Engine mounting angle
overlord93
PostPosted: 22:28 - 28 Dec 2015    Post subject: Engine mounting angle Reply with quote
Hey, i'm mounting a 97' CBR600 engine which won't be at its original angle, It will be mounted so the chain exits the engine straight down above an axle, will this effect anything like the oil pick up or carbs , etc etc.
please look at the image below you'll see for the chain to directly exit the engine vertically it needs to be rotated clockwise.
https://i.imgur.com/7Sy26ul.jpg>
Stalk
PostPosted: 00:41 - 29 Dec 2015    Post subject: Reply with quote
Oil pick up, depends if its at the front or back. Carbs, more than likely
Ichy
PostPosted: 01:17 - 29 Dec 2015    Post subject: Reply with quote
oil and carbs will be a problem. What are you doing with it that it needs to be rotated that far?
jimspeed
PostPosted: 01:26 - 29 Dec 2015    Post subject: Reply with quote
I would try to keep it as close to original angle as poss or the carbs will be unhappy
Maybe using a small jackshaft and sprocket to get the chain run where you want it
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
wristjob
PostPosted: 01:40 - 29 Dec 2015    Post subject: Reply with quote
the usual way is to make the cart longer and move the axle back so stuff fits.
you are not going to have the engine that far off the floor are you?
is this for some form of organised motorsport or just mess about fun?
ive done a couple of bike engined cars and results are not as allways as good as you would expect,but sometimes its amazing!
overlord93
PostPosted: 13:31 - 29 Dec 2015    Post subject: Reply with quote
Thought it would be a problem, I won't be at that height, it will be flush with the frame. I'm trying to make short as possible, hence rotating the engine. I was thinking having two chains, one going horizontally out the engine then one going diagonally backwards to clear the engine, but ill have a rethink. What is a jackshaft? just an extension ?
Thanks for your help guys!
pdg
PostPosted: 13:38 - 29 Dec 2015    Post subject: Reply with quote
Do a google image search for jackshaft, you'll need one for 2 chains.
Or make an extension to bring the chain out further from the gearbox - outrigger bearing and support would probably be a good idea.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
PostPosted: 14:15 - 29 Dec 2015    Post subject: Reply with quote
Float heights will be messed up, it may be possible to adjust that out though. I'd have thought oil feed might be more of an issue, although you MIGHT get away with overfilling it... if the bottom of the crank is submerged in oil, you might damage it though.
c_dug
PostPosted: 15:15 - 29 Dec 2015    Post subject: Reply with quote
Do this?
https://i235.photobucket.com/albums/ee81/paddy2007dug/kart%20engine_zpsz8bnptrg.jpg
With a couple of these:
https://www.ggbearings.com/sites/default/files/styles/458x458/public/thumbnails/image/ggb-exalign-pb-pedestal-bearing-1_0.jpg?itok=Mgv5sUND
And a piece of steel bar, you'd have it knocked together in a couple of hours and not have to worry about adjusting any of the engine to suit a new angle.
PostPosted: 15:20 - 29 Dec 2015    Post subject: Reply with quote
You could almost certainly safely remove a fair portion of the cast alloy "lip" below the sprocket which would give you a wider angle to play with.
MCN
PostPosted: 15:27 - 30 Dec 2015    Post subject: Reply with quote
Just put a fuk-off diameter back wheel on.
Job Jobbed. Thumbs Up
CHR15
Turbo nutter bastard
PostPosted: 18:11 - 30 Dec 2015    Post subject: Reply with quote
use an offset sprocket and an outrigger bearing.
PostPosted: 19:58 - 30 Dec 2015    Post subject: Reply with quote
^^^I have no idea what he means but I defend his right to say it.
MCN
PostPosted: 20:11 - 30 Dec 2015    Post subject: Reply with quote
It's American maybe. Smile
stevo as b4
PostPosted: 20:12 - 30 Dec 2015    Post subject: Reply with quote
It would be someone's excuse for a load of v.sexy CNC machined alloy to bolt to the crankcase or even a new output shaft machined with a stepped diameter for the splined part maybe! Wink
The last post was made 10 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 85.13 Kb
