| Boxing |
 Boxing World Chat Champion
 Posted: 03:32 - 30 Dec 2015 Post subject: 1997 DTR Won't Start |
Hi all, had a lot of issues with my DTR bogging and stalling out. Assumed it was an air leak somewhere as it was a bit rough on idle, searched all over the bike for air leaks and replace or fixed any possible air leaks, bike then ran fine. Went out on a 20 mile ride, then went Sainsburys and filled the tank up (was unleaded before anyone assumes it was diesel, I'm very cautious at the pumps. Once bitten, twice shy.) Added two stroke, gave it a swirl to mix the oil and pulled off, got about 3 miles away from the petrol station and it began bogging at the higher rev range, approx 7-8K rpms when the power valve kicks in.
Now it will only manage to do a mile or so and bogs the whole way before bogging and stalling out to not start again for about 10 minutes, then pulls off again bogging. Until the day before yesterday when it never fired back up and I had to walk the bike home.
Anyway, I've looked at the exhaust port, is some very light scoring on the cylinder wall and the usual carbon on the piston, as expected after a couple thousand miles. Taken the spark plug out, it was very oily and probably running slightly rich, cleaned it up and replaced it, still not starting. Put a old plug in that ran fine prior still nothing.
I'm going to clan the carb tomorrow, but I've had carb problems before and it only bogged at high RPM's and leaked petrol out the overflow. It's never just not started.
Sorry for the wall of text.
Edit: Put won't spark, in actual fact meant wouldn't start.
| P.addy |
 P.addy Red Rocket
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| Boxing |
| P.addy |
 P.addy Red Rocket
| Boxing |
| stevo as b4 |
 - Super Spammer
 Posted: 18:54 - 30 Dec 2015 Post subject: |
| Boxing wrote: | | Paddy. wrote: | You don't have the pump on there? Have you up jetted to deal with petrol/oil premix. |
Nope, never had any issues prior. Been running it premix for the last three years and it's on a #240 main jet.
I'm hoping the jets are clogged or something. Was going to clean the carb today but can't be bothered with the rain.
And my names Luke, not Reece. Been here for three years, check my post history.  |
Blimey. My TZR250 race bike is on #320 mains for premix and it's essentially 2 X TZR125 motors side by side.
I'm not sure lobbing a bit of oil in the tank and swirling it about will go a lot of good with some oils, especially in cold weather.
What's wrong with the oil pump? I presume all channels and jets are spotless?
Could be a few things, maybe the crank seal is going. If you rev it with the gear oil filler cap removed and your thumb over it, is it pressurising?
Have you thought about checking fuel flow? You might have a little gauze filter in the fuel input of the carb and maybe an internal tank filter. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| Boxing |
 Posted: 04:11 - 31 Dec 2015 Post subject: |
 - Super Spammer
 Posted: 12:24 - 31 Dec 2015 Post subject: |
Your maths is way off. You are running 40:1, not 25:1. At 25 to 1 you should be putting 200ml oil in every 5L.
I ran 30:1 on my TZR250 which is 167ml to 5L. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
The last post was made 10 years, 274 days ago. Instead of replying here, would creating a new thread be more useful? |
