Servicing a mechanical watch
Error 650
PostPosted: 18:43 - 08 Jan 2016    Post subject: Servicing a mechanical watch Reply with quote
I have one of these
https://i65.tinypic.com/25aui44.jpg
It's getting on for 9 years old now. It could really do with a service, a couple of times a day it'll just stop for no apparent reason and a gentle 'tap' will get it going again. If it's left in a draw it never stops, not much use there though.
Is there an easy way to service a mechanical watch? what expense would be involved?
CaNsA
PostPosted: 19:25 - 08 Jan 2016    Post subject: Reply with quote
Are there any jewellers in Kent that you could ask for a quotation?
Error 650
PostPosted: 19:27 - 08 Jan 2016    Post subject: Reply with quote
I live in Tooting. I could I suppose ask a shop.
RhynoCZ
PostPosted: 19:32 - 08 Jan 2016    Post subject: Reply with quote
Taking it apart, safely, would require some special (small) tools. Cleaning the watch by a professional is not that expensive actually (if there is no local watch repair man, you can always send the watch via mail). Well, he'll probably take the back off and tell you quite right away how much will he ask for the cleaning/repair.
The watch stopping could be anything from dirt/dust in the case to worn bearing jewels. Thumbs Up
PostPosted: 20:16 - 08 Jan 2016    Post subject: Reply with quote
Sound like something is loose inside. My daughter's boyfriend has a watch left by his granddad that never worked despite being fully wound. A local watch shop wanted £100 to look at it. I took the back off and found that a tiny post had come un-screwed and lodged in the pendulum. I carefully removed it and the watch started right away.
arry
PostPosted: 20:26 - 08 Jan 2016    Post subject: Reply with quote
There's a watch shop in Grays I use - cheap and old school. Not too far for you to go I guess but it's a trip out to get there
Error 650
PostPosted: 20:34 - 08 Jan 2016    Post subject: Reply with quote
Not too far, a trip out on the Cbr. I'll open the watch and have a look around first, spray it with wd40 and a blast of compressed air, see what that does.
Sload
PostPosted: 20:41 - 08 Jan 2016    Post subject: Reply with quote
That could be hilarious, please let us know Thumbs Up
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
arry
PostPosted: 21:14 - 08 Jan 2016    Post subject: Reply with quote
It's a place called Lyn Jon on Southend Road Grays RM17 5. He's a bit slow in turnaround but he's put a couple of my older watches back together well
Chuffin Nora
PostPosted: 00:08 - 09 Jan 2016    Post subject: Reply with quote
Not entirely the best recommendation for a watch repairer!
There's a fine line between integrity
Ariel Badger
PostPosted: 00:21 - 09 Jan 2016    Post subject: Reply with quote
Bloke I know has a fast turnaround, you takes your choices to what best suits you.
Chuffin Nora
PostPosted: 03:00 - 09 Jan 2016    Post subject: Reply with quote
A-A-Ahmmmm. Thinking
Not entirely the best recommendation for --- oh, never mind . . . Brick Wall
PostPosted: 14:37 - 09 Jan 2016    Post subject: Reply with quote
Why not give it a good shake and listen for anything loose? If you hear something moving about inside pop the back off and see what's up.
arry
PostPosted: 17:53 - 09 Jan 2016    Post subject: Reply with quote
Vincent wrote:
Is this a wind up? Wink
I clocked that too. You have to watch yourself on here these days. But I'm dialled into it now. I'd think of some more but I'm strapped for time - matters out of my hands
Chuffin Nora
PostPosted: 18:03 - 09 Jan 2016    Post subject: Reply with quote
Jsmith86 wrote:
I'll open the watch and have a look around first, spray it with wd40...
Yeah, the inherent problem with squirting WD40 into the mechanism is that the watch will run fast thereafter, as time will keep on slipping, slipping, slipping into the future.
Flying like an eagle, no less.
I'm on a Rolex!
WD Forte
PostPosted: 15:27 - 10 Jan 2016    Post subject: Reply with quote
I dimly recall reading a tip about putting some butter in a watch
to improve its accuracy.
Cant remember where though
bikers smell of wee
The last post was made 10 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 102.48 Kb
