2013 Street Triple Timing - Timing marks not 100%
Pigeon
PostPosted: 01:10 - 31 Dec 2015    Post subject: 2013 Street Triple Timing - Timing marks not 100% Reply with quote
I've just re-shimmed all the valves on my 2013 Street Triple but am wondering if the fact the alignment marks on the cams aren't 100% opposing is an issue?
Just to clarify, this picture was before I took the cams out. You can see that the horizontal lines on the cams (covered in paint) which should point towards each other at TDC on C1 are not quite aligned.
The intake cam (left of pic) points slightly up when the exhaust cam points horizontal.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151213_145028.resized_zpsndpsedao.jpg
Small dot on cog aligning with mark on crankcase.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151220_121428.resized_zpsid7h6aka.jpg
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151220_121519.resized_zpsrmbaloc5.jpg
This is after I put the cams back. Roughly the same as before I think.
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151229_170805.resized_zps7tojj2bb.jpg
https://i1329.photobucket.com/albums/w559/pigeon35/151205%20-%20Striple%2012k%20Service/20151229_170836.resized_zpstkntmord.jpg
I tried to get the marks on the sprockets to align, but one tooth higher or lower on the cam chain and the alignment marks were either above each other or below.
So this was the closest I could get and I think matches how it was.
What do you think? Would you be happy with that?
Or would you adjust the sprockets via the torx bolts shown in the pics (requires a £30 triumph tool apparently)?
Cyl2 Intake clearances were 0.10 when the others were around 0.16.
All the exhaust clearances were around 0.25 (range should be 0.325 to 0.375).
So I'm looking at the tightening on all the exhaust clearances on an 11k mile bike. Then I'm looking at the camshaft timing marks that don't appear to be exactly aligned and I'm putting 2+2 together and coming up with 4 or 40,000?
Advice very much appreciated!!
temeluchus
PostPosted: 05:20 - 31 Dec 2015    Post subject: Reply with quote
Seem to be normal
https://www.triumph675.net/forum/showthread.php?t=64422
Also, are those aftermarket cam sprockets?
Pigeon
PostPosted: 11:23 - 31 Dec 2015    Post subject: Reply with quote
temeluchus wrote:
Seem to be normal
Cheers boss Thumbs Up
Honestly, I spent a an hour googling this before posting here. So much so that after I posted here, I carried on searching and this post was the first item returned by a google search Shocked
I took that to be a bad sign Very Happy
The 12k mile service is (according to Triumph Service Manual) supposed to include re-timing using this Triumph device that slots between the cutouts on the camshafts on the opposite side to the sprockets (pics in earlier post).
Then, having slackened the torx fixings holding the sprockets to the camshafts, you can rotate the sprockets (having removed the tensioner & chain) to get the alignment marks correct while the camshafts remain correctly positioned.
These adjustable sprockets I think appeared from the Mk2 onwards.
I think I'll leave it as was, as it was working and I'll limit the things I've messed with on my first attempt.
As a side note, the position of the lobes on Cyl1 at "TDC" seems to have lots of people thinking their cams are on back to front.
The only other bike I've done is my SV and they were definitely up & out (10:00 & 02:00), not down and together (04:00 & 08:00).
Possibly Triumph call it TDC on Cyl1, but actually the firing order is different. Certainly what I have matches the diagrams in the Triumph Service Manual (which covers my VIN), so just an observation really.
Snod Blatter
PostPosted: 13:00 - 31 Dec 2015    Post subject: Reply with quote
The marks will be out because the cam chain stretches over time, retarding the timing from where it was supposed to be. The slotted gears are a nice thought but not as nice as driving the cams with gears from the crank..
The timing marks in the TRX seemed to be nowhere near, I was so glad I put some Tipp-Ex marks on the gears and chain before I took it all to bits.
1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL
Robby
Dirty Old Man
PostPosted: 16:15 - 31 Dec 2015    Post subject: Reply with quote
I can't tell from the photo - is the tensioner in place and tensioning the chain, or is it slack?
No point trying to get a good read off it with the chain loose - it can allow just enough play to look wrong, without being enough of a difference to be out by a tooth.
Pigeon
PostPosted: 23:59 - 31 Dec 2015    Post subject: Reply with quote
Thanks all. OK, so ideally it does sound like I should have tweaked the timing via the adjustable cam sprockets, but to be honest I'm just happy shes back together and running
Will make sure the timing tool is ordered before the next clearance check and do it a bit early.
Robby, the tensioner was in place for those pics.
The last post was made 10 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 52.43 Kb
