What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 160, 161, 162 ... 407, 408, 409  Next
Snod Blatter
PostPosted: 00:38 - 25 Dec 2015    Post subject: Reply with quote
Last Sunday I put the new (to me) K1100 radiator on the K100, and today I filled it up and ran it to see if it leaks. It didn't! Yayyyyy.
https://i.imgur.com/2bVcnpE.jpg
Now to wrestle the bizarre "rubber dam" into the space between the top of the radiator and the frame/gubbins above it, and then wrestle the radiator grille and side panels into an angle where I can get most of the screw holes to line up. It's an awful job..
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
trevor saxe-coburg-gotha
PostPosted: 06:58 - 25 Dec 2015    Post subject: Reply with quote
Norralot - just cleaned it and lubed all pivot points, plus a bit of preserver sprayed into its nether regions, etc. etc. Had an ace time off-roading again yesterday but my god the going was good to soft and often heavy. Been putting off chucking a fresh ac10 on the back and I'm actually sort of glad cos I still enjoyed it a lot (plus my mate's is a fair few mil down on mine and if he can manage I should damn well be able to). Anyway yeah - this's all me klx250. Despite MCN's execrable and almost perversely stupid review of this bike (hint - it's better than the crf250l), it's great for laning. Not fast, nor powerful - but the geometry's great and the suspension excellent. I give it a bit of stick here and there and it really shrugs it off. Anyway, after the pressure hose (useful but mind those bearings), there was still mud in nooks and crannies, and bits of lubing needed - so it all got done yesterday.
fox
PostPosted: 13:00 - 25 Dec 2015    Post subject: Reply with quote
Whacked the battery on the charger after a year out from riding. Planning on giving the Sprint a full service in the new year. Can't wait! Merry Xmas guys Smile
Sold: 2003 satin black Yamaha R6
Current rides: 2006 blue Triumph Sprint ST 1050, 2003 Yamaha WR450F
ADSrox0r
PostPosted: 13:03 - 25 Dec 2015    Post subject: Reply with quote
Hid in the garage and cuddled her to hide from the fucking wailing chaos indoors.
Merry sodding Christmas.
PostPosted: 14:02 - 27 Dec 2015    Post subject: Reply with quote
^^^Difficult to get an accurate measurement using verniers.
A micrometer is better.
It makes sense when you see this.
https://www.youtube.com/watch?v=L2Ik-7FhhxA
ST2 on charge.
https://i104.photobucket.com/albums/m174/howlingterror_2006/15D3C4E5-EB5D-49D4-A1DF-EEEC1BCC7773_zps1htnqc5u.jpg
Oil & filter change on the MV
https://i104.photobucket.com/albums/m174/howlingterror_2006/8494FE3E-6D7C-47C4-AD82-1AE97F4C3F3B_zpsivzcgbtw.jpg
A blob of silicone on that lower exhaust shield bolt as it touches the fairing. Rolling Eyes
https://i104.photobucket.com/albums/m174/howlingterror_2006/54C05ED1-C600-42B5-9495-F421D0A5C39E_zpscc32gjls.jpg
Whosthedaddy
PostPosted: 19:01 - 27 Dec 2015    Post subject: Reply with quote
As the C900rr is gone, the attention is now back to the monkeybike.
As I've had trouble in the past with brackets snapping for the licence plates and lights I've taken the decision to revert back to standard so off came the extended swing arm and back in with stock.
So today was me dismantling the rear of the bike and putting it back on again before a little tootle round the garden.
Next up is getting the fork seals changed and sorting out the insurance on Tuesday then it's back on the road after a 12 month break in the shed.
Pigeon
PostPosted: 19:55 - 28 Dec 2015    Post subject: Reply with quote
Hey dude, Merry Xmas to you & yours too! + Happy New Year!
Can't believe how fast 2015 went.
Will say hello if you Mayday run from Boxhill again. Or wherever etc
Snod Blatter
PostPosted: 21:26 - 28 Dec 2015    Post subject: Reply with quote
The CB250 has been a little less happy than normal recently, particularly when not up to temperature, very particularly on cold mornings. A loss of happiness/sweetness/glance-at-the-starter-button-and-away-it-goesness is usually a sign that the spark plug gaps have become a little too wide. Sure enough, a quick check revealed they were at about 0.75mm when the spec is 0.6-0.7mm. A few taps and they were back in spec, and now all is well again. I like the CB, it's easy.
