| scooke |
 scooke Borekit Bruiser
| andys675 |
 andys675 World Chat Champion
| scooke |
| Old Git Racing |
 Old Git Racing World Chat Champion
| scooke |
| Nobby the Bastard |
| P.addy |
 P.addy Red Rocket
| mysterious_rider |
 mysterious_rider World Chat Champion
| mysterious_rider |
| scooke |
| Howling TerrorOutOfOffice |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 07:04 - 29 Dec 2015 Post subject: |
Be pretty bad luck if it has slipped a couple of teeth on the cam sprocket,
Never heard of it happening before, but the cam chain tensioner is a bit of a weak point on the vtr,
Pop the rocker covers off and check the timing marks,
Fingers crossed that the piston isn't jammed against the valves. ____________________ the humans are dead
I kick arse for the lord
| P.addy |
 P.addy Red Rocket
| redeem ouzzer |
| spikenipple |
 spikenipple Crazy Courier
| chris-red |
| redeem ouzzer |
| Robby |
 Robby Dirty Old Man
 Posted: 13:07 - 29 Dec 2015 Post subject: |
A backfire shouldn't cause the camchain to jump. It's unburnt fuel igniting in the exhaust. This puts pressure on the back of the valve, which is pressure in the wrong direction as far as a valve in concerned. They're strong in compression but less so in tension. It doesn't cause enough pressure to seriously interrupt the piston and jar the engine to the point where the camchain will jump.
So it is possible to damage/break a valve, but you would have to be unlucky for your first backfire to break your engine.
To diagnose, I would do the following:
1. Get the battery on charge, just in case this is all incidental.
2. While the battery is on charge, take out the spark plugs and crank timing bolt cap (usually a screw cap in the middle of a crankcase cover) and rotate the engine through a few revolutions. If the engine moves smoothly, it's fine. If you encounter a lot of resistance, there is something between the piston and head. This would need proper investigation.
3. If you don't find any resistance, put the cap back on, plugs back in, and try starting it once the charger has finished.
If you have killed a valve then I would price up replacement engines. Changing a valve is not a particularly expensive job - probably about £100 in parts and tools. The issue is the other damage you can cause, which may include a knackered head and piston. |
| Nobby the Bastard |
| temeluchus |
| andys675 |
| jjdugen |
 jjdugen World Chat Champion
| MCN |
 MCN Super Spammer
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful? |
