| Pigeon |
 Pigeon World Chat Champion
| temeluchus |
| Pigeon |
 Posted: 11:23 - 31 Dec 2015 Post subject: |
Cheers boss
Honestly, I spent a an hour googling this before posting here. So much so that after I posted here, I carried on searching and this post was the first item returned by a google search
I took that to be a bad sign
The 12k mile service is (according to Triumph Service Manual) supposed to include re-timing using this Triumph device that slots between the cutouts on the camshafts on the opposite side to the sprockets (pics in earlier post).
Then, having slackened the torx fixings holding the sprockets to the camshafts, you can rotate the sprockets (having removed the tensioner & chain) to get the alignment marks correct while the camshafts remain correctly positioned.
These adjustable sprockets I think appeared from the Mk2 onwards.
I think I'll leave it as was, as it was working and I'll limit the things I've messed with on my first attempt.
As a side note, the position of the lobes on Cyl1 at "TDC" seems to have lots of people thinking their cams are on back to front.
The only other bike I've done is my SV and they were definitely up & out (10:00 & 02:00), not down and together (04:00 & 08:00).
Possibly Triumph call it TDC on Cyl1, but actually the firing order is different. Certainly what I have matches the diagrams in the Triumph Service Manual (which covers my VIN), so just an observation really. |
| Snod Blatter |
 Snod Blatter Crazy Courier
| Robby |
 Robby Dirty Old Man
| Pigeon |
 Posted: 23:59 - 31 Dec 2015 Post subject: |
Thanks all. OK, so ideally it does sound like I should have tweaked the timing via the adjustable cam sprockets, but to be honest I'm just happy shes back together and running
Will make sure the timing tool is ordered before the next clearance check and do it a bit early.
Robby, the tensioner was in place for those pics. |
The last post was made 10 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