Next was tracing some strange electrical fault on the CBX250 which has stopped the tail light from working, this is stupid but it also makes it a dangerous bike to ride in these winter months when it almost always seems to be dark. The only other bulb that shares the exact same circuit is the sidelight bulb in the headlight which works fine, and the ground is common to all the bulbs in the tail and they all work fine, so it's surely the feed to the tail light. Bending the wires briefly brought it back to life, but then it stopped again so it's a broken wire.. But as I was pulling the wires out of their holding brackety bits it started to work as it should, and I couldn't stop it from working which makes finding the fault impossible. So I've put it all back together, and it still insists on pretending nothing's wrong. It'll wait until I want to use it in the dark and then stop working again, I know it. Bloody CBX. Or I could cut out and replace that last bit of wire just for peace of mind.. Maybe.
Copycat73
PostPosted: 22:18 - 28 Dec 2015    Post subject: Reply with quote
try replacing the bulb .. it may be two intermittent faults your trying to find.. Thumbs Up
caveat emptor
Matt B
PostPosted: 12:46 - 29 Dec 2015    Post subject: Reply with quote
In fact, I would say totally pointless using verniers. All you are measuring is the lip on the edge of the disc that doesn't contact the pads. It is probably covered in a layer of surface rust too, making it thicker.
Snod Blatter
PostPosted: 18:38 - 29 Dec 2015    Post subject: Reply with quote
My first thought was that the bulb had blown (obviously), so bought a couple of "pothole resistant" replacements from Halfords, as the vibes of the CBX can be harsh. The first replacement I put in didn't work either, which lead me to disconnect it all and check it out with a multimeter but later on I found that bulb never worked anyway! Cheers, Halfords.
At the female bullet connector on the end of the loom I was getting anywhere from nothing to 1.5v, and then suddenly 11.7v because I'd bent the wiring in a different direction. Ah well, whatever.
Pigeon
PostPosted: 21:17 - 29 Dec 2015    Post subject: Reply with quote
Pigeon wrote:
IN 0.10 - 0.20
IN CYL 1 L 0.15
IN CYL 1 R 0.15
IN CYL 2 L 0.10
IN CYL 2 R 0.10
IN CYL 3 L 0.13
IN CYL 3 R 0.12
Re-shimming these up to around 0.17
EX 0.325 - 0.375
EX CYL 1 L 0.25
EX CYL 1 R 0.25
EX CYL 2 L 0.26
EX CYL 2 R 0.25
EX CYL 3 L 0.25
EX CYL 3 R 0.24
Re-shimming these up to around 0.36
Another 4 hours in the garage and all the valve shims have been replaced and the camshafts + tensioner re-installed and clearances re-measured. Very Happy
IN 0.10 - 0.20
IN CYL 1 L 0.18
IN CYL 1 R 0.18
IN CYL 2 L 0.16
IN CYL 2 R 0.16
IN CYL 3 L 0.18
IN CYL 3 R 0.20
EX 0.325 - 0.375
EX CYL 1 L 0.36
EX CYL 1 R 0.36
EX CYL 2 L 0.36
EX CYL 2 R 0.37
EX CYL 3 L 0.38 *
EX CYL 3 R 0.38 *
A touch on the loose side, but considering how faffy it is trying to get a decent measurement, I'm pretty happy so far!
"Just" need to get the cam cover on and get it to the point I can check / balance the throttle bodies. Tomorrows job.
* Slightly worn gauges would let a 0.39 (made up of 0.30 + 0.09 blades combined). I tried a new Sealey angled gauge and 0.354 would go, and 0.381 would not. So I'm guessing it's probably around 0.37, so hopefully not out of spec.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151229_191209.resized_zps0rezam9t.jpg
Tamsin
PostPosted: 23:36 - 29 Dec 2015    Post subject: Reply with quote
i actually did something!
The bike has been chained to a telegraph pole since 18th October Embarassed and it was only running with choke....
So today, I stripped and ultrasonic cleaned the carb, fitted new air filter and carb rubber and the motor seems to run better than ever
The clutch lever is stiff as fook and the chain has rusted up a bit so a bit more work needed before I take her out again though...
kawashima
PostPosted: 12:20 - 30 Dec 2015    Post subject: Reply with quote
Bought this screen and attached.
