillion climbs aboard.
One hand on your shoulder for steady.
Left foot on left pillion peg.
Carefully swing a leg ower the back of the bike to land on the opposite right side peg. Without pulling the bike over of course. Some folk are genetically clumsy.
If you don't hold the brake, are not on level ground, both feet on the ground then disaster will be more imminent.
When they let you know they are cumfy and holding on you can pull away. No wheelies (yet).
After two or three ons, scoots aboots and offs the whole frigmarole become 'memory moves' for the body.
If they do not enjoy it then un-friend/block them on Facetube and score them off your Christmas list etc.
Have/had fun. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Chuffin Nora |
 Posted: 22:56 - 30 Dec 2015 Post subject: |
https://www.bikechatforums.com/viewtopic.php?p=4179347&highlight=#4179347
| Chuffin Nora wrote: | A fullish tank of fuel at the outset will help to keep the front end planted, and by the time that it's emptyish the other half, if she has the Gift, will have bestowed the trinity of rider-pillion-bike with the Oneness for which Life, the Universe and Everything was invented.
It's Rocket Science!
Initiate The Twang!
Just before they place their left foot onto the left peg, lean the bike a few degrees to the right. This will ensure that at the moment when they lift their right foot -- all of their weight thus bearing down on the left side of the bike -- the bike will swing back to the perpendicular as they swing their arse over and their centre of mass aligns with the bike's wont to be perfectly upright.
Whereas if the bike is perpendicular to begin with, with all of their weight on the left peg, the bike will also therefore tend to (precariously  ) lean, thus putting undue pressure on your left leg, with the very real possibility, especially where dodgy ground's afoot, of the imminent pull-away literally biting the dust!
It's worth mentioning also that from the outset the rider's feet ought to be -- on firm ground, at least -- as far out from the bike as is comfortably possible, thus making like an efficient A-frame. |
____________________ There's a fine line between integrity |
| talkToTheHat |
The last post was made 10 years, 286 days ago. Instead of replying here, would creating a new thread be more useful? |
