Clutch cable lubrication, what kind of lube?
Ribenapigeon
PostPosted: 13:01 - 28 Dec 2015    Post subject: Clutch cable lubrication, what kind of lube? Reply with quote
What lube for cable and any do's and don'ts when lubing up?
Ariel Badger
PostPosted: 13:20 - 28 Dec 2015    Post subject: Reply with quote
If it is nylon lined only use WD40, if it is unlined run 3in1 oil down it.
Ribenapigeon
PostPosted: 16:05 - 28 Dec 2015    Post subject: Reply with quote
How do I tell if its lined or not?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:40 - 28 Dec 2015    Post subject: Reply with quote
Cut it in half and see if there is a plastic sleeve between the inner and outer.
Triumph Sprint ST 1050
dydey90
PostPosted: 19:01 - 28 Dec 2015    Post subject: Reply with quote
[anorak]Ah, but WD40 isn't a lubricant. It's a water displacement agent.[/anorak]
My clutch cable is a bit stiff mind...
iooi
PostPosted: 19:12 - 28 Dec 2015    Post subject: Reply with quote
WD-40® Multi-Use Product protects metal from rust and corrosion, penetrates stuck parts, displaces moisture and lubricates almost anything. It even removes grease, grime and more from most surfaces.
I think the manufacture has the inside info Rolling Eyes Unlike your anorak Laughing
Pigeon
PostPosted: 20:38 - 28 Dec 2015    Post subject: Reply with quote
"It even removes grease"
I wouldn't use it for this reason. It may lubricate briefly, but it doesn't have any staying power and leaves it dryer after a while than before you used it.
temeluchus
PostPosted: 21:02 - 28 Dec 2015    Post subject: Reply with quote
3 in 1 or similar for cables. Dab of grease on exposed cables.
Hahadumball
PostPosted: 21:08 - 28 Dec 2015    Post subject: Reply with quote
ky jelly
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
Old Git Racing
PostPosted: 21:43 - 28 Dec 2015    Post subject: Reply with quote
I take the cable out at the lever end, attach a duct tape funnel about 25 mm high, fill with 3 in 1 oil and leave upright overnight, wipe excess away next morning and reattach cable.
OGR
Nobby the Bastard
Harley Gaydar
PostPosted: 21:51 - 28 Dec 2015    Post subject: Reply with quote
OGR
Old school....
orac
PostPosted: 03:55 - 29 Dec 2015    Post subject: Reply with quote
Silkolene silkopen. It leaves a graphite film on the cables, I go about 12 months between lubing cables with this stuff
PostPosted: 10:43 - 29 Dec 2015    Post subject: Reply with quote
I don't have any Shocked . I actually had to go and have a look!
Hydraulic brake and clutch and fly by wire throttle Thumbs Up
When I did I used one of these
https://tse4.mm.bing.net/th?id=OIP.M782e63ea4ed98f0e94faa7c0f72df096o0&pid=15.1
and this
https://i.walmartimages.com/i/mp/00/68/62/26/80/0068622680070_P321146_500X500.jpg
PostPosted: 14:13 - 29 Dec 2015    Post subject: Reply with quote
I always use 3 in 1. Seems to do the job.
Fizzer Thou
PostPosted: 16:13 - 29 Dec 2015    Post subject: Reply with quote
I use GT85 silicone spray lubricant and one of these.
https://i12.photobucket.com/albums/a201/scotsy/cableoiler_.jpg
Makes the pull a lot smoother Dance!
Always have a 'Plan B'
The last post was made 10 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 86.47 Kb