Much cheaper than Givi and gave me best wind protection. I liked.
https://i21.photobucket.com/albums/b295/kawashima_/asahi-fubo-no99mini-002_zpstdn0dl4n.jpg
own:2020 Serow 250
Tamsin
PostPosted: 14:44 - 30 Dec 2015    Post subject: Reply with quote
I now have a nice clean, well lubed chain and a clutch lever that works. Its the wrong clutch lever and it flaps around in a weird fashion so I knocked up some spacers out of a Morris Minor Thermostat gasket (cork) thoroughly soaked in oil. Its not quite right but will do the job until the new lever arrives.
Pumped up the tyres too, but no time for a ride Sad
PostPosted: 20:12 - 30 Dec 2015    Post subject: Reply with quote
I've had terminal manfluenza, but today managed to drag myself to the garage, tickled, chocked and kicked the Enfield, let it idle for a few minutes, and then turned it off.
I may be about ready for my Harley.
Tamsin
PostPosted: 16:55 - 31 Dec 2015    Post subject: Reply with quote
I did change the clutch lever to the correct type and went for a ride.
There is an annoying buzzing from somewhere up front over 55mph....
andym
PostPosted: 17:42 - 31 Dec 2015    Post subject: Reply with quote
Today I fought with the rear caliper on the ZX Evil or Very Mad
A job that should have taken around 30 minutes ended up taking 90.... but at least the new seals and pads are in, now I just need to fit it back on the bike and bleed it
Skudd
PostPosted: 18:19 - 31 Dec 2015    Post subject: Reply with quote
Started the Cagiva and took it round the block to make sure it was ok.
Adjusted and oiled the chain on the Big Varadero, good job I did as the spindle nut had come loose, I hate nylon locking nuts.
The baby varadero was wheel out and then back in again.
Pigeon
PostPosted: 23:48 - 31 Dec 2015    Post subject: Reply with quote
Bike has been in bits since 5th December, but today she lives!!! Mr. Green
To say I'm happy is an understatement (and relieved!).
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151231_123421.resized_zpswvqxx5hd.jpg
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151231_123431.resized_zpsxvoyizcx.png
Valves re-shimmed, new oil, plugs, oil+air filters, throttle bodies balanced.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151231_143846.resized_zpsfc8z0uyl.jpg
After 3 weeks, I've still not finished the 12k service. Head bearings and rear shock linkages + bearings need stripping & re-greasing. But I'm waiting for a 38mm socket.
Rear calliper needs doing, but as requires removal of wheel am leaving that until the suspension linkage session.
So in the meantime, cleaned the front callipers and freed the 50% non-working pistons (would explain the not so great brakes). Drained + replaced the brake fluid in the reservoir and bled the system.
To be fair, that's 2.25 years, and 11k miles they've not been touched.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151231_180850.resized_zpsdek0av1h.jpg
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151231_172522.resized_zpsmhlrw8uc.jpg
Tomorrow, am actually going for a ride Smile
Happy New Year all! Very Happy
Dabura
PostPosted: 00:40 - 01 Jan 2016    Post subject: Reply with quote
Found a bargain puig fly screen on eBay for £20 so fitted that today and overall I'm happy just wish my headlight would fill the aperture but at least it clears the clocks
Before
https://i.imgur.com/u1J5ygF.jpg
After
https://i.imgur.com/zNxyOZc.jpg
1198
PostPosted: 22:18 - 01 Jan 2016    Post subject: Reply with quote
Today I've bought a battery for my nemesis - the M900. No comments about good money, bad money or throwing money away, or quitting while I'm ahead please!
Raffles
PostPosted: 22:48 - 01 Jan 2016    Post subject: Reply with quote
MrGs1 wrote:
Measured the discs with my new tool but not sure if they are within spec without Googling.
Rear: 30.80mm
Front left: 39.90mm
Front right: 40.67mm
Are they?
According to those figures, they've got loads of life left in them Wink
RhynoCZ
PostPosted: 01:50 - 02 Jan 2016    Post subject: Reply with quote
Left it in the garage and went out to do some rwd stuff on snow in my mate's BMW.
Very addictive. Thumbs Up
The last post was made 10 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT + 1 Hour
Page 161 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 139.52 Kb
